Which engine for 1/3 pup
My Feedback: (23)
MI
My 1/3 pup is about ready to set up and cover but I'm not sure which engine to use. I was originally going with a dle55 and adding nose weight, afraid it will be underpowered. Then I thought why not a dle111 and no weight. I know thats overkill. Then theres the da85 which has the "da" price tag. I'm not really a fan of zenoah engines either. I will buy either one new. I like the 55 idea and I dont want to rip the plane apart with the 111. Ive only seen videos of the 1/3 scale fly, mostly with g62s and they look scary underpowered. I'm not dogging any make of engine here, just looking for input. Thanks
RE: Which engine for 1/3 pup
If your plane is under 29 lbs with engine and your flying around sea level a G-62 is a good choice and is cheap. I've seen a lot of pups fly with this power plant. I think the dle 55 is just as powerfull and will do fine with added nose weight. I have a da 100 in my 1/3 gtm fokker and not to worry about ripping the plane apart. In fact twins have less vibration. If you have around 800 dollars I would choose the dle 111 or a used da 100 which i bought for $750. Twins sound nice and you can swing big prop that is more scale. Don't get those gear reduction units cost an arm and a leg for not much more power.
My Feedback: (95)
ORIGINAL: jefflangton
My 1/3 pup is about ready to set up and cover but I'm not sure which engine to use. I was originally going with a dle55 and adding nose weight, afraid it will be underpowered. Then I thought why not a dle111 and no weight. I know thats overkill. Then theres the da85 which has the ''da'' price tag. I'm not really a fan of zenoah engines either. I will buy either one new. I like the 55 idea and I dont want to rip the plane apart with the 111. Ive only seen videos of the 1/3 scale fly, mostly with g62s and they look scary underpowered. I'm not dogging any make of engine here, just looking for input. Thanks
I did eventually put a smoke system in it and added a paint ball gun system for sound. This and other stuff put the weight around 43lbs. The 62 still pulled it but it took some airspeed to make it through a loop. The 95cc fixed the additional weight problem but I did have the occational wire break due to having more weight and more power. It made for exciting landings! The dle 111 would be nicer, since you could swing a prop that would come closer to scale but you MUST be mindfull of the G-load you put on the frame with that engine.
If it were my plane, I would go with the 111 and overprop it a little. You could swing a big prop and it would reduce the power a little. It's much better to hear an airplane that is chugging along on 1/4 throttle from a big engine, versus a smaller engine whining at a high rpm..... my opinion of coarse.
ORIGINAL: Joe Westrich
I have had this airplane with a G-62 and a 95cc engine. The 62 will fly the heck out of it, as long as it is not loaded down with weight from extras you put on it. If it comes out between 25 to 30lbs, you will have no problems at all. I consider the dle 55 and the 62 about equal.
DougB1
FL
flew one for years with a g-62 at 37 lbs, plenty of power. i was at 1000 ft altitude at the time. if your in the mountains you may want a 85. 100 is overkill you will want to beef up the airframe alot.
My Feedback: (38)
I have flown a 35 lbs pup with a 3.7 Sachs mag engine with a 24x10 prop and it flew great - capable of rolling circles and lots of other aerobatics........altitude here in Indiana is about 750 feet above sea level.
I also flew a 37 lbs pup with a G 62 (mag) also w/24x10 prop....also flew great, but not quite as strong as the other one. I go to a fly in in the Ozarks where the altitude is about 1700 feet and the power is affected somewhat, but it doesn't struggle at all. I also flew this same pup with a Zenoah 445 (74cc) twin (same prop). I liked the extra power a lot. For scale flying a G62 or equivilent (DLE 55) is fine, but for spirited dog fighting a bigger engine is loads more fun.
I say go for the extra power, up to an 80 twin or an 80 or 85 single - but would not recommend a 100 cc twin or larger. Just my 2 cents worth......Art
BC, CANADA
Mine is 32 lbs, G62, 24/8 plenty of power. Does loops just fine, need to push the nose down first, (scale). A pup needs a heavy motor up front, even with a G62, mine has about 2 or 3 lbs. of ballast (can't remember the exact amount). More power doesn't really do you much good, it will only go so fast with all the drag from 4 wings and all the flying wires. All the new engines are pretty lightweight, so more balance weight needed.
GA
Another option to consider is a belt drive on a G62. Check out the Mick Reeves site. You will be able to swing a 30x12 prop at about 4200rpm. Tons of torque and power.
John
John
Greg
Mine has a G62, and the Pup is a heavy one at 40lbs. No shortage of power, does every manoeuvre the full size did with ease. Never got the sense ever from it that it was lacking in power - all you have to do is calculate the wing loading on it (way less than 20oz. if I remember correctly), plus the super lift from the undercambered wings, and if there wasn't all the drag it would be a glider!
Cheers,
Mike
Cheers,
Mike
