Rotating Light
TX
RE: Rotating Light
Maybe this will work for you ... http://www.ramrcandramtrack.com/ramd.../MarsDemo.html
CA
RE: Rotating Light
Thanks bonedaddy....I didn't see any at Tower (pretty sure tower still sells RAM), so I ruled them out... Should have thought to go to the RAM webpage!!!! Ohhh on further investigation it's a simulated rotating light.... I wonder how good it really looks???
I think I recal old radio shack toys having rotating lights too.... I'll have to take a look on ebay... might acctually be cheaper too!
Thanks again fellas
Thanks again fellas
TX
RE: Rotating Light
I have the RAM "rotating" beacon for my Bonanza. I haven't finished the plane yet but I have played with the lights The beacon looks pretty good even though it doesn't really rotate. It is also totally adjustable so you can pretty much set it however you want. My only question is ... is it bright enough? But then again I believe the only light that will be visible during the day will be the landing light ... it should really look awesome at dusk though
