Aerodyne Beechcraft B200 Super King Air Composite
Gang starting a build of the 88" wingspan RC Aerodyne's B200 Super King Air.
The one I'm building is a pre-production kit.
Cliff is in the process of changing manufactures as the quality of these initial kits just wasn't up to his expectations.
He's made the decision as to who will be making the kits and all I can say is that if the quality of their other kits is any indication of what to expect we'll all be pleasantly amazed!
Never-the-less this pre-production version is still a beautiful kit and I'm excited to get this put together.
These pre-production kits don't have any instructions so will be document as I go.
If anyone has any suggestions or comments on this build I welcome their comments/suggestions!
Here's what the kit comes in (2 boxes)
Here's the packed fuselage box
With the rudder taken out
The packed wing and tail surfaces
Here's some of the parts unpacked (Some I left wrapped to keep parts together.
Here's the interior linings
Parts bag (Engine mounting frames, motor mounts and hardware
Center wing panel
Bottom of center wing panel
Seats
Horizontal stab
One of the props and it's spinner
Fuselage
Fuselage with rudder taped to it (12" ruler placed along side for size) this thing is BIG...
Here's one of the nacelles placed along side of the fuselage
Here's the landing gear package
Here's the nose gear. (This will make you drool)
Here's the main gear with air brakes!!!!
One of the earlier kits taped together
Center wing panel
Seats
Horizontal stab
Fuselage
Very nice plane !
I've ordered the B200 today ..
Have some expierences on Twins , and this is my Baron from Aerodyne :
Alpha-air Welcome to the King Air club.
Looking forward to working alongside of you.
Since there are no instructions hoping we can double check each others work
Glad someone has started a build thread on the King Air. I was in Seattle in May and shipped this King Air model home to Anchorage, Alaska. I have also bought RC Aerodyne's Baron G58 and am about one third finished with that build. The Baron goes together very nicely, just take one step at a time. I've been very pleased with that model. I puposefully started the Baron first (just this last week) so that I would be primed and ready to take on the King Air without any type of instruction guide.
Gang,
Getting started with the landing gear boxes that sit inside a bay in the center wing panel.
This may take me a little longer than usual as there are no instructions yet and one of the reasons I'm doing this build.
Here's the bay that the landing gear mounting boxes sit inside:
My suggestion is to tape all of these pieces together first then mark each corresponding side with matching number/letter before doing any gluing
Here's the 4 pieces that make up the box sides:
Here's the top 2 pieces that the retract is bolted to:
Here's the 4 side pieces laid side to side in the order that they are assemblied:
Here's the box sides taped together. (Note all the notches are facing up)
Here's what it looks like with all 5 pieces taped together:
Here's how the box sits inside the wing gear bay: (Note the notch in the box faces forward as the main gears retract forward into the nacelles)
Because of the wing dihedral the top of the boxes are going to look slanted (Note the slant of the top of the retract mount in relation to the wing panel. While it looks like it’s at too much of an angle it really isn’t)
Here’s how the retract mounting box, retract and strut look inside the wing: (Again everything is just placed/taped and no gluing has been done yet)
Here’s the first problem I encountered:
The strut support arms are hitting the front and rear plywood wing tube spar supports.
The solution is to notch the plywood allowing the strut to fully retract.
Here’s the before:
Here’s the after:
Here’s how the strut sits now:
Here’s the before:
Here’s the after:
RC Aerodyne is selling at a super deal what they have on stock of their pre-production kits.
http://www.scaleflying.com/Pre-Produ...k-_p_4295.html
This isn't your bolt together kit but is a good deal if you want to get into a nice size King Air
There are no instructions and some of the hardware (Bolts/screws) may have to be purchased but so far my kit is going together with no problems.
My Feedback: (98)
I received my King Air Monday. Just started the build. I pre-fit the nacelle to the center wing I had to trim the opening for them to fit. The allen screws that came with the kit were to short so a trip to Home Depot and picked up the next size longer. I have noticed the servo hatch covers are small so it looks like micro servos will have to be used. any one else have any thoughts on this. My kit was missing the retracts a call to Aerodyne and they are on there way. Glade to see more kits being built.
JD
JD
Doc, I was having a lot of problems with posting on this group so moved over to RCGroups.com.
I'll try posting to this site again tonight and see if I can figure out why I'm having problems.
There's 5 of us building RCA's King Air and some of us are further along than others but none of us are flying it yet.
Some of us are glassing the wing for extra strength while others are trying to save weight. Pretty much all of us have beefed up the main gear retract supports as that is one weak point.
Let me know if you have any questions.
It's a really nice looking plane and has some good detailing.
The price is great for what you get but do know you will have to put some work into it.
I know Cliff put together one pretty fast and with minimal work but he's a pretty good pilot so unlike me who can bounce a good landing felt i needed to make a lot of modifications.
3 of us have ordered a scale cockpit and the plane already has a detailed interior so it is a awesome plane.
Did you buy one or thinking of buying?
I appreciate the response, I'll admit, I've bought the plane but was waiting you brave souls to go forward first! Could you provide a link to the Rcgroups thread as well as the scale cockpit? Thanks
jvance here's the link to the king Air group: http://www.rcgroups.com/forums/showthread.php?t=2507707
I'll also see about getting this site updated also.
Here's the link to the scale cockpit: http://www.flying-season.com/
You can also contact faye at: [email protected]
I also posted some pictures and prices for the cockpit on Jan 16, 2016, 08:47 PM (In the King Air link above)
Again if you guys have any questions feel free to ask.
Welcome to the king Air club!!!!!
I do have everything; I shipped the model up last summer but have not started--I'm one of those guys that buys two for every one that gets built. I'm finishing up the Baron and expect to maiden it this summer. I probably won't start the King Air until next winter's build season (which lasts long in Alaska). In the mean-time spring is almost here and that means 20 hours of daylight for spring summer flying!
Does anyone know when the actual production ARF version of this is ready to purchase as i too have been waiting a age for this to arrive. I looked into the pre production kit but thought i would wait until the ARF version was available. Aerodyne very cagey on when this is to be released as a full arf and i have been waiting a long time for its arrival
Autotecart that's a loaded question.
When Cliff started his venture with one of his manufactures on the first King Air, the thought was he would have production kits in less than a year and you know how that turned out. (3 years later and you know where we're at with that one. The reason he's changed to a different manufacture)
Any comments I make are strictly mine and I'm not speaking for RC Aerodyne so no one come back and say that there was any commitment to having kits out in this timeframe.
So last I heard I "think" his new builder had completed the master molds so hearing this I "think" we could see something by spring or early summer. (Again strictly my thoughts)
Many things could happen and I have no insight as to the builders priority on this kit so the above is just a stab in the dark.
If I hear of any updates I'll keep you guys informed.
