building a cowl for the 87 span BATES mkv tempest,
My Feedback: (38)
I have searched many threads and i may be the first to attempt this insanity. the cowl
has two pieces , a top half and a lower half . will get some pictures if , the dang batteries in my camera dont
keep dying. ive got the top half almost done , the bottom half will be wack , because there are no stringer slots in the formers.
, i thought the sepp /uk temp cowl would fit , but its too pricey and its probly not the right size. along with my unemployment
depression , i may take up some added medisional beverage drinking durring this quest.
have a goody
have a goody
My Feedback: (38)
hi chad , this bates tempest v is a different animal , its a combination of an old plan and a new cad file
which spells mistakes everywhere, ive made progress, but its a ball buster. The sepp cowl is 100.00 british
plus shipping , way too pricey , but , yea , send the dimensions. i know this one is 7.250 wide , dont know
the height yet. j bates should have redone the plans , to match the cad , but i guess it was too much of an
undertaking , too bad. FOR ME. i'm going to go with a New 3w70i , and heavy shindin sport leg retracts.
id have to cut up the ribs too much for scale legs.
Thanks chad
Thanks chad
My Feedback: (60)
AZ
Have not forgotten you WhiteRook! I will attempt to dig out the Uiberlacher cowl this weekend and get you some dimensions, although it appears your solution is coming along nicely at any rate.
My Feedback: (60)
AZ
Not really sure at this point WhiteRook. I was actually just looking for a set of the Uiberlacher plans to use as a basis for a Tempest II as I prefer the look of the radial powered version. A gentleman responded to my request for plans and happend to have the cowl and some other accessories available for a good price so I purchased the whole package. I could probably be persueded to part with the cowling since my intentions are for the Tempest II if I ever get around to building it at all.
The cowl is 12 1/4 inches in overall length, spinner diameter is 5 1/2 inches, and the mounting face is approximately 7 1/2 inches wide at its widest point. Let me know if that tells you what you need to know.
