FIX THE IMAGE LINKS D HEADS
RE: FIX THE IMAGE LINKS D HEADS
It's been hit and miss for me. But more hit than miss. And I just can't spend the time trying load photos three or four times. And when the photo upload fails, it also seems to do something to the connection and I often have to quit Firefox then re-open even to post a message. This is NOT a minor glitch. This is a MAJOR cock-up with the software!
I have tried to load a photo from my Photobucket .
5 ..... Times and it timed out or I get (This Image or Video has been removed or deleted)
I have placed the right link in the box .
I give up
So Please fix it
I will be nice now OK
Just had the Sh.ts before
I give up
So Please fix it
I found something that seems to help. It seems something with the cookies is what the problem is. If I log out then log in again I can get photos to upload. I will also post, hit ok, then go back and edit to add photos. Using the multi file upload option seems to work better then the regular upload. I am with the others that usually post here to go to other forums to post my build threads there. It's a lot of work to type it all out so people can understand it then when you go to upload the images it all goes poof! It has gotten better in the last 24 hours though. I was able to use both styles of uploading tonight so maybe the worst is behind us.
