G62 for a 77" P-47?
Reply
Old 11-11-2012, 08:02 AM
RCER88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: G62 for a 77
Propped right it should do fine. I am flying a 23 lb Scale Davis with a 110" WS on a Quadra 35 this is a HUGE draggy airplane. I have a US 41 on the front of a 80" Zero. I am still ground testing but preliminary tests indicates it will have more than enough thrust. Weather has gone bad here in MI so probably won't maiden until next spring. Good luck.
RCER88 is offline
Old 11-11-2012, 08:17 AM
RCER88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ScottMcM
Never mind....I pulled the sparkplug out, and held it against the engine while I spun it with my starter.....pretty blue spark....I must be living right...the seller said that it needed a new coil. I plan to put it on a test stand tomorrow and see if it runs. Will let you guys know.
I bought a bunch of coils at a swap meet last year for $2.00 a piece. I was glad I did. I had to replace one on my Davis earlier this season. I also bought a US26 and another US41. The US and Quadra are very similar engines so some parts swap without problems. I still use the mag coils. The extra weight is not a problem and welcomed in the birds I am flying. I have switched though to the solid state coils that way I don't have to mess with the points and condenser. They run great.
RCER88 is offline
Old 11-11-2012, 08:37 AM
ScottMcM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
False alarm. I just got in from test running the engine. No problems at all, in fact, it will hand start pretty easily too. When I did use the spring starter, I noticed a grinding sound as I was winding it. It sounded like it was coming from the coil, but it turned out to be from the starter rubbing on a homemade engine mounting plate that the previous owner put on it. As a matter of fact, it runs better than the one that was sold as a good engine....go figure.
ScottMcM is offline
Old 11-11-2012, 08:44 AM
ScottMcM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a photo of the plane WS is 77". From the front of the cowl to the end of the rudder is 64". Dry weight is 20 lbs. Does it look familiar to anyone?
ID:	1819399   Click image for larger version
ScottMcM is offline
Old 11-11-2012, 08:47 AM
flycatch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like an ESM ARF and the 1.8 Moki will fly it.
flycatch is offline
Old 11-11-2012, 09:11 AM
  #31
ScottMcM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow....never thought it was an ARF. Thanks for the info, though.
ScottMcM is offline
Old 11-11-2012, 12:33 PM
  #32
2walla
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a moki 180 and it is more than nough power for your plane. Mine ran perfectly on 10% red max. Most people that have had issues dont know how to tune them. Replacing it with a g38 or quadra 41 is a step down in power AND an increase in weight. I have both of those motors too..g62 is pretty heavy for the airframe size so unless there is three lbs of lead on the firewall i would go with a lightweight 50 cc gas motor if you dont want to go with the moki.
2walla is offline
Old 11-11-2012, 03:22 PM
  #33
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The US41 will fit in that cowl nicely and you can patch some of the other holes. Should look nice when you have it in.
flyinwalenda is online now
Reply
Display Modes
