Propeller turbine body?
Has anyone tried a design with the propeller inside a round tube with airflow exiting the rear? https://ibb.co/epMkaQ
hope the link works. Just a crappy drawing of the idea.
There are a few planes where the line between a ducted fan and a ducted propellor is a little fuzzy but one plane does actually meet your description, it is called a Stipa Caproni. It looks like shrouded propellers were investigated during the 1930's. IIRC the shroud or duct negates the need for a high aspect ratio propeller blade and a shorter low aspect ratio propellor with multiple blades is more practical when it can run in a duct.
There are some interesting websites. Go take a look at stipa-caproni dot com. apparently someone in Australia built a replica. The original was unexpectedly draggy and overly stable but it was only intended to be a test bed for the idea. With smaller size the drag is less of an issue and a little stability never hurts with a novel plan form.
