Premire Tiger Moth Help
My Feedback: (20)
NV
Hello, I bought a completed Premire Tiger moth, 67" span, that has had several things wrong with it. I have repaired most but do not have the control throws and the wing incidence angles. The top wing had a real aggressive AOA and I thought maybe the builder soldered the cabanes wrong, so I set it up per the Great Planes Tigermoth ARF which is 0 deg stab and lower wing, and -2 on the top. Took some work to do this and I kept thinking maybe I better stop and do some searching. Premire, and English kit maker, is long out of business and I have had no luck getting any information on the specs, can anybody help with the wing incidence? I should be OK where I have it now, but maybe going back to original spec would be better, thanks.
