Long EZ - St. Croix
Long EZ - St. Croix
Recently completed a 1/5 th scale Long EZ from St. Croix kit, electric conversion, 7 Lb all up using a G force .46 with a 14 x 6 prop. Balanced 1/8" FWD of plans C.G. as recommended in Text. control throws as recommended in instructions. the initial flight was conducted at full up stick. as soon as I reduced the throttle the nose dropped as there was nothing left. Have repaired and reset the canard with 2 deg more angle of incidence. changed C.G. to the exact plans point, added Gap cover on elevator. Second flightstarted climb from take off and would not respond ro full down stick. reduced throttle and nose came down immediately and would not respond to full up stick. Have not invested in second repair. wanted to gain some expert input. anyone have helpfull suggestions?
