RCM - CT-114 Tutor or F-18 "Pusher Prop"
RE: RCM - CT-114 Tutor or F-18 "Pusher Prop"
I built the F-18 a few years back and it performed well. Not as fast as you'd hope due to a fairly thick wing but it does help the landings quite a bit. Make sure you have a slightly nose up attitude built into the gear or it will stick to the runway like glue until you give up elevator and then STRAIGHT UP!!
Dave
Dave
AB, CANADA
I owned his prototype A-10 pusher...it was a real fun airplane and loved being tossed around the sky. Takeoffs were an adventure though....
ON, CANADA
Jim,
Just finished the Canadair Tutor from RCM plans. It's easy to build and I will let you know how it flies. The plane requires alot of lead in the nose to balance, however I am a Heavy builder. Here's a couple of pics of the finished product. I added a mac smoke system and mini mag headlight and underwing fuel tanks for added scale.
Mike
Mike
ON, CANADA
Jim,
The Snowbird Tutor flies great, however don't put the mac smoke system in it. I should of realized that with the exhaust backwards there is enough back presure to push the smoke oil into the cylander head choking the engine. Lucky I was high enough and in good position for a dead stick landing. I kept the landings a little hot as with pushers the lack of prop blast over control surfaces make the less responsive at slower speeds. Other than that a great little project and a good flyer, I highly recomend it. good luck..
Mike
Mike
ON, CANADA
Jim, I forgot to mention but if you are interested in the F-18 design from Mike Pastro the is a Kit available from G&P sales. Heres a couple of pics of the f-18 from them that I built. The camo one is the one I built and the blue angel I picked up at a fun fly, both fly well but I waited a long time to get the kit. A good flyer but grass fields rake havoc on the landing gear. If you have any questions I'll be glad to help...
Mike
Mike
AB, CANADA
You don't have to give up on the smoke.... just get a Traxxas header (TRX5540) and cut it into a "J" pipe, as in the photo, and JB weld it on to the end of your muffler. It redirects the exhaust flow. and cuts down the back pressure.
Thanks Mike, I'm building the F-18 (40 size) currently. It's about 80% complete now and working on the front canopy and deck. Picking a colour scheme. I was going to paint it, but I might just use ultrakote for the first model. I have both plans, the CT-114 and F-18. Like the snowbird scheme, but also snapped photos of the AETE version at the Armed Forces Day in June. Was the canopy for the CT-114 from Bob Holman plans.
Jim
Jim
ON, CANADA
Jim,
yep both the foam wing cores and the canpoy were from Holman plans and were both good quality. I don't know what he's asking for them now, mine sat on the shelf for awhile before I got a chance to built it. I like the paint scheme you picked. Mine was z-poxy and .75 fiberglass cloth painted with topflite paint. Me and monokote just don't get along. I made the decals with the Testors paper and my computer printer and then clear coated them with topflite clear to fuel proof. Looking forward to seeing the finished product.
Mike
Mike
I've used z-poxy for the center sections of planes, but never considered it for laminating 0.75 oz. cloth to a fuselage and wing before. Wouldn't it make it heavy? By top flite paints, i guess you used lusterkote. How many cans did it take to finish the model? It's just too bad the it's only available in spray cans. I was considering latex for my F/A-18 and than spraying it with top flite clear. But it's getting late in the summer and over the winter I don't have any place to spray paint. Except for the paint shop at work (black or light black).
Jim
Jim
Hi Mike, so far here is the completed stages of the 0.40 CF-18 Pusher. Just trying to decide on a colour scheme. Just too many nice ones to choose from. I ended up using 0.75 oz cloth with minwax polycrylic. It's final surface doesn't have the toughness of fibreglass resin or finishing epoxy. It does take many coats to fill the weave of the cloth unless you add baby powder to the polycrylic mix. Smell baby fresh though. Primed with duplicolor filler primer .... sanded off ...... filled again ..... reprimed ..... sanded off ..... primed ..... sanded off...... etc.
Jim
Jim
I checked with G&P Sales, the kit isn't at a bad price but the shipping was going to cost me $100.00 To bad my brother-in-law doesn't drive semi'sout to the west coast anymore.
Jim
Jim
ORIGINAL: mwalsh6
Mike
Mike
