Reload this Page >
1/5ish scale Red Baron RB-51
Old 06-13-2015, 05:59 AM
  #51
TheRickster
My Feedback: (12)
TheRickster's Avatar
Fuel system arrived. Now to find proper placement for CG and make up some series harnesses.
Old 08-23-2015, 04:37 PM
  #52
TheRickster
My Feedback: (12)
Static photos
ID:	2116333   Click image for larger version
ID:	2116334   Click image for larger version
Old 08-23-2015, 04:39 PM
  #53
TheRickster
My Feedback: (12)
https://www.youtube.com/watch?v=Hx4ZTXsmo7E&feature=youtu.be
Old 08-24-2015, 10:39 AM
  #54
FlyerInOKC
FlyerInOKC's Avatar
Beautiful flight, love them counter-roatating props!
Old 08-28-2015, 02:59 PM
  #55
77chickenhawk
77chickenhawk's Avatar
Sure sounds like it could use some more pitch in the props based off the speed on the flyby. Excellent job fantastic looking plane
Old 08-28-2015, 03:04 PM
  #56
TheRickster
My Feedback: (12)
I might go to 19X12 props in the future but right now the plane flies nicely in the 1/2 throttle range and is easy on the amp draw.. In the video I never went past 3/4 but do not expect much speed difference with the 10" pitch props at full throttle.. I never intended for the plane to be a racer persay. I wanted it to look like the RB as much as possible and present well in the air. If it will fly in the 80-100mph range it will do the full scale justice I think...
ID:	2117078   Click image for larger version
ID:	2117079   Click image for larger version
Old 08-28-2015, 03:09 PM
  #57
77chickenhawk
Kudos to you you did a good job
Old 08-31-2015, 05:04 AM
  #58
FlyerInOKC
FlyerInOKC's Avatar
Its a keeper alright!
Old 09-21-2015, 02:03 PM
  #59
TheRickster
My Feedback: (12)
Couple more flights in Sunday.. Some video..
https://www.youtube.com/watch?v=KKavOtcX8V4 https://www.youtube.com/watch?v=QiY_mkAKCVU
Old 09-22-2015, 12:20 AM
  #60
perttime
perttime's Avatar
Looks and sounds good!
There was something bothering me about the overall impression, though. Perhaps I felt a mismatch between speed and sound? Could you get about the same speed with lower RPM?
Old 09-22-2015, 03:24 AM
  #61
TheRickster
My Feedback: (12)
The sound is much different with the contra rotating propellers, and gives the audible illusion of a very high RPM sound. In reality even at 100% throttle the each motor RPM is less than 7000rpm.
Old 09-22-2015, 05:00 AM
  #62
JeffH
My Feedback: (43)
Does the rear prop have more pitch than the front prop?
Old 09-22-2015, 05:14 AM
  #63
TheRickster
My Feedback: (12)
Both props are 20x10. After each flight the mah usage has been within 150mah between the 2 packs which leads me to believe the current load to be about the same. With the setup as it is the battery temp is only warm and flight times are satisfactory. I am going to try some 19x12 props in the future..
Old 09-22-2015, 05:27 AM
  #64
JeffH
My Feedback: (43)
I ask because I researched doing this conversion awhile back to a Top Flite Mustang. Supposedly the rear prop needs more pitch since the air has now been accelerated by the front prop.
The pattern guys have done exhaustive testing on this with the 'contra-drive' system. Of course they use one motor and a gear box so differential current draw is not a concern.
Perhaps a 20x10 in the front and 19x12 in the rear. The half inch on each side would probably not be noticeable on the ground. In the air, you may notice a slightly different disc size on low fly by's.
I still have not ruled out doing this to my Byron's Mustang since it has a nice long engine compartment to put the motors and batteries in.
No matter what, you did a great job and I think its awesome!
Old 09-22-2015, 05:39 AM
  #65
TheRickster
My Feedback: (12)
I have researched both theory's on props. The other theory is that the front prop twists the air flow in a helical manner so the rear prop is actually entering the air that is rotating the opposite direction thus acting like a heavier pitch. Lots of theory involved and the distance between the front and rear props also comes into the factoring. Trouble is that there are not a lot of options in the tractor/pusher in a 3 blade configuration to test with...
Old 09-22-2015, 06:00 AM
  #66
JeffH
My Feedback: (43)
Yeah I had read that too.
The pattern guys look for the utmost in efficiency and custom made many props finding that sweet spot in pitch differential. Of course they were using two blade props which may present a whole new set of variables.
I agree that the 3 blade pusher prop selection is poor at best.
I had considered making a modular style like the Zinger but using Xoar blades since the Zingers have always been on the low end of the performance scale.
Old 09-22-2015, 06:08 AM
  #67
TheRickster
My Feedback: (12)
I agree on the Zinger being pretty low on the efficiency scale..lol. However it works well for me because it allows me to run a scale appearing diameter whereas if I were using a very good prop I would be forced to run a considerably smaller blade which would detract from the appearance to me..To me the thing that stood out on the Red Baron was the massive prop system and my goal was to replicate that first impression...
Old 09-22-2015, 06:14 AM
  #68
JeffH
My Feedback: (43)
You should contact xoar directly. I know that they have done custom sized tractor three blades for guys. Maybe they can do a pusher three blade to your specs.
Now you have my mind turning about doing a Miss Ashley II using my fuse and a scratch building a set of Lear Jet wings and tail like she had.
Old 09-22-2015, 06:27 AM
  #69
TheRickster
My Feedback: (12)
Miss Ashley II would be awesome!!! That was one of the prettiest birds to grace Reno in my opinion..
Old 09-22-2015, 06:38 AM
  #70
JeffH
My Feedback: (43)
She was a truly sexy airplane.
Old 09-22-2015, 06:54 AM
  #71
FlyerInOKC
FlyerInOKC's Avatar
The counter rotating props really make this model!
Old 09-23-2015, 05:21 PM
  #72
TheRickster
My Feedback: (12)
shots
ID:	2122026   Click image for larger version
ID:	2122027   Click image for larger version
ID:	2122028   Click image for larger version
ID:	2122029   Click image for larger version
Old 09-24-2015, 07:27 AM
  #73
FlyerInOKC
FlyerInOKC's Avatar
The Rickster, you need to post a photo here: http://www.rcuniverse.com/forum/rc-s...l#post12103699
Mike
Old 11-16-2015, 06:34 PM
  #74
TheRickster
My Feedback: (12)
Made the trek over to a Warbird meet in La.. Hung out with a great bunch of guys and managed a "Pilots Choice" award to boot..
ID:	2130982   Click image for larger version
ID:	2130983   Click image for larger version
ID:	2130984   Click image for larger version
ID:	2130985   Click image for larger version
ID:	2130986   Click image for larger version
ID:	2130987   Click image for larger version
ID:	2130988   Click image for larger version
Old 11-17-2015, 05:55 AM
  #75
FlyerInOKC
FlyerInOKC's Avatar
Congrats! It just proves we knew what we were talking about when we said it was fantastic!
