"Scale" prop nut ?
"Scale" prop nut ?
I've seen on several BUSA WWI planes in particular, a prop nut that has the appearance of the scale front plate that has small nut heads to make it look like a multiple bolt hub. Who makes these, and what sizes are available? I need them in 7mm x 1 threads (mid block Saito), and to fit G-26 and G-38.
RE: "Scale" prop nut ?
At one time, BUSA was selling these. My BUSA Fokker DVII just had contact info, which I've lost.
The mfg is Ralph Vanneman (sp?). Try a search. I'm very happy with the one on my G26.
Hi
I bought one a couple of years ago for a Saito150 in a BUSA N-28 from:
Ralph Vannaman
2301 13th Ave
Menominee, MI 49858
E-Mail: [email protected]
Sizes listed at that time were:
5/16-24
8mm
10mm
3/8-24
Bunsen
Ralph Vannaman
2301 13th Ave
Menominee, MI 49858
5/16-24
8mm
10mm
3/8-24
Bunsen
Just got my Nieuport 28 kit-here is the info-Ralph Vannaman- email is [email protected] Picture of prop hub looks nice-I was just going to get a correct diameter washer, lay out 8 equally spaced holes, drill, tap for 2-56 or 4-4- screws and grind off flat on back side.
