Reload this Page >
Pitts S1-S by EMHW
Pitts S1-S by EMHW
Old 04-26-2015, 08:25 PM
  #4751
John_M_
John_M_'s Avatar
Looks nice Ace... I like the forward windshield frame.
John M,
Old 04-27-2015, 07:26 AM
  #4752
acerc
acerc's Avatar
The prop has been painted, decals added, and everything has been given two coats of clear. I will let all this set until this evening and then start assembly. I did gently slide the prop on to get a looksee.
ID:	2092510   Click image for larger version
Old 04-27-2015, 07:50 AM
  #4753
squirrly
Wow!! Nice Job on the prop. Man, she is going to be one beautiful bird!
Jeff
Old 04-27-2015, 07:55 AM
  #4754
squirrly
Rob, I was just looking at the canopy again. Besides it being really clear, how did you cut it so straight?
Jeff
Old 04-27-2015, 08:58 AM
  #4755
Cub Flyer Fresno
Cub Flyer Fresno's Avatar
Oh BABY! That looks NICE! Some how I've got to get out your way to see that thing in person. Or let me know when you are headed west, maybe I could arrange some sort of vacation, just not tell the wife why we're going.
Old 04-27-2015, 09:44 AM
  #4756
acerc
acerc's Avatar
Jeff
Thank you and I think so also.
Jeff
I used the laser for marking then a 18TPI metal cutting blade on the band saw. Then finished it up with a 500 grit just to help with cut scratch removal.
LOL! Doubt I'll ever be that far west..
Old 04-27-2015, 09:49 AM
  #4757
acerc
acerc's Avatar
I used a couple fasteners and some tape to hold things in place and it works very well with a nice tight fit at the joint. If you look where the canopy meets the windscreen you can just see the glass underside piece. That underside piece should keep the wind from getting in between the two.
The paint and clear coat is still a bit soft, un-cured, so I am going to wait until tomorrow to permanently bolt it all together.
Old 04-27-2015, 11:29 AM
  #4758
raptureboy
raptureboy's Avatar
How will you balance the prop? I usually just sand mine off if they are really bad or just clear coat the light side.
Old 04-27-2015, 11:34 AM
  #4759
FlyerInOKC
FlyerInOKC's Avatar
I was going to ask the same thing I assume the painted prop is for more than just display.
Old 04-27-2015, 11:43 AM
  #4760
acerc
acerc's Avatar
I will clear coat the backside of the light blade with lacquer. I have to balance the prop, the spinner, then the prop and spinner together.
Old 04-27-2015, 03:06 PM
  #4761
acerc
acerc's Avatar
It is amazing with all this bird has going on that the prop and spinner adds more appeal. On the canopy I need some brass strips for the mount, nuts and washers are to long, so I will thread the brass and then the canopy will be done.
I have started on the pilot, right now I have a tube being glue in from the body bottom to the top of the head. When that cures I can add the limbs, add some padding, and then clothes.
ID:	2092639   Click image for larger version
Old 04-28-2015, 06:43 AM
  #4762
acerc
acerc's Avatar
The canopy is bolted on and working, now to add the rest of the screws. I can not believe I am finally here, woo hoo!!
It is raining here and suppose to until Thursday so putting the wings on and loading it in the trailer will have to wait a couple days.
Old 04-28-2015, 07:09 AM
  #4763
acerc
acerc's Avatar
Here is a look with Jacquie in the cockpit. There is a lot of work to do on the body but I think it fits nicely.
ID:	2092800   Click image for larger version
Old 04-28-2015, 07:30 AM
  #4764
FlyerInOKC
FlyerInOKC's Avatar
Can't wait to see how the pilot comes out!
Old 04-28-2015, 07:53 AM
  #4765
Melchizedek
Melchizedek's Avatar
This is just awesomeness Robert.
Well deserved joy near the end of the journey.
Kevin
Old 04-28-2015, 09:01 AM
  #4766
squirrly
Its a beauty!!! Great job Robert.
Old 04-28-2015, 09:39 AM
  #4767
John_M_
John_M_'s Avatar
You're on the straight and narrow now Ace, looking good... The pilot figure looks better under the new canopy, nice fit !!
The prop... all I can say is Wow, that came out nice!... if you do the same with the 3 bladed prop, its going to look even better.
John M,
Old 04-28-2015, 10:49 AM
  #4768
FlyerInOKC
FlyerInOKC's Avatar
John M,
Watch that straight and narrow stuff John! You'll spoil his Devil May Care Hotshot Stunt Pilot image!
Old 04-28-2015, 05:20 PM
  #4769
WacoNut
WacoNut's Avatar
Robert,
I tip my hat and bow to you. Awesome effort and result. I am sure you are proud and you should be. I am sure there will be plenty of guys drooling all over the thing when you take it to the field. I would love to be there for the maiden. If I just lived a few hundred miles closer.
Enjoy the ride!!!
Anthony
Old 04-28-2015, 06:47 PM
  #4770
acerc
acerc's Avatar
Thank you Anthony and everyone else, it has been a long and at time's drawn out road. I need to flex my thumbs a bit before the maiden for I have not been flying much in the last several months. But, the Eagle will be assembled, in the trailer, and returning home this week in preparations for flight. Hopefully in the next couple of weeks but as with the build I am not going to rush it, when I am ready it will get done.
Thank you to everyone for your support and bearing with me to the end.
Is their someone out there in RC land capable and willing to aid me in clothing Jacquie. I can't find anything in the size that is appropriate. I need a pair of pants, a turtle neck shirt, and would like a jacket. My sewing machine is toast so in order for me to make them I would have to replace it, find some patterns, learn how to do everything and right now I am burnt out on learning. And nothing has to be anywhere near perfect for most will be unseen fastened into the harness.
Thank you.
Old 04-28-2015, 07:17 PM
  #4771
squirrly
Rob, have you gone online to see if any of the Barbie clothes would fit. Even a drive to the toy store. I made my helicopter pilot out of a gijoe. I had to cut a portion of the body out but, the clothes still worked. Good luck.
Jeff
Old 04-29-2015, 06:03 AM
  #4772
FlyerInOKC
FlyerInOKC's Avatar
Anthony he already has a bunch of guys drooling over this airplane right here!
Old 04-29-2015, 06:30 AM
  #4773
acerc
acerc's Avatar
Jeff
Most dolls are to small, believe me, I have looked.
Old 04-29-2015, 07:53 AM
  #4774
John_M_
John_M_'s Avatar
Originally Posted by acerc
Is their someone out there in RC land capable and willing to aid me in clothing Jacquie. I can't find anything in the size that is appropriate. I need a pair of pants, a turtle neck shirt, and would like a jacket. My sewing machine is toast so in order for me to make them I would have to replace it, find some patterns, learn how to do everything and right now I am burnt out on learning. And nothing has to be anywhere near perfect for most will be unseen fastened into the harness.Thank you.
Ace if all else fails, try searching on line for "custom doll clothing seamstress"... you may find someone capable of making what you need.
Wish I could be more of assistance, but that's one area I just would not attempt to do... its funny, we're good with our hands and shape metal and wood into something marvelous, but put a needle and thread in my hands, and I haven't got a clue.
John M,
Old 04-29-2015, 08:01 AM
  #4775
FlyerInOKC
FlyerInOKC's Avatar
There was a lady here that did that kind of thing but she has been gone a long time. Check with a doll store there is a big market for custom clothes for antique dolls and that is where you will have the best luck. The antique doll clothes require a level of attention to detail equal to the detail of your airplane.
