If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 11 of 11
  1. #1
    Join Date
    May 2004
    Bountiful, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hanger 9 P-51 1.5 Can I Use Zenoah G38?
    Has anyone tried fitting a Zenoah gas engine, particularly the G38 into the Hanger 9 P-51 1.5 ARF? If not this engine any other gas engine? I am also hoping the 37.7 cc engine will be enough horse power for the plane. Thanks for reply.
  2. #2
    Join Date
    Apr 2002
    Roanoke Rapids, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hanger 9 P-51 1.5 Can I Use Zenoah G38?
    WLJ -- (Enfield, NC) has done it, I saw it fly last weekend. Send him a PM, maybe he'll fill you in on the details.
    D. Hayes
  3. #3
    WLJ's Avatar
    Join Date
    Jan 2002
    Enfield, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I did. Plenty of power.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	137642   Click image for larger version.
ID:	137643   Click image for larger version.
ID:	137644   Click image for larger version.
  4. #4
    Join Date
    Sep 2004
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WLJ,
    Did you mount the engine directly to the firewall? I am going to use the same engine on the new version of this plane. The dimensions may not be the same since it is slightly larger. Any tech info would be greatly appreciated.
    Denny
    Live to Love and laugh, anything else is rubbish!
    A citizen of the universe
  5. #5
    WLJ's Avatar
    Join Date
    Jan 2002
    Enfield, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tenacious101010
    WLJ,
    Denny
    Mounted to the firewall, but needed standoffs to get the spinner distance right. Fuse is the same, wingspan was just increased..
  6. #6
    Join Date
    Oct 2005
    TUSCALOOSA, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WLJ,
    Denny
    Hello,
    Can you tell me what Hanger 9's product ID number for the new version of the P-51 1.50 size is?
    P-51 MAN
  7. #7
    Join Date
    Oct 2005
    TUSCALOOSA, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: WLJ
    WLJ,
    What size APC prop did you use? Did you convert to electronic ignition,if so where did you get it? Your prop washer and shaft is different,did it come with your engine or did you change it?
    P-51 MAN
  8. #8
    WLJ's Avatar
    Join Date
    Jan 2002
    Enfield, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used a 18X8. I'm not looking for max. speed as much as scale speed. My G-38 is one of the older models that came with a steel prop hub and steel washer. Newer models have Aluminum. Didn't use electronic ign. I kept the spring starter. Moved the gas tank back to the CG. Balanced with no added wt. Billy Johnson (WLJ)
  9. #9
    Join Date
    Sep 2004
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thought I would add to this thread. I put a Zenoah G-38 in my H9 Mustang and bolted it right to the firewall. The engine I used has a spring starter and the associated cup mount. I had to replace the factory supplied spinner with a dave Brown brand I believe, and the engine is too far foreward now, the gap between the spinner backplate and the front of the cowl was way too large. I traced the back of the engine mount onto the firewall and cut out that portion of the firewall. I made a pattern and transferred that to a piece of 1/4 ply. I had to make this in two pieces but it conforms well to the existing firewall and will be glued behind the present firewall. This moved the engine back just right. I may glue a bit more ply to this, not sure how thick the firewall should be for a G-38. I will decide after some research. I saw a post somewhere about the recommended thicknesses of firewall ply for various Zenoah sizes.
    Denny
  10. #10
    aghost's Avatar
    Join Date
    May 2002
    Amarillo, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Denny,
    My Zenoah manual lists firewall thickness for G-38 through GT 80twin as 10 mm of aircraft grade plywood minimum.
    Brian
  11. #11
    Join Date
    Sep 2004
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Brian,
    I was thinking around 3/8 inch, I will use two 1/4 inch sheets of ply bonded together, that comes to 12 MM, or just over 1/2 inch by 2 MM.
    Denny
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
