Rudder to Retractable Gear link
Reply
Old 11-11-2012, 01:08 AM
DennisS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Rudder to Retractable Gear link
I have a TF Giant P47. Installing Robart retractable tail gear, will turn using pull/pull to a servo. Also using rudder servo. I want to link the two together, but don't want the tail wheel turning while retracted in the bay, while using the rudder. I'm lost as to the best way to make this all work.
Dennis
DennisS is offline
Old 11-11-2012, 01:27 AM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Rudder to Retractable Gear link
Sorry I am not familiar with your tailwheel but other nosewheel systems I have used functioned because as retraction took place the the pull pull wires were slackened.
John
JohnBuckner is offline
Old 11-11-2012, 02:32 AM
DennisS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John, never thought about that, I'll check and see. Thanks for your insight.
Dennis
DennisS is offline
Old 11-11-2012, 02:34 AM
abufletcher
abufletcher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the original P47 wasn't the tail wheel (as on many WWII aircraft) free-castering?
abufletcher is offline
Old 11-11-2012, 03:02 AM
Teus
Teus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can also place a micro switch in the pulse line so that activated the switch will disconnect the pulse from your tail wheel steering servo when retracted.
Teus is offline
Old 11-11-2012, 06:58 AM
aghost
aghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DenisS: The TF GS P-51 has a retractable tailwheel setup like you describe for their P-47. The pull-pull lines do go slack when the wheel is up. I (and others) added a small spring on each side of the tailwheel to keep it centered while retracted. The small springs do not affect the movement in the down position. Seems to work well.
I have a picture somewhere. Will post it if I can find it.
Brian
aghost is offline
Old 11-11-2012, 07:16 AM
LesUyeda
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"On the original P47 wasn't the tail wheel (as on many WWII aircraft) free-castering? "
Absolutely, BUT, Abu, have you ever tried to taxi a model in a cross wind???:-))))))))))))))
Virtually impossible without being able to control the tail wheel.
Les
LesUyeda is offline
Old 11-11-2012, 07:32 AM
dasintex
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like the others have stated, the Pull-Pull Wires will go Slack and preventing the Tail Wheel from Turning while Retracted, adding springs will keep the Tail Wheel Straight, so the Wheel doesn't get hung Up in the Bay, I used this set up on my TF Giant P-40, here is a picture showing the Springs.
dasintex is offline
Old 11-11-2012, 08:19 AM
Walt Thyng
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tail wheels were free castering for taxiing and landing, but locked for take off.
Walt
Walt Thyng is offline
Old 11-11-2012, 01:34 PM
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use a seperate servo for the tail wheel steering of the nose wheel steering. When the gear is retracted my streering servo is turned off. That way I don't have any steering while the wheel is retrached. How you do this by your Tx depends on what brand and model you have.
BobH is offline
Old 11-11-2012, 03:05 PM
abufletcher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: LesUyeda
''On the original P47 wasn't the tail wheel (as on many WWII aircraft) free-castering? ''
I've never had a model with a tail wheel...and proud of it!
Old 11-12-2012, 07:13 AM
LesUyeda
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried a wooden skid with a 1/16 diameter piano wire "wear proofer" and our strip wore thru that wire in about 3 takeoffs.:-(((((((((((((
Les
LesUyeda is offline
Old 11-12-2012, 08:07 AM
scale only 4 me
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: DennisS
Dennis
This is how I did it on my Zirolli p47
Pull-pull system off a servo wheel for the tail wheel steering tied to a regular servo arm for the Rudder, cables go slack when the gear is retracted up
http://youtu.be/g94Aq-DxCrA
p.s.
The tail retract is actuated by a hitec 5645 programed to 10% speed (no air on this one, mains are Lado actuated also)
scale only 4 me is offline
Reply
Display Modes
