Albatros D.III Build along
Reply
Old 01-26-2004, 09:47 PM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Albatros D.III Build along
I've always liked the build along threads in here, so I thought I'd post one of my own.
This is my winter project, a [link=http://www.funaero.com/albatrosd3.htm]FunAero Albatros D.III[/link]
Its about 1/6 scale, 65" span, Saito .91 power. Its my first scale effort and I am hoping to enter
it in Fun Scale at our local Scale Masters qualifier.
Im thinking of doing the finish in this scheme from an unknown pilot in Richthofen's Jasta 11:
First image, the kit contents. Very nice laser cutting and good wood selection. Two BIG full size plan sheets.
*** Update Jan-30-04 ***
I'm running this build along on my website also. Same photos, but with more comments.
[link=http://sky.prohosting.com/jharkin/albatros.html]Albatros D.III Construction Site[/link]
jharkin is offline
Old 01-26-2004, 09:50 PM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Albatros D.III Build along
This next bunch is the tail group. The stab is a sheeted frame of laser cut parts. I opted to scratch build the fin and rudder as the docs I have are for the early version of this bird wich has a different rudder shape than this kit.
ID:	94645   Click image for larger version
ID:	94646   Click image for larger version
ID:	94647   Click image for larger version
jharkin is offline
Old 01-26-2004, 09:53 PM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Last of the tail group construction sequence. My scratch built fin and rudder next to the kit build stab and elevator.
jharkin is offline
Old 01-26-2004, 10:03 PM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now for the fuselage. The only change I've made here is to recess the firewall 1/4" to better fit the Saito in the cowl.
ID:	94659   Click image for larger version
ID:	94660   Click image for larger version
ID:	94661   Click image for larger version
jharkin is offline
Old 01-27-2004, 04:18 AM
pete913
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats a very nicely done kit of a very cool airplane. It's one that I've dreamt of building for awhile myself. I have a few questions about it. First, does it come with a scale dummy engine or plans for building one? Second, the cooling issue, what provisions are there for getting some airflow to the engine? Thats one thing that has always put me off building one of these myself. Also, what's the fuselage and tail group sheeted with? At one time I sorta toyed with the idea of scaling up some 3 views of this plane to quarter scale, and sheeting it with 1/64 plywood over balsa, but yikes, all those compound curves.[] Thanks for posting it. Looks great so far.
pete913 is offline
Old 01-27-2004, 08:48 AM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Pete-
Thanks for the compliment...
Dummy Engine- Yes, the kit includes parts for one. Its all balsa and dowel pieces though and some pieces you supply yourself (coat hanger wire, brass tube, springs from a pen to make the valve springs).
Cooling - The engine is mounted upright , all you do is cut away part of the dummy engine to expose the head. I plan to cut a bunch of holes in the bottom of the cowl for exit air. I'm also thinking of running the exhaust out the bottom with a flexible header pipe. Its not totally concealed, but then again this is only a sport scale kit. BTW, if you click the link in my first post you can see some images of how it is supposed to come out.
Sheeting- The fuselage is sheeted with 1/16 balsa. I'm going to be experimenting with different finishes to try to duplicate the varnished wood look on the balsa without leaving the surface too soft. My fall back plan will be to sheet it with 1/64 ply. (This is how proctor does their D.Va)
jharkin is offline
Old 01-27-2004, 11:59 AM
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tom Polpink finished his plane (1/5 albatross from his own plans) in tan latex paint and simulated the wood grain finish. From the photos in RCSI the plane looks like a wood finished plane. Its very convincing!..BobH.
BobH is offline
Old 01-27-2004, 02:37 PM
Tmoth4
Tmoth4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I saw that article in RC Scale International. It's amazing how good his fake wood finish looks.
Jim
Tmoth4 is offline
Old 01-27-2004, 09:45 PM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More of the fuselage building sequence...
ID:	95014   Click image for larger version
ID:	95015   Click image for larger version
ID:	95016   Click image for larger version
jharkin is offline
Old 01-27-2004, 10:28 PM
Lucky Dog
Lucky Dog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
James,
Looking very good! The DIII is also on my list of too builds some day. Like pete13, I'd have a hankering for 1/4 scale too.... maybe. But, the Fun Aero kits sure is nice looking. I was drooling on one a the Dayton DPR last September.
What's the diameter of the spinner? It might be an option for builders of the Balsa USA Bristol M1C.
I'm looking forward to watching your progress.
Lucky Dog is offline
Old 01-28-2004, 09:44 AM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike-
The spinner is 4.75 inch in diameter and is made by [link=http://www.genebarton.com/]Gene Barton.[/link]
BTW, nice site. I'll have to send some picks in when I get this bird completed.
-Jeremy
jharkin is offline
Old 01-28-2004, 12:51 PM
balsa4cat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hallo Jharken;
The Albatross Werke D series aircraft are very interesting to model. I have build a 62" wingspan, .65 (2-stroke engine) Mike Bishop plans D-Va version. Building the spinner and running the control cables were the best part before flying. It is a good flyer.
Your stabilizer is sheet covered ? This is not scale ! The rudder fin is sheeted but not the stab. Check the NASM restoration research.
You have over 82 basic Jasta's colors to choose from. Mine is a green tailed with red trim (j5), grey fuselage with a red dragon playfully running the lenght of the fuselage.
Clear the skies of the those inferior Newports, DeHavallins, etc. !
balsa4cat is offline
Old 01-28-2004, 01:12 PM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good catch balsa, you are of course correct.
This kit is only semi-scale. The outline is about right, but some dimensions are stretched and many details are altered. One of which is that they sheeted the stab and framed the fin (reverse on the original). I scratched my own sheeted fin, but did not want to go to all that trouble on the stab. Instead, I'm thinking of gluing some thin balsa strips over the sheeting to simulate the ribs.
Eventually I'd like to do one exact scale, like the Proctor and Torrance kits; but I want to get some building and competition experience under my belt first.
ORIGINAL: balsa4cat
jharkin is offline
Old 01-28-2004, 01:17 PM
Wulfman
Wulfman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Neat airplane! I also have this kit, but the parts have never left the box. I hope to get around to building it someday, the Albatross is a great looking airplane. What are you using for wheels?
Wulfman is offline
Old 01-29-2004, 09:07 PM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm probably going to use williams wheels. I'm thinking of making real fabric wheel covers to dress them up though.
ORIGINAL: Wulfman
jharkin is offline
Old 01-30-2004, 09:53 AM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Latest update. I just recieved the pilot Im going to use from perfectpilots.com
[link=http://www.perfectpilots.com/pilots/ww1/spike.html]Spike[/link]
Not necessarirly scale for 1917, but he looks a lot better than the bland williams pilots.
jharkin is offline
Old 01-30-2004, 11:46 AM
balsa4cat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hallo Jharken;
Just a thought about your exhaust plan; The full scale exhaust was routed out and above teh top wing. Your four stroke pointed up would be scale. Engine cooling would be aided by moving the spinner forward more from the fuselage creating a air gap, ala full scale.
Have you selected the wing covering color yet ? Early production purple, dark green & blue colours are easy to paint on. The 4 or 5 colour lozenge of late production versions require a lot of preperation: diangonal or perpendicular cloth lay, painting /staining the lozence colors (unless you buy pre dyed cloth from arizona Model Werks), pink or blue 'pinking strips', top pattern is differnt colours from bottom pattern, etc. Then we must not forget the shiny grey or green colored structs (steel on full scale while the allies used wood).
The pilot I assigned in my Albatross came from a Pease Officer (with helment) on motorcycle toy of my son. A little latex paint and voila!
Old 01-31-2004, 02:43 PM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello...just noticed your build...I"ve just recieved one of these kits, and am very impressed.....going to be an avid follower of your build.....you mentioned the ply covering...what about sheeting with 1/32 balsa....instead of the suggested 1/16...then apply 1/64 ply.....cut into panels to represent thr full-size?......maybe be easier as well!! I"m not going to build mine for a few weeks...but am delighted at getting the chance to follow you.....brilliant.....
Clifford
clifford is offline
Old 02-02-2004, 08:26 PM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Balsa-
Actually the exhaust on the D.III is routed in between the planes. It was only on the D.I prototypes I believe that the over the top wing exhaust was used. The dummy engine on this model has the scale exhaust pipe, For the real exhaust Im just drying to hide it and direct the mess away from as much detail as possible. Hense the bottom of the cowl idea.
Clifford-
Interesting idea, I may have to try that. Another thought I had was to use finishing resin straight on the balsa without glass. It should harden the surface quite a bit. In any case I'm going to do a bunch of experiments on scrap first before selecting a finish.
jharkin is offline
Old 02-02-2004, 08:28 PM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More photos. Start of the lower wing...
ID:	96790   Click image for larger version
ID:	96791   Click image for larger version
ID:	96792   Click image for larger version
jharkin is offline
Old 02-06-2004, 08:53 AM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great......keep it coming...I"m saving your pics for reference, when I start my own.....any problems so far?....
Clifford
clifford is offline
Old 02-06-2004, 11:31 AM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cliff-
So far things are going well. In addition to what I've posted I have the wings complete and am now working on the ailerons. I hope to have more photos in a week or so.
A few comments/suggestions on the build:
* Study the plans carefully! They are well drawn but could benefit from more details view IMO. Especially some cross sections of the wings.
*Dry fit everything before glue. 95% of the parts fit perfectly so I got lazy about this. Then I ran into some aileron ribs that were too short. Its any easy fix but dry fitting would have saved me some frustration
* The instructions have some gaps. For instance the top wing instructions just end without finishing the top of the center section and there are no instructions on control installation. I've built enough kits that I can figure all of it out on my own using the plan but it could leave a first time builder in trouble.
* There is nothing in the plan about routing the aileron servo leads to the fuse. The ribs have cutouts thought so I installed some paper tube conduits and I think I will cut access holes and strap the leads to the cabanes.
* The building sequence calls for making the cabanes during fuselage construction. I skipped over this and built the wings first. I want to be able to attach the wings and check the alignment before I finish solder the struts.
* Like many kits, the plan calls for drilling holes in the lower wing for the alignment dowels after the wing is complete. I don't like the imprecision of this so I marked the leading edges and made a jig to drill them on the drill press before installation. I left of the top sheeting until after Ive test fit the wing to the fuse and glued them in.
jharkin is offline
Old 02-07-2004, 11:49 AM
clifford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeremy...thanks, I"ll bear those points in mind....do you thinkd that you are going to have any cooling problems?.....ie...only the top-part of the engine is showing in the slipstream....any ideas?
Clifford
clifford is offline
Old 02-11-2004, 10:46 AM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cliff-
Wont know for sure until I try it, but I doubt it. The head is the hottest part of the engine and is well exposed. What I plan to do is measure the area of the opening, double it and then cut that much area of vent holes in the bottom of the cowl for exhaust.
ORIGINAL: clifford
Clifford
jharkin is offline
Old 02-16-2004, 09:17 AM
jharkin
jharkin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More progress to report...
The wings are nearly complete. All the framing is complete and the lower wing has been fit to the fuse. All that remains is to build the cabanes, struts and hinge the ailerons. I did some more modifications here - the model has a sheeted center section on the upper wing but the full scale does not. So I cap stripped the upper wing instead. I am not too worried about strength as I have added full shear webbing to both wings and will be using semi-functional flying wires.
I also prepared some test samples for the fuse sheeting technique. I tried 4 methods:
1 clearcoat on bare balsa
2 3/4oz glassing
3 resin on balsa without glass
4 1/64 ply laminated onto balsa
As you might guess #4 looks the best. Clearcoat on balsa soaks into the grain too much and the glassing looks like it will need a lot of clear to fill in the weave. Tonight I will sand down the bare resin and shoot some clear... However its looking like the ply is the way to go.
I also had the pleasure of an up close look at a Duncan Hudson Tiger Moth that is being prepped for Top Gun this weekend. The builder is a member of my club and was showing me how the scale s*t*i*t*s covering works. That stuff really looks amazing, I'm just not ready to invest in spraying gear and the $20/pint !! paint it uses. I think koverall, krylon and Sig dope will give me 80% of the look at a budget I can afford.
jharkin is offline
Contact Us Archive Advertising Cookie Policy
