.25 Scale Fw-190
ID
.25 Scale Fw-190
HI! This is my first post and with that i bring you my "new" project. The basic premise is to enlarge the guillows fw-190 plans as a basic starting point and change it all!!! As of now I have designed the wing and cut one test panel to test my prowess with my new foam cutter. The basic specs are wing area = 370 in^2, wing span = 44 in, power will come in the form of a .25 OS LA that i have had lying around. The plans were scaled around the wing design to give an acceptable wing loading of around 21 - 22 oz/ft^2 which also (thankyou Kurt Tank) yielded an acceptable tail moment arm and tail surface areas. Would love to know how to go about forming a canopy and/or cowl. Will post pictures if intrested.
MI
RE: .25 Scale Fw-190
Wing Manufacturing has a pre-formed cowl and blisters and also a canopy for their .25-.40 sized FW190 that you may be able to use or adapt that can be purchased seperately from their short kit. They may also be able to make a custom cowl and canopy if you provide the mold or plug. They are very nice and easy to deal with people there. Check out their web site for more info.
PA
I built a 54" wing span Guillows fw-190.
The Wing MFG kit is 54" also, which you could probably use parts from.
For my cowl, I bought a $5 surplus cowl from a Hobby Shop, which I believe was from a Sukhoi. I cut it down, and it fit perfectly. Robart makes an inexpensive fixed landing gear strut, which fits and looks good. Is this project still going?
