Reload this Page >
Blohm & Voss BV-138 Sea Dragon 1:8 scale
Old 03-13-2014, 08:52 AM
  #101
splinterz25
splinterz25's Avatar
OKAY MARTIN AND ALL...I made the changes to my incidence meter raised it
by 1 1/2" I had some black plastic lying around that happened to match the meter.
I sliced some 3/4" strips and making sure the were both parts of the meter were the same size then I glued them up.
Then it was on to the changes to the planes incidence; with some fanagueling and luck I was able to get a 5/16 carbon fiber tube into the aft section where I wanted it.
Next I made a piece to capture the carbon rod and lock on to the fuse while holding the aft end of the center section of the wing to the correct height.
I've raised the aft end 5/8" to bring the wing to 3 degrees incidence.
I also cut 1 1/2" x 1 1/2" pieces of balsa w/ a 5/16" hole drilled in them to hold the carbon fiber tube.
Nothing is glued yet; also I've made it so the center section can still come out so I'll be able to have it on the bench while building the wing tips, this will be better for lining up the wing tubes and angles of ribs #6.
Once I'm sure this is where I want this to be set I glue the carbon tube in place; this will make it more rigid but I may still but a 1/8" x 1/2" spruce stringer over the flap hing line to be sure.
Check it out,
ID:	1977676   Click image for larger version
ID:	1977677   Click image for larger version
ID:	1977678   Click image for larger version
ID:	1977679   Click image for larger version
ID:	1977680   Click image for larger version
ID:	1977681   Click image for larger version
ID:	1977682   Click image for larger version
ID:	1977684   Click image for larger version
ID:	1977685   Click image for larger version
ID:	1977686   Click image for larger version
Old 03-18-2014, 02:55 PM
  #102
splinterz25
you should check out my thread on RCSB.
http://www.rcscalebuilder.com/forum/...69&PN=1&TPN=44
The other thing you may not see or notice is the props/ engines on the booms are forward of the center engine; on this model it's about 3/4" back from the booms engines/ props.
Gene points this out on the drawings; I'll post a photo of his words.
Two of those photos show all three engines w/ three bladed props it may have had to do w/ cockpit noise and vibration so they used a four bladed prop?
Okay I got back into it today before moving on I wanted to get the aft stringers cut in; I changed my mind and added a 1/4" x 1/4" stringer to each side along the top of the flap hinge line.
While I had the center section of the wing off on the bench I sanded all the ribs flush w/ the main stringers, touched up any places that needed it and added glue where it was needed.
I also cut and sanded all of the ribs LE, and cut the LE sub edges; these sub edges and the stringers will be glued in place once I have the center section just where I want it, after many measurements.
The other thing I did was the aft edge had to be lifted out of the locking groves that Gene had me cut in ribs # 1 so I've made another lock that will slide around the fuse formers besides the one that holds the carbon tube, and would still like to get one more set if possible.
ID:	1979406   Click image for larger version
ID:	1979407   Click image for larger version
ID:	1979408   Click image for larger version
ID:	1979409   Click image for larger version
ID:	1979410   Click image for larger version
ID:	1979411   Click image for larger version
ID:	1979412   Click image for larger version
ID:	1979414   Click image for larger version
ID:	1979415   Click image for larger version
ID:	1979416   Click image for larger version
Old 03-19-2014, 04:05 PM
  #103
splinterz25
Okay today what I did was before I cut the formers for the 24oz tank to fit I wanted to come up w/ away for the firewall and all the formers to get tied together; but I wanted to keep it strong and light.
Here's what I've come up w/ so far I made sides out of 1/16" 9 ply they will be recessed into the formers and firewall; I'm sure I'll have to do some bracing but this is much lighter than using spruce stringers, the formers & firewall still need to be notched to accept the sides.
This also will put the fire wall at 2 degrees upward thrust; the aft section of the sides will be extended and will tie into former #13, then because there in set the 1/8" balsa sheeting will cover over making it even stronger.
Check it out I think you can tell where I'm going w/ this,
Bruce
ID:	1979617   Click image for larger version
ID:	1979618   Click image for larger version
ID:	1979619   Click image for larger version
ID:	1979620   Click image for larger version
ID:	1979621   Click image for larger version
ID:	1979622   Click image for larger version
ID:	1979623   Click image for larger version
ID:	1979625   Click image for larger version
ID:	1979626   Click image for larger version
ID:	1979627   Click image for larger version
ID:	1979628   Click image for larger version
ID:	1979629   Click image for larger version
Old 03-20-2014, 11:58 AM
  #104
splinterz25
Okay the fuel tanks is cut in and an aft mount made and installed I'll make the front one when I get closer to sheeting the sides and mounting the engines.
I've also finished the sides groves & splines as well as an dove tail extension on each side back to former #13.
When these pieces are all locked together you can't believe how strong the whole top becomes w/ out any glue
The 2 degree up thrust I was trying to incorporate into the firewall seems to have straightened it self out some how?
But I could still change it if need be or just shim the engine mounts.
I'm getting quite a few people telling me not to do up thrust ; but I know a triple engine plane is set up different than a twin or single also this is a water plane and needs to get on step to get up out of the water.
Check the days progress,
Bruce
ID:	1979878   Click image for larger version
ID:	1979879   Click image for larger version
ID:	1979880   Click image for larger version
ID:	1979881   Click image for larger version
ID:	1979882   Click image for larger version
ID:	1979883   Click image for larger version
ID:	1979884   Click image for larger version
ID:	1979886   Click image for larger version
ID:	1979887   Click image for larger version
ID:	1979888   Click image for larger version
ID:	1979889   Click image for larger version
ID:	1979890   Click image for larger version
ID:	1979891   Click image for larger version
ID:	1979892   Click image for larger version
ID:	1979894   Click image for larger version
ID:	1979895   Click image for larger version
ID:	1979896   Click image for larger version
ID:	1979897   Click image for larger version
Old 03-20-2014, 08:00 PM
  #105
splinterz25
I'm looking at the machine gunners position an arch needs to be made for the sheeting to follow.
The aft end of the fuse really falls off fast down to the turret.
Bruce
Old 03-21-2014, 01:55 PM
  #106
splinterz25
Okay guys I started on the aft machine gunners station today.
I'm making this whole section so it can come out in one or two pieces and go back easily when the wing center section goes on for the final mounting.
I was going to make the top ribs in spruce but have changed my mind they will now be made out of 1/8" light ply.
I'm going to cut most of the way through the top of former #14 so when time comes to remove that part it will be easy w/ a few Dremal cuts.
Bruce
ID:	1980234   Click image for larger version
ID:	1980235   Click image for larger version
ID:	1980236   Click image for larger version
ID:	1980237   Click image for larger version
ID:	1980238   Click image for larger version
ID:	1980239   Click image for larger version
Old 03-21-2014, 11:12 PM
  #107
splinterz25
Originally Posted by Martin5465 View Post
Bruce, what "whole section" is going to come out? Are you saying the aft part of the nacelle will be removable? I might have missed something here.................
Martin the parts I'm making now will all be removable until I'm ready to glue in the center of the wing, I had to go out this evening but had the idea fresh in my mind so when I got home I stayed up and keep on working.
All of these parts lock in place w/ out glue just a few clamps
check it out,
ID:	1980366   Click image for larger version
ID:	1980367   Click image for larger version
ID:	1980368   Click image for larger version
ID:	1980369   Click image for larger version
ID:	1980370   Click image for larger version
Old 03-25-2014, 10:23 AM
  #108
splinterz25
Well I've not been well since the weekend and I'm not sure what's wrong but I couldn't even focus on anything for length of time until today.
So I went down stairs and did some simple things, I need more of the fiberglass sheet I used for the hinges on the rudders; so I thought I would lay up some of that.
This is also a test to see how the resin is working because it's snowing again here in Maryland.
I've also made some more parts to connect the sides I was working before; these will
make the sides one piece and they'll be easier to install when I'm ready.
The other thing is the slow boat from China arrived w/ the micro servo; it only took 25 days and Hobby King ing up my bank account to get it, I've not had a chance to try it yet?
No photos this time not much to show,
Bruce
Old 03-25-2014, 02:11 PM
  #109
splinterz25
I finished making my fiberglass sheeting for the rest of my hinges; and the resin works well but this is the fast dry kind.
I ran a test on the turnigy micro servo and it seems very strong no gidders or humming; it even comes w/ a metal horn/ arm.
Still going to run a few more test though.
Then I put a few new pieces on the center section so it can come off in one piece.
I also bent some 1/8" balsa to see how it will bend; to do this I soak it in almost boiling hot water for 10 min, my tap water in my house is this hot.
I bent it around a can w/ the correct shape and rubber banded in in place let it dry a few days; looks really good it's the whole top radius, all that is needed is to add some flat sides to take it all the way to the bottom.
This is good no need for planking w/ all of the glue mess and w/ 1/8" thick balsa and my frame work no need for stringers either.
If I can bend this I should be able to do the same w/ the booms only w/ a longer piece.
I'll make a tube / cylinder w/ a bottom & top to hold a full sheet fill it w/ very hot water; I'm not worried about raising the grain here it's 1/8" thick and can be sanded w/ little worries of going through.
Hope to do more tomorrow,
Bruce
ID:	1981388   Click image for larger version
ID:	1981389   Click image for larger version
ID:	1981390   Click image for larger version
ID:	1981391   Click image for larger version
ID:	1981392   Click image for larger version
ID:	1981393   Click image for larger version
ID:	1981394   Click image for larger version
ID:	1981396   Click image for larger version
ID:	1981397   Click image for larger version
ID:	1981398   Click image for larger version
ID:	1981400   Click image for larger version
ID:	1981401   Click image for larger version
ID:	1981402   Click image for larger version
ID:	1981403   Click image for larger version
ID:	1981405   Click image for larger version
ID:	1981406   Click image for larger version
ID:	1981407   Click image for larger version
Old 03-25-2014, 06:29 PM
  #110
splinterz25
Feeling much better I should make some headway tomorrow.
Does any body have a link for a slimline / wing servo w/ good power that also has a good track record that's not $100 ea.
It has to be just at or thinner than 1/2" to fit
Bruce
Old 03-25-2014, 07:15 PM
  #111
splinterz25
IS ANY BODY EVEN FOLLOWING THIS THREAD HERE ON RC SCALE AIRCRAFT RCU?
Bruce
Old 03-25-2014, 11:23 PM
  #112
jrtal
Me!!
John.....
Old 03-26-2014, 04:34 AM
  #113
splinterz25
Originally Posted by jrtal
Me!!
John.....
Great John welcome on board.... There just hasn't been any questions or comments so I wasn't sure it was worth posting here anymore.
Bruce
Old 03-26-2014, 02:21 PM
  #114
splinterz25
This is what I've just spent the day working on was the firewall angle; it's NOW 2 degrees, I had to make changes to my finger joints and remove the triangle glue blocks.
SO IT'S LIKE THIS... the wing is set at 3 degrees incidence off the center line of the FUSE ; the center engine is set at 2 degrees up thrust off the center line of the FUSE, this still may have to be changed once flown.
The booms engines ARE SET AT 0 DEGREES INLINE w/ the center line of the FUSE.
Getting this right took me much longer than I thought it would today; but I was able to get the other pieces parts drilled and glued in place on the temp. removable center section.
I'm going to eat something and head back down stairs; I want to look at cutting in the air intake into the bottom portion of the center firewall.
There should be a really nice natural air flow through the center section and out the gunners station.
I know water is going to get in this planes hull so I'm already looking a bilge pumps; and will run 2 - 6V nicad batteries on this plane, I don't want lithos.
Check it,
ID:	1981658   Click image for larger version
ID:	1981659   Click image for larger version
ID:	1981660   Click image for larger version
ID:	1981661   Click image for larger version
ID:	1981662   Click image for larger version
ID:	1981663   Click image for larger version
ID:	1981664   Click image for larger version
Old 03-27-2014, 10:38 AM
  #115
splinterz25
So my brain has started working again and I have been thinking
about what kwik said awhile back about getting to the fuel tanks if there's a leak.
There will be a hatch to get to the hoses but there would be no way to change out the tank; so I came
up w/ a new plan, there will be a sub plate that the firewall will bolt to w/ T-nuts, the center engines set up is not that hard but the booms will be a bit of work; better now than later though.
I've also came up with the idea for the air intake under the center engine to try and keep water from getting in as much; on the scale plane there's a horizontal louver inside the intake if I can make this close when flaps are down this should help, once in the air flaps up it will open giving great air flow.
The center engine gets two intakes, the booms only one I'm still working on the booms out going air; looking at the scoops under the booms for that.
The removable center truss system is now all glued together and all the formers notched to fit.
There's still so much to do on this center section; there is a scale hatch on the top in front of the
machine gunners station that will be great for the electronics to keep them up high away from water.
Then there's the flaps these are going to be very tricky there's in board and out board flaps; the in board are easier than the out board because of the removable wing tips.
I'f I can, there's a small section of the out board flaps that is under the boom and remains when the wing tips are removed; this section either will have to move w/ the inboard servo or when I plug in the wing tip I have a tube & dowel line up as well.
This is one of those parts that would get broken very easy if this is not done well.
And I still have to finish boom two's aft end. [:P]
I love this stuff I never stop thinking []
ID:	1982033   Click image for larger version
ID:	1982036   Click image for larger version
ID:	1982039   Click image for larger version
ID:	1982042   Click image for larger version
ID:	1982044   Click image for larger version
ID:	1982045   Click image for larger version
ID:	1982046   Click image for larger version
Old 03-31-2014, 05:42 AM
  #116
splinterz25
Hi everybody... I didn't do anything on the plane this weekend but think about the next steps.
I want to have a really good look at the Flaps look and position there's very little info on these.
While looking for info on these I found out the AILERONS, ELEVATOR & RUDDERS are tinplate & fabric; FLAPS are all tinplate.
The flaps have an internal hinge/ turn axle like rudders and the inner set deflect 30 degrees and the outer 60 degrees; the other control surfaces are all just under 30 degrees deflection.
The Aileron hinges and control arms are external but I can't find any close up shots to make duplicating them easy?
For the flaps I would like to have one servo for each side, run the inner and outer and still have the wing tip easily removed.
So today I'll start by removing the center section of the wing and put the fuse to the side; while I'm figuring this out I'll also work on boom #2 and bring it up to where the first one is.
Things will slow down now for a bit because there's very little to go on I'll be making it up as I go
trying to copy other German planes when I can't find any info on this one.
Control surfaces
Horizontal Stab and elevator
Total area &n bsp; &n bsp;16,56 m2 &nbs p; &nbs p; (src: Handbuch)
Depth & nbsp; & nbsp; 2,45 m ; ; (src: Handbuch)
Horizontal stabilizer:
Area &n bsp; &n bsp;10,67 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 7,20 m ; ; (src: Handbuch)
Depth & nbsp; & nbsp;1,54 m ; ; (src: Handbuch)
Attitude against horizontal &n bsp; +5? +2? &nb sp; &nb sp; (src: Handbuch)
-4?
Material &nbs p; &nbs p; Tin-plate & nbsp; & nbsp; (src: Handbuch)
Elevator:
Total area &n bsp; &n bsp;5,89 m2 &nbs p; &nbs p; (src: calculated)
Area behind turnaxle, including trimmrudder 4,34 m2 &nbs p; &nbs p; (src: Handbuch)
Counterbalance area &n bsp; 1,55 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 7,00 m ; ; (src: Handbuch)
Depth with counterbalance part &n bsp;0,915 m ; ; (src: Handbuch)
Depth without counterbalance part 0,675 m ; ; (src: Handbuch)
Position of turnaxle from backward edge 27,5 % ; ; (src: Handbuch)
Deflection upwards ; 29? &n bsp; &n bsp; &n bsp; (src: Handbuch)
Deflection downwards &nb sp; 27? (src: Handbuch)
Material &nbs p; &nbs p; Tin-plate and fabric (src: Handbuch)
Trimming rudder:
Area &n bsp; &n bsp;0,348 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 2,05 m ; ; (src: Handbuch)
Depth to turnaxle &nbs p; 0,15 m ; ; (src: Handbuch)
Material &nbs p; &nbs p; fabric &nbs p; &nbs p; (src: Handbuch)
Vertical Stabs and rudders
Total area &n bsp; &n bsp;12,60 m2 &nbs p; &nbs p; (src: Handbuch)
Vertical stabilizer:
Area &n bsp; &n bsp;2x 4,12 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth (height) &nbs p; 2,70 m ; ; (src: Handbuch)
Depth midheights (length) &nbs p; 1,53 m ; ; (src: Handbuch)
Vertical rudders:
Area behind turnaxle, including trimmrudder 2x 1,59 m2 &nbs p; &nbs p; (src: Handbuch)
Counterbalance area &n bsp; 2x 0,59 m2 &nbs p; &nbs p; (src: Handbuch)
Depth with counterbalance (length) 0,95 m ; ; (src: Handbuch)
Depth without counterbalance (length) 0,65 m ; ; (src: Handbuch)
edge, midheights &n bsp; 28 % ; ; (src: Handbuch)
Deflection inwards ; 29? &n bsp; &n bsp; &n bsp; (src: Handbuch)
Deflection outwards &nbs p; 29? & nbsp; & nbsp; & nbsp; (src: Handbuch)
Trimming rudders:
Area &n bsp; &n bsp;2x 0,143 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 1,425 m ; ; (src: Handbuch)
Depth (length) &nbs p; 0,100 m ; ; (src: Handbuch)
Ailerons
Total area: & nbsp; & nbsp;2x 3,07 m2 &nbs p; &nbs p; (src: calculated)
Area behind turnaxle &nbs p; 2x 2,30 m2 &nbs p; &nbs p; (src: Handbuch)
Counterbalance area &n bsp; 2x 0,77 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 5,06 m ; ; (src: Handbuch)
Depth with counterbalance (length) &nbs p; 0,64 m ; ; (src: Handbuch)
Depth without counterbalance (length) 0,48 m ; ; (src: Handbuch)
edge of wing, inner: 11,7 % ; ; (src: Handbuch)
edge of wing, outer: 18,5 % ; ; (src: Handbuch)
Deflection downwards &nb sp; 21? (src: Handbuch)
Deflection when used as flaps (14?)
upwards ; 39? &n bsp; &n bsp; &n bsp; (src: Handbuch)
downwards &nb sp; 11? (src: Handbuch)
Trimming rudder (only on the left side):
Area &n bsp; &n bsp;0,089 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 1,05 m ; ; (src: Handbuch)
Depth (length) &nbs p; 0,085 m ; ; (src: Handbuch)
Flaps
Total area: & nbsp; & nbsp;9,58 m2 &nbs p; &nbs p; (src: Handbuch)
Inner:
Area &n bsp; &n bsp;2x 1,87 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth&nb sp; &nb sp; 2,550 m ; ; (src: Handbuch)
Depth & nbsp; & nbsp; 0,726 m ; ; (src: Handbuch)
Max deflection &n bsp; 30? ; ; ; (src: Handbuch)
Outer:
Area &n bsp; &n bsp;2x 2,92 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth&nb sp; &nb sp; 4,43 m ; ; (src: Handbuch)
Depth (length), mid &nb sp; 0,66 m ; ; (src: Handbuch)
Max deflection &n bsp; 60? ; ; ; (src: Handbuch)
Ailerons:
Aileron-defl ection as flap &n bsp;14? ; ; (src: Handbuch)
Old 04-01-2014, 09:13 AM
  #117
splinterz25
I'm still working on the Flaps today I think I've got these figured out
But I can't find any examples of the aileron hinges; they look like offset flap hinges mounted on top of the wing this doesn't make since to me.
Or they could be a cantilevered hinge mounted on top? I'm really not sure what they did here
It will be a while before I need to do this but while I was looking at the flap hinges thought I would look for these also.
Any thoughts about these hinges guys?
Bruce
Old 04-02-2014, 11:16 AM
  #118
splinterz25
Well I've made a mock up hinge and gotten the first part of mounting the flap installed.
The real hinges will be either fiberglass w/ a brass bushing or 1/8" AG ply w/ brass bushing these are split flaps but there inset; Gene doesn't show this on his drawing, the way I've found this out was looking at the plastic model.
The aft edges is inset flush like the rest of the flap.
Here's where I'm at so far, it's slow going there's nothing on the drawings about any of this; So I'm making it up as I go.
ID:	1983508   Click image for larger version
ID:	1983509   Click image for larger version
ID:	1983510   Click image for larger version
ID:	1983511   Click image for larger version
ID:	1983512   Click image for larger version
ID:	1983513   Click image for larger version
ID:	1983514   Click image for larger version
ID:	1983516   Click image for larger version
ID:	1983517   Click image for larger version
Old 04-03-2014, 10:05 AM
  #119
splinterz25
Okay some progress was made today on the actuator arms; Martin had asked about using a bushing or bearing I've sorta used both w/ this setup.
I made the arms / horns continue out like the ribs on the flap and glued one in between; there made out of that fiberglass sheet I made a few days ago, even though there's a bolt going through the fiberglass and there won't be much ware I still add in a small piece of brass tube for the bolt to go through then into and through the ball link which acts like a bearing.
These are just 2-56 pushrods & ball links and once I gt the servo in the correct place
I'll cut the rod and solder on a 2-56 brass coupler / clevis or ball link.
ID:	1983687   Click image for larger version
ID:	1983688   Click image for larger version
ID:	1983689   Click image for larger version
ID:	1983690   Click image for larger version
ID:	1983691   Click image for larger version
ID:	1983692   Click image for larger version
ID:	1983693   Click image for larger version
ID:	1983695   Click image for larger version
Old 04-14-2014, 09:45 AM
  #120
splinterz25
I know you guys were wondering where I went
I'm still working on my yard/ garden/ fencing projects hang in there I'll be back soon.
Bruce
Old 04-16-2014, 06:25 PM
  #121
jack steward350
My Feedback: (7)
I am watching this thread. I find it pretty fascinating and such a unique subject. I think a lot of folks may be bit in awe of the whole process....like I said fascinating!
Old 04-24-2014, 12:29 PM
  #122
splinterz25
Thank you Jack....YES THIS IS UNIQUE I'm guessing that's why so little response?
I'll be back on it in a few weeks the weather is perfect for me to get all my out side work completed before it gets really hot
I'm currently building fences,a sitting bench, and getting ready to start building a picnic table; I'll post some photos soon.
Bruce
Old 05-16-2014, 07:50 AM
  #123
splinterz25
I've now finished my spring yard work and should be back on the build very soon,
after some cleaning up of my shop
Bruce
Old 06-14-2014, 07:29 PM
  #124
splinterz25
I moved the fuse into the building room yesterday and I'm going to work on getting the wing mid section up there next week.
Also I bought the parts to build my Vac-U Form box I hope to start building on that tomorrow or Monday.
Bruce
Old 06-14-2014, 08:27 PM
  #125
Boomerang1
Boomerang1's Avatar
I've been following, look in from time to time!
Mostly have a peek on RCSB though.
John.
