Andy Sheber Pitts s1s
Reply
Old 01-09-2013, 04:11 AM
  #501
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Andy Sheber Pitts s1s
Wow turned out super. Thanks for the tips, the tape tip will definitely be helpful down the road.
VincentJ is online now
Old 01-09-2013, 10:11 AM
  #502
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad to help when I can.
acerc is offline
Old 01-09-2013, 10:14 AM
  #503
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuse has been sanded, the stabilizer and fin have been sanded aswell and installed. While that is drying I can get the rudder and elevator sanded.
acerc is offline
Old 01-09-2013, 12:07 PM
  #504
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The elevator and rudder are sanded and in place. And I think I'm done for the day. I know this morning I said I wanted to get the strips in for the fuse panels but I don't have the 1/16th ply to cut them from.
Later!
acerc is offline
Old 01-09-2013, 07:09 PM
  #505
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not much done today, some days are like that. I have to mow my clubs field tomorrow and will pick up the piece of 1/16 I mentioned earlier. On my plans there is a template for the cockpit opening. Is the template the size of the opening as if looking down from above or is it to be layed over the curvature of the wood and cut out?
acerc is offline
Old 01-09-2013, 07:17 PM
  #506
straitnickel
straitnickel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Measure the width of the template at the rear and see if it matchs the former at the rear of the cockpit.
straitnickel is offline
Old 01-09-2013, 07:19 PM
  #507
straitnickel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If its wider than the former, will a curve make it fit?
Old 01-09-2013, 07:20 PM
  #508
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep! It does, thank's strait!
acerc is offline
Old 01-10-2013, 10:43 AM
  #509
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I awakened around 3am this morning with a though of "Hey dumb dumb you can do this" in regard to the cockpit opening. So when I got home I measured the opening height on the side viewand the width on the overhead view. Put the template in place, marked with chalk, measured,and cut. When this is dry I will epoxy a 1" strip of glass on the inside edge of the opening, just to give it a little strength.
acerc is offline
Old 01-10-2013, 01:26 PM
  #510
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have installed the 1/16x3/8 ply for the fuse panels, the black lines. Did not take as many as I thought, most of in front of cockpit fell on the 1/4 ply formers.
acerc is offline
Old 01-10-2013, 03:05 PM
  #511
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Old Man that's looking pretty good
Won't be long and you will be putting the fabric on.
Later!!
Anthony
WacoNut is offline
Old 01-10-2013, 03:34 PM
  #512
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Robert, i dont quite understand - is there another panel that goes from the former where the front of your undercarrage sits to overlap the panel you have highlighted in black or is there only the one panel ?
john josey is offline
Old 01-10-2013, 04:10 PM
  #513
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John there will be six panels. Two yellow and two green, one on each side. And one red and one blue, of which goes across the top of the fuse.
acerc is offline
Old 01-10-2013, 04:20 PM
  #514
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Robert,
What are you going to make your panels from? I used 1/64 ply with good success on my 25% Waco. Steam it in a microwave for a couple minutes and it becomes very pliable. I added my panels after covering and gave then several coats of Polycrylic then primer and they were very convinceing for aluminum panels.
Later!!
Anthony
WacoNut is offline
Old 01-10-2013, 04:26 PM
  #515
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anthony, I'm going to attach 1/64 ply to some very thin aluminum and screw in place. I used the 1/64 on my 1/5 scale Waco and it did turn out well. Just want to try something different.
acerc is offline
Old 01-10-2013, 04:46 PM
  #516
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds good,
I usually try somehting new with each build.
WacoNut is offline
Old 01-10-2013, 04:53 PM
  #517
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: acerc
Yeah, that make's sense Robert. Cant wait to see the fullsize, dont think i'll get much sleep the night before !
Guy's, these aeroplanes are beautifull....what other delights have you got hiding away ?
Old 01-10-2013, 05:06 PM
  #518
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank's John! I need to finish the sanding on the top wing and get it mounted. I need the cabane's in place to cut the panels to fit arount them.
acerc is offline
Old 01-10-2013, 05:39 PM
  #519
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John,
The Waco I posted a pic of is now in the WACO Museum in Troy Ohio on permenant display. I donated it last spring.
I have a 1/3 Waco going thru a rebuild now due to pilot error. Destroyed the fuselage[:@]
Sorry to hijack Robert!!
Anthony
WacoNut is offline
Old 01-10-2013, 06:15 PM
  #520
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And here is the paper teplates for the 1/64 ply.
acerc is offline
Old 01-10-2013, 11:55 PM
  #521
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: WacoNut
Anthony
Hi WN, can you describe the process of steaming in the microwave ? sounds interesting! Thanks V.
vasek is offline
Old 01-11-2013, 02:49 AM
  #522
WacoNut
WacoNut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: vasek
Hi vasek,
I cut the ply close to the size I need then put a eough water in a dinner plate to cover the bottom. Set the ply in the water and microwave for 1-1/2 to 2 minutes. This will essentially steam the plywood and make it very easy to bend. I put it on the plane and finish trim to size with scissors then secure it to the plane and let it dry. Once dried it will maintain it's shape. Works good for removeable panels as well.
Later!!
Anthony
WacoNut is offline
Old 01-11-2013, 07:16 AM
  #523
brianrfike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey acerc,
Where can I get my hands on a set of these plans? I also saw a post earlier from Rick about a 1/4 scale version. Any help will be greatly appreciated!
Brian
brianrfike is offline
Old 01-11-2013, 07:32 AM
  #524
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Brian. Go back to one of those post by Rick and Pm him. He has the plans.
acerc is offline
Old 01-11-2013, 08:19 AM
  #525
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Been workin on the wing bolt area. The current set up requires a 2-1/4" bolt. I installed a new ply bolt plate as seen in red. This will reduce the bolt length to 1". And also gives me a good point for an alignment dowel.
acerc is offline
Reply
Display Modes
