Reload this Page >
Scale Modifications to the 1/3 Scale Balsa USA Sopwith Pup
Old 12-21-2014, 02:52 PM
  #101
AndyF
AndyF's Avatar
Originally Posted by BobH
I has a similar idea. they do make a tool that creates goves in sheet metal. It works very much like you described. The problem is that all the wheels they supply make the grove too large for our purposes.
Plus I don't know how difficult it is to keep the cowl aligned if working alone?
The crip method does work. I made the grove deep only to discover that it made adding the side parts so that it all fit around the wood parts was a bother.
The JW kit's wood is sized to have the top and side bits screwed into place. The cowl is then attached to a fixture in the front. This becomes a butt joint and not overlapping like the Full scale is.. So.. i had to make the grove in the wood and reduce the diameter of the whole front for everything to fit..
I see what you mean about having to reduce the wood parts. That is a good thing to know. The other thing I thought about doing was creating a rounded die of some sort and then use a hammer and a chisel to tap the groove into it.
Where did you get your Evo engine?
Andy
Old 12-21-2014, 03:19 PM
  #102
BobH
Andy,
got the engine from Horizon. One good thing about the simple tool is tha it's easy to get a nice straight line around the cowl.
Old 12-23-2014, 06:42 AM
  #103
BobH
This particular kit doesn't "do" scale per se. The aft section of the fin and the fore section of the rudder use flat hinges with pins. The TE and LE edges are also flat. So some modification is in order. The TE edge of the fin has the ply removed so I can fit a 5/8 dowel in place to accept Robart hinges. Similar will be done for the LE of the rudder.
The FS plane uses only two hinges for the rudder. I may go that route or add one more just to be safe..
Old 12-23-2014, 07:03 AM
  #104
AndyF
AndyF's Avatar
That's nice Bob. I've gone done a rabbit trail with my lathe so I haven't been working on my pup for a couple of weeks.
Today I plan to finish the new instrument panel. The compass is giving my cause for thought because I made the housing out of aluminum I am looking for a way to attach the mounting brackets to the housing. I have just about settled on using steel epoxy to glue them to the sides of the housing. Once I do that, I might put a small screw through the bracket into the housing to make sure it doesn't come lose.
I have decided to redo the tail surfaces on my pup too. The BUSA is not to scale. I'm not going to use metal to outline the surfaces but I am going to add a symmetrical airfoil to the horizontal stabilizer and I am going to taper the elevator and the rudder to make them more scalelike.
Andy
Old 12-24-2014, 09:45 AM
  #105
AndyF
AndyF's Avatar
I finally got back to working on my Pup last night. I added a spacer to the back of the instrument panel and cut out the holes to add some depth to the gauges. I also painted the inside of the opening black for each or the instruments. Today, I'll attach the gauge faces and create the needles. My intent is to create layers so that when you look at the instrument you get the impression that you are looking a a real instrument. The altimeter actually had two dials the top one that moved so the pilot could set the altitude for the airfield, and the inner dial that did not turn. I am thinking of creating that effect. We'll see if it turns out.
Merry Christmas everyone! Thanks for reading this.
Andy
Old 12-24-2014, 10:19 AM
  #106
capnpaul
capnpaul's Avatar
Thank you-Andy. Really enjoying you build and Merry Christmas to you and your family, all the best for 2015!!
Old 12-24-2014, 11:52 AM
  #107
BobH
Andy.
Merry Christmas and Happy New Year to you too
Old 12-25-2014, 12:54 PM
  #108
AndyF
AndyF's Avatar
I worked a little on my Pup last night.
I added filler pieces to the back of the panel to make the gauges sit a little deeper in the panel and I painted the openings
I cut the center out of the altimeter using a homemade brass hole punch. In the second picture I laid the two faces on top of each other to see the effect.
I mounted the gauges. This picture is a closeup of the altimeter
This last picture I tried the bezels to see how it looked. Next I have to make the pointers and cut out the plastic for the gauge glass.
More later.
Andy
Name:	New Panel Testing Bezels.JPG
ID:	2057697   Click image for larger version
Name:	Two Layer Altimeter Mounted.JPG
ID:	2057698   Click image for larger version
Name:	Faces Mounted.JPG
ID:	2057699   Click image for larger version
Name:	Two layer Altimeter.JPG
ID:	2057700   Click image for larger version
Name:	Center Removed from Altimeter.JPG
ID:	2057701   Click image for larger version
Name:	New Panel Front with painted openings.JPG
ID:	2057702   Click image for larger version
Name:	New Panel Back.JPG
Old 12-25-2014, 08:38 PM
  #109
AndyF
AndyF's Avatar
I worked on the instrument panel today and finished the three main gauges.
First I bent the indicators using my Z-Bend pliers and then I cut each one to length for each size of instrument. Then I painted each one white.
Then I test fit and positioned each indicator and glued them in place by adding a drop of glue to the back side of the indicator.
Next I drilled the holes and test fit the bezels. Finally I cut out the plastic and installed the glass for each gauge and screwed everything down.
Merry Christmas to all and to all a good night!
Andy
Name:	Plastic lenses installed.JPG
ID:	2057764   Click image for larger version
Name:	Test fitting bezels.JPG
ID:	2057765   Click image for larger version
Name:	Gluing indicators.JPG
ID:	2057766   Click image for larger version
Name:	Test fitting indicators.JPG
ID:	2057767   Click image for larger version
Name:	Painting Pointers.JPG
ID:	2057768   Click image for larger version
Name:	Bending pointers.JPG
Old 12-26-2014, 07:58 AM
  #110
R/C Art
My Feedback: (38)
R/C Art's Avatar
Andy, the gauges look really good! This is a very interesting thread.
Old 12-26-2014, 09:39 AM
  #111
BobH
Yes I agree good looking Gage's. Nice work, again.
Old 12-27-2014, 08:35 AM
  #112
Propworn
Propworn's Avatar
Good thinking on positioning the needles. People are going to be looking in the cockpit when the model is on display and not running so it would be correct for rpm to be 0 and airspeed also. Good job!!!
Old 12-27-2014, 12:10 PM
  #113
AndyF
AndyF's Avatar
Thanks! I kept going round and round with where to set the needles and then figured that people would be viewing most often when it was sitting on the ground with the engine would be off. I set the altitude to about 500 feet which is close for here in Fort Wayne.
Andy
Old 12-27-2014, 04:49 PM
  #114
Karp050555
I think you should install an 8 track player in the dash.
Old 12-27-2014, 05:19 PM
  #115
BobH
Andy,
The dial hands look good just as they are. sadly hardly any one even notices stuff like that .. Bummer!!!!!
Old 12-27-2014, 08:09 PM
  #116
AndyF
AndyF's Avatar
Andy,
If I get it done in time to take it to Toledo in April for the Weak Signals show, the judges will notice.
Andy
Old 12-28-2014, 07:32 AM
  #117
Propworn
Propworn's Avatar
You would be amazed at the stuff everyone notices. My Buddy entered his Otter at Toledo and there were many comments on the pencil in the pilots pocket, the miniature folded map on the dash, the fish and sea weed in the simulated water in the diorama. It’s the little details that amaze and entertain the observer.
Old 12-28-2014, 07:56 AM
  #118
BobH
I remember the otter. It was excellent!
I entered my SE5a one year. I don't think, actually I'm pretty sure, it was never moved so you could see the interior at all. Lol
Andy I hope you get your pup finished in time.
Old 12-28-2014, 09:17 AM
  #119
AndyF
AndyF's Avatar
Thanks Bob! If not this year, there is always 2016.
I have taken some very good cockpit shots at Toledo by using my cell phone camera. What year did you enter your SE5A? if it was in the last 5 or 6 years, I might have a picture of it.
Andy
Old 12-28-2014, 12:26 PM
  #120
BobH
Andy, I was entered in 2006.. wow does time fly!
ID:	2058462   Click image for larger version
Old 12-28-2014, 04:23 PM
  #121
AndyF
AndyF's Avatar
That's a beauty Bob! I didn't move to Fort Wayne until 2007 and my first show was in 2009. Toledo is about an hour and 40 minutes from here so we usually go up on Friday and then again on Saturday.
What kit is that? I have a BUSA SE5A that I am customizing but I'm not going to go crazy like I did on the Pup.
Andy
Old 12-28-2014, 04:45 PM
  #122
BobH
Andy,
thank you. It's a Duncan Hutson kit. Proctor sold them and then Duncan closed up shop. I thin you can still get the kit parts from Traplet plans.
Old 12-29-2014, 10:18 AM
  #123
MRadu
MRadu's Avatar
Bob,
Nice SE5a. Is that ¼ scale and what engine? Did you fly it?
Andy,
Great work on the panel. Keep it up!
I'm just about to wrap up my ¼ scale scout "Pup" and my maiden flight is scheduled for the first of January!
I took the Pup to the field to run the engine.
ID:	2058714   Click image for larger version
ID:	2058715   Click image for larger version
ID:	2058716   Click image for larger version
ID:	2058717   Click image for larger version
Old 12-29-2014, 11:51 AM
  #124
AndyF
AndyF's Avatar
Originally Posted by MRadu
Andy,
Michael,
Thanks. Your Pup looks great. I love the detailing and the stitching on the wings. Your radial engine looks great too.
I hope you have good weather with low winds on the first.
Andy
Old 12-29-2014, 01:46 PM
  #125
BobH
The Se5a is 90% 1/4 scale flown with a Saito 150 engine. It flew well.
Andy, what do you plan to use for covering for your pup?
I may venture over to linen fabric. Or stits.. something like that. Linen is very nice and it feels great after its glued and doped on. VERY durable too. No wrinkles etc..
