Cub On Floats
Cub On Floats
I purchased a balsa/plywood Cub on floats at the Expo swap this weekend. She's built for nitro and has a 60 inch span. Does anyone know how I could tell who the kit manufacture was? I need a windshield and a engine cowl at minimum. Also need an engine or convert to electric but thats rather easy.
Thanks in advance!
Joe
Thanks in advance!
Joe
More than likely a 40 size cub. Take measurements of the fuselage too and post that with the pictures.
Even if you can't ID the kit the cowl from a current kit or arf should fit along with the window/windshield kit. If you want to make your own windshield all you need is a piece of clear plastic used on display boxes for toys and electronics. Not the flimsy stuff but a bit heavier. Scissors, a heat gun and some time and it can be made.
Here's some pics of mine, landing gear is obviously different, but I think it's the same plane.
http://www.rcuniverse.com/forum/crash-rebuild-96/11386234-cub-windshield-bottle.html
The fuselage is ~ 34 inches long from the firewall to the rudder trailing edge. She weighs ~ 4 lbs w/o an engine. It looks like it matches up with the Eflight 25 Cub except for the IC vs. electric powerplant. Did Horizon offer these in a IC version in the past?
Tx,
Joe
Tx,
Joe
