Panel lines and math??
Ok maybe this is a dumb question and if I can't answer it myself maybe I should stop now, but here it goes.
I have some 3D pictures of a P-47 that show every panel line and rivet. The pictures are in 1/72 scale. How can i convert them to about 1/7 or 1/8 scale for the .60 size TF P-47? Then after I do that what size tape should I use for the panel lines and brass tube for the rivets?
Chris :stupid:
Chris :stupid:
AK
Okiedokiethen...
1/72nd = 0.0138
1/7th = 0.1428 Mulitply your 1/72 measurement by 10.3478
1/8th = 0.1250 Mulitply your 1/72 measurement by 9.0579
You might do just as well by looking (probably in an Architectural supply place) for a scale that already has those ratios on it.
I like to use a spreadsheet, entering whatever measurements I have, then I can change my mind any time about what scale I want to build at, and the spreadsheet automatically does the math. Just set one up, and you can use it as a template for all your scale projects.
AK
Scale and 3D
I create all the 3D images on my site personally, using "Carrara Studio" by Eovia. ( http://www.eovia.com ) I also use Photoshop, Illustrator, and other software, to add text, fine-tune colors, etc..
Good luck on your P-47. The Top Flite kits are good to practice scale techniques on without spending a fortune. (Several friends and I built a TopFlite Cessna 182 last year, and now one of my local friends is doing the Bonanza.
Happy flying!
Happy flying!
Green River,
I found them at http://www.suurland.com goto the blueprints and it will show you a list of a lot of planes!! Good luck
My Feedback: (22)
Make the math easier
Get metric flex rulers and measuring tape. You've been using base 10 all your life. It makes scaling, and measuring much easier to do it in CM and MM. Try it, you'll like it!
