1/4 CUB landing gear ?
My Feedback: (19)
I don't like to ask this sort of question but have no source for the answers otherwise. I've done the searches but the available info isn't very conclusive. Here goes .....
Which 1/4 scale landing gear appears to be the most durable over the long haul .... the Robart or the one from TheCubNut? All opinions are welcome and with luck this won't be a product bash. This will be going on a highly modified SIG CUB with a slightly wider than normal fuselage at 6 5/8".
I am not sure of the gear from TheCubNut as I had never heard of them.
I had the Robart gear on my 1/4 Cub and they performed very well. A guy named Wallace used to sell Cub gear, they were supposed to be a little more scale than the Robart gear but were not as strong.
The Robart gear uses fairly thick walled chrome molly tubing. It is a very stout gear. I cannot remember how wide the stock fuse is on the Sig Cub so I do not know what the width change will do.
Good Luck!!
Anthony
Good Luck!!
Anthony
My Feedback: (19)
Good Luck!!
Anthony
Good Luck!!
Anthony
I just put a Robart Cub landing gear on a 1/4 scale Sig Cub... my fuselage is 6 5/16 " inches wide... after installing the gear the pivot points for the gear arms are right at the radius / corners of the bottom of the fuselage... I mortised the gear mounts down into the bottom of the fuse about 1/8" of an inch to bring the pivot points closer to the bottom surface (to help close up the gap between the arm and fuselage)... your fuselage is about 5/16" of an inch wider than mine... so your pivot points (mounts) will be about 5/32" of an inch inside of where mine is (on each side) which probably won't be that noticeable.... you maybe able to stretch the front bungee brace a bit to get a little more width... the other "wider" cub gear they sell which is for the BalsaUSA cub, will probably be way too wide, like over an inch.
Horizon hobbies sells replacement parts for their 1/4 scale Cub; their cub landing gear set its like $85 bucks... it looks very similar to the the Robart design, but not as robust... it maybe wider than the robart cub gear.
John M,
John M,
Truckracer, I think you are more than capable of widening the 1/4 scale gear. I have done it and it was not that big of a deal. Here is how, in the pic there is a black line, cut the tube in half there. Get a piece of brass tube that fits inside that tube, cut it just a bit shorter that the total of the cut tube, flux the brass tube and re-assemble, then set in place on fuse at the proper width, then solder the joint.
My Feedback: (19)
No problem Truckrace, glad I could help... you probably won't have to modify the gear... 5/32 of an inch (per side) isn't much to worry about... when I look down the side of my fuselage from the wing saddle, the gear sticks out past the fuse, about an 1/8 of an inch.... so yours should be almost flush with the fuse side.
John M,
John M,
CA
Yes, Thecubnut is Wallace.
Seriously considering a pair for my cub!
http://www.cublandinggear.com/Page_2_34LV.html
