Andy Sheber Pitts s1s
#676
RE: Andy Sheber Pitts s1s
One by one gettin it done. One more task down. The belly pan has been glassed. Well sorta. I don't use fiberglass, I use polyester fabric as well as polyester finishing resin. A nuch more flexibletechnique for these airframes.
#677
I'm with you on the polyester Robert. I think when you start the covering, you'll begin to see a bit of light. I may even get a cheap ticket to come and see it fly !
#679
NC
ORIGINAL: john josey
Maby we will all get to see it fly onYou Tube.
#682
Ok, maybe my control horns are too big but I really like having good ground control as well.
One of the thing's I like about these hinges and making new pins, the control surface is removeable.
#683
ORIGINAL: acerc
Wow!
John is that one of the pilots you're trying to get?
Wow!
Here is a link to his site - https://picasaweb.google.com/1116209...pitInstruments#
#685
ORIGINAL: acerc
Thank's, but I think I'll stick with something from Toys R Us and modify it.
#686
This could be another option - http://www.ytinternational.co.uk/tai...red_third.html
#687
The covering on the bellypan turned out well. Tomorrow I will give it one more coat of resin and call it done, ready for primer and paint.
JJ, I get nothing under that last link you posted.
#688
Sounds like you are making good progress Robert.
I had a hard time finding a 1/3 scale pilot. I bought the one for my Waco at Toledo from a Roy Valiancort and went back to him a couple years later to get another one for my 1/3 Cub and he was out of them and evidently his supplier that molded them passed away. Not much available in a quality 1/3 full body pilot without paying big $$$. I wound up transfering the pilot from my crashed Waco to the Cub of course after having a stern talk with him about the incident. Looks like he will be moving back to the Waco and I will have to find something else for the Cub.
Later!!
Anthony
Later!!
Anthony
#691
Watching your speedy progress Robert got me to push on some of my projects.
Finnished 2 planes. They are ready for test flights. And back at work on the super long rebuild I started over a year ago.
Ken
Ken
#692
almost time for flying wires! I epoxied wood blocks in place then drilled in 1/8 wood dowels through block into rib that is beefed up . went with 2-56 threaded couplers that except 90# seven strain wire with crimps that were used for off shore fishing! Then small piece of heat shrink over crimp. Seven Strand was the wire I used that has a plastic coating. once clevises were in place I used blue locktite on the on nut jammed againts the clevis . This is a quick methed at the field to get in the air fast. On my Andy Sheber Pitts I used 4-40 rod 2 in front 2 on rear like full scale with dubro clevises,, polished out ,, looked great but kept braking metal mounts! Good Luck! I like it
#693
Easy there Ken, I'm home evryday with not much better to do. But still glad to hear it.
Billy the fishin wire is a shure fire, quick method. I will also be useing the 4-40 rods but will be useing the Dubro rod ends, they bolt down and help keep the flex to a minimum.
#695
Good luck on finding a toy slodier at 1/3 scale. Your progress has been remarkable to this point and it's looking real good. I have a thing for biplanes although usually WWI but this makes me think a Pitts might be a cool addition in the hangar. Been watching since near the start, keep up the good work.
Doc
Doc
#696
Thank's everyone. Been wondering where my order of little stuff is, screws, bolts, push rods, fuel line, etc.etc.etc
Well, looking through my order history for a packed and ship date I realised, I have not ordered anything. DUH!! It'll never get here.
So, I just placed an order with an in state supplier which has one day shipping.
#697
ORIGINAL: acerc
Is YT international not an american company ?
#699
Ok got it from youtube.
http://www.youtube.com/watch?feature...&v=8qRkSKwJpKo
