Top Flite Beechcraft Bonanza engine options?
Hello. I'm considering engine choices for a new kit build. Is there a 4 stroke twin that will fit inside the cowl without cutting holes for the cylinder head covers? I would likely consider the Gemini FT-160. If that doesn't fit, I would likely go electric.
Anyone here have one with one of these two engine options?
Thanks.
Thanks.
Banned
The FT-160 is 7.72 inches wide. Take a ruler and measure your space.
Weight: 38.8 oz (1100 g)
Length: 4.72 in (120 mm)
Width: 7.72 in (196 mm)
Height: 3.15 in (80 mm)
FT-160 Specs
FT-160 Specs
Thanks.
Thanks.
Banned
Banned
Checking the manufacturers specs on the engine, it gives 6000 rpm as the MAXIMUM prop speed. I wouldn't bet the farm on keeping it at that rpm for extended periods.
You're also looking at a top speed of around 65 MPH. Sounds OK to me but the proof will be in the flying.
