35cc Phoenix Stenson Reliant
Finishing assembly of 35cc Stenson Reliant. The listed Control Throws appear to be very small for an 88” wing span, 18 lb. aircraft: low rate 10mm, high rate 13mm for both aileron & elevator. Using inner holes on servo arm and 70% on end point the actual throws are 25 mm on low rate. Any suggestions on preliminary rates?
