Balsa USA 1/4 scale Fokker DVII from plans
Reply
Old 02-19-2012, 04:18 PM
  #76
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Balsa USA 1/4 scale Fokker DVII from plans
I am going to be putting a DLE-50(if it fits) up front and I will be building the tail lighter than stock(I hope).
I have the laminated sheets for the fuse sides drying, I will start framing up the fuse tomorrow.
Later!!
Anthony
WacoNut is offline
Old 02-19-2012, 05:49 PM
  #77
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought very light in my tail, eliminating most of the wood they recommended back there. I also used pull pull cables which help a lot with tail weight. I have a G38 on mine and still needed to add 2# of nose weight. I think the DLE 55 is close to the same weight as the G38, maybe a little more with the added ignition battery. That will be a good combo. I will be interested to see how well it fits and can be hidden inside the cowl. There is a lot of room. If you cant the engine to one side or the other, you may be able to get the plug concealed by your dummy engine. Now that I have had all of this time to think about combos, I would put a G62 in my next one. I doubt it would require any nose weight and the cylinder is 1" shorter than the DLE 55.
vertical grimmace is offline
Old 02-19-2012, 06:11 PM
  #78
geezeraviation
geezeraviation's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you say "rocket ship"?
geezeraviation is offline
Old 02-19-2012, 06:54 PM
  #79
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have seen a 1/4 D7 fly at the Owatonna warbird event that had a dl50. I am not sure anything can make them go faster than the drag allows
but the guy sure had nice power, and maneuverability with that motor.
foodstick is offline
Old 02-20-2012, 02:14 PM
  #80
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the tips,
I have the sheeting laminated for the front of the fuse and it is ready to apply the template and run thru the band saw. I plan on starting the 1st fuse side tonight. I need to dig out my DLE-50 and lay it over the plans and see how it is going to fit.
I will post some pics once I get some of the framing going.
Anthony
WacoNut is offline
Old 02-20-2012, 05:11 PM
  #81
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have started on the 1st fuse side. It is going together pretty good.
This is my 1st attempt at framing with dowels but so far I like it. I spliced the upper longeron into a 1/4x3/8 stick stock where it will be hidden from the hood sheeting. I am using a 1/4" dia sanding roll in my drill press to put a radius into the end of the dowels at the joints. All the joints will be drilled,glued and pegged once it has dried and I can remove it from the table. I also spliced in a piece of balsa for the stab saddle.
I found it easier to fit the upright then cut the diagonal to fit and sand the radius until it all matches then glue them in place. Here are a few pics of my progress.
Later!!
Anthony
ID:	1729729   Click image for larger version
ID:	1729730   Click image for larger version
WacoNut is offline
Old 02-20-2012, 05:49 PM
  #82
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At the risk of sounding stupid.. is there a reason you are using the dowels instead of just round ing the stock wood after framing it up? I realize you started without a kit..
Do you think the dowels will be stronger? I would assume they will be heavier..
just wondered.. it will fly well regardless...
Old 02-20-2012, 06:06 PM
  #83
geezeraviation
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The shape you're putting on the dowel ends is referred to as a fishmouth
Doc
Old 02-20-2012, 06:09 PM
  #84
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No Problem, not a stupid question it is just the way I wanted to do it
In reality it shouldn't really add much weight. The poplar wood is fairly light and yes it should be stronger. I am going to detail out the cockpit and the dowels should help in that respect as well. I am having to change things around slightly because of using the dowels but I usually change things the way I want them anyways.
I will add a few scale turnbuckles and wires in the cockpit area as well. I am attaching a pic I found of the DVII cockpit.
Later!!
Anthony
WacoNut is offline
Old 02-20-2012, 06:38 PM
  #85
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good Anthony. I believe your right about being stronger without significant weight gain. Would like to know what adhesive your using, just curious. Some years back I built some bamboo replica gazeebo's. Used the same technique and wood glue. Almost indestructable.
acerc is offline
Old 02-21-2012, 02:36 AM
  #86
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Robert,
I am using med CA to glue the dowels. The joints will get drilled and pegged and I will use wood glue for that. It should make for a nice strong joint.
Later!!
Anthony
WacoNut is offline
Old 02-21-2012, 05:00 AM
  #87
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anthony, wow, seems like fitting jointswith dowels would be very time consuming and difficult ! You are the man....Was it hard to find straight dowels because everytime I look at the dowel selection at the LHS they are always bent.
VincentJ is offline
Old 02-21-2012, 04:30 PM
  #88
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi VJ,
I picked the dowels up at the local Lowe's. They have a huge selection of dowels at a good price. I bought enough dowels to frame up the fuse for $8. It didn't take long to pick out some nice straight dowels.
The 1st side is off the table and I am pleased with it. I married in some square balsa stock at the tail end to keep it light and make it easier to mount up the stab later. The 2nd side is now on the board and I should be able to finish glueing it up tonight. Fitting the dowels isn't too bad once you get used to working with it. I am anxious to see how it will look once the sides are joined together. I have to pick up some more 1/8" ply to make the fuse formers and the fuse ply doublers.
It was also great to see the fuse side did not relieve itself once it was released from the table, very little stresses built into the structure.
Later!!
Anthony
ID:	1730117   Click image for larger version
ID:	1730118   Click image for larger version
WacoNut is offline
Old 02-25-2012, 06:21 AM
  #89
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A little progress,
I have both fuse sides completed and the ply doublers glued in place. I will be joining the fuse sides together today. I still need to cut the front fuse formers so once that is complete I will join the front end of the fuse together and let that dry until tomorrow then work the aft end.
Later!!
Anthony
WacoNut is offline
Old 02-25-2012, 08:29 AM
  #90
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did finally lay the DLE-50 over the plans and the motor will fit just fine. The top of the cylinder head comes to the top of the fuse side/bottom of the cowl top. Should be able to keep the spark plug and wire hidden in the dummy engine. I am moving the firewall back 1.1" from the location shown on the plans. I still may need to rotate the engine slightly but that will be determined after the framing is complete and the cowling built.
I am setting the firewall with 2 deg of down thrust and "0" deg of right thrust. I think setting right thrust on this plane would look bad. I wll post some pics of the fuse once the sides are joined together.
Later!!
Anthony
WacoNut is offline
Old 02-25-2012, 02:34 PM
  #91
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuse sides are joined together(at the front anyways),
It took a while to get everything lined up properly but all came out fine. I will drill and pin the firewall while I am pinning the dowel joints in the aft end of the fuse. I added some extra tri-stock pieces for strenth at all the joints. I will let this sit a little while longer to make sure the epoxy has cured enough to continue with the aft end.
Later!!
Anthony
ID:	1731806   Click image for larger version
ID:	1731807   Click image for larger version
WacoNut is offline
Old 02-25-2012, 04:27 PM
  #92
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The tail end of the fuse is now joined together.
I do like the looks of the dowels in the fuselage. I need to start working on the scale tail skid before I do much more work to the fuse.
Here are a few pics.
Later!!
Anthony
ID:	1731878   Click image for larger version
ID:	1731879   Click image for larger version
WacoNut is offline
Old 02-25-2012, 04:45 PM
  #93
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking at your pics brings back memories..
The fuselage on a D7 always reminds me of a big carp until you get that cowl on there
I will be interested to see how you like the handling of this plane compared to some of your Waco's. Sometimes i sweat taking mine out and flying it, but as long as it is running its nearly impossible to get in trouble.
Old 02-25-2012, 06:04 PM
  #94
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very impressive build Anthony! Looking Great.
VincentJ is offline
Old 02-25-2012, 06:14 PM
  #95
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks VJ,
I may have gotten ahead of myself a little. I added sheeting to the stab saddle and I didn't give any thought to access to the bungee for the tail skid. I have to rethink how I want to gain access.
Later!!
Anthony
WacoNut is offline
Old 02-26-2012, 09:53 AM
  #96
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am borrowing the tail skid design from Del Johnson that he is using on his V29 build(Thanks for the pics Del).
After looking it over It finally dawned on me I could just put a removeable 1/8 ply cover fron the tail post forward to the 1/8" balsa sheeting I had already installed. I cut the tail skid from Red Oak and the base for the bungee chord to attach to is made from spruce. I will pick up some 1/2" tubing to go over the dowel post for the tail skid to attach too. I am taking the rest of the day off from the build to watch the Daytona 500.
Later!!
Anthony
ID:	1732215   Click image for larger version
ID:	1732216   Click image for larger version
WacoNut is offline
Old 02-26-2012, 12:46 PM
  #97
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well since the race in under a rain delay I went back to work on the DVII.
I do not have the materials yet for the landing gear or the mounts so I went ahead and added the top fuse formers and stringers. I also discovered I made a mistake when I cut the balsa front fuse sides. These should have been flat across the front to allow for the cowl mounting. This was not clear on the plans and I did not look far enough ahead in the instructions. This required a little surgery to correct. The template was used to mark the line and a cut made and the material removed.
I think I will go ahead and start building that beast of a cowling.
Later!!
Anthony
ID:	1732323   Click image for larger version
ID:	1732324   Click image for larger version
WacoNut is offline
Old 02-28-2012, 12:28 PM
  #98
jeffEE
jeffEE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is food for thought. I just picked up this nice prop from Balsa USA. It would look good on the front of that DL 50.
jeffEE is offline
Old 02-28-2012, 02:16 PM
  #99
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi jeffEE,
I put the same prop in 20x8 on my DRI. I plan on buying a 22x10 for the DVII.
I haven't worked on the DVII anymore spent lastnight watching the race and too many honey do's tonight. Tomorrow is my birthday so maybe get a little time tomorrow evening.
Later!!
Anthony
WacoNut is offline
Old 02-28-2012, 04:30 PM
  #100
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well then let me wish you a very Happy Birthday!
VincentJ is offline
Reply
Display Modes
