Reload this Page >
Bob Rich L-19 Bird Dog anyone?
Old 12-10-2006, 11:23 AM
wsmalley
Default Bob Rich L-19 Bird Dog anyone?
I bought this plane essentially finished from a buddy who bought it from the builder, said it was built from plans. I believe it to be a Bob Rich RCM #1189 plan set. Has a 6' wing span, operating flaps, fiberglass cowl. It's drilled for the motor mounts, but doesn't appear to have had an engine mounted. Certainly never flew since the wing doesn't fit the fuse-needs to be trimmed. Trying to find out what engine/motor mount may have been called for in the plans. I have an ST .61 2s that looks like it will squeeze in with the right muffler. Any help on this one? Bill S.
ID:	574647   Click image for larger version
Old 12-10-2006, 01:12 PM
DavidAgar
My Feedback: (108)
DavidAgar's Avatar
Default RE: Bob Rich L-19 Bird Dog anyone?
Except for the location of the wing hold down block, that closely resembels the Jack Stafford L-19. It is a 60 size plane as well. I have mounted an OS 91 4 cycle on mine and there is plenty of room in the cowl. My wing is also about 6 ft long and I have built in the flaps as well. I am just finishing the wing as we speak and hope to have her finished in a month or so. Good Luck, Dave
Old 12-10-2006, 02:16 PM
wsmalley
These are pics of the wing and tail feathers. Guy did an excellent job of building, and covering! Needs a few of my personal touches such as lettering. In the background is my rebuild P-40, my F4D Skyray and the Ziroli Stuka wing-I think I suffer from a plane addiction!
ID:	574708   Click image for larger version
Old 12-10-2006, 08:58 PM
flipstart
WS-I am building the Stafford L-19 and on the plans they credit Bob Rich with the design-his original model was published in RCM. Your ST 61 should fly the plane ok-I am using a Saito 91S, but I talked to a modeler who flew his with a Saito 72. The plane should come in around 8 # AUW,depending on how many scale details you add. The new Stafford design calls for 2 servos on Ailerons and 2 for the flaps, so mine may weigh a little more. I have not seen that color scheme, gray and red, currently planning on doing mine in the Army red/white scheme, with rockets of course. (non-functional)
Does yours have the windows in the top of the wing?
I didn't like the wing bolts going thru the windows, so I am currently trying to work around that little detail.
Old 12-10-2006, 09:01 PM
flipstart
WS-also meant to ask how your builder handled the corrugations on ailerons, flaps, elevator and rudder. Still pondering how to get that effect. Any ideas??
Old 12-12-2006, 09:40 AM
wsmalley
I'll study the corrugations and try to get a closeup shot. He has the top windows (wing) faked with aluminum tape. It has 4 servos in the wing. If your interested, this is something I came up with to build a Ford Tri-motor:
ID:	575825   Click image for larger version
Old 12-12-2006, 11:37 AM
wsmalley
It looks like he used something like angle stock, maybe basswood like model railroaders use. Appears he covered the surfaces first, then applied the pre-painted corrugations individually. Man, I don't have that kind of patience! Must add up to a couple hundred! I'm not happy with the servos mounted up high, sort of Cub-like. That big cockpit area cries out for a full scale pilot-and cool instrument panel too! Where do these Stafford plans come from?
Old 12-12-2006, 06:43 PM
flipstart
I was thinking on 1/6 scale the corrugations would not be quite that tall-in Bob Rich's write up on his model, he used string ca'ed to the control surface-just hate to try that technique. Guess I need to see how big the plastic corrugations are in a Cessna 182 kit. Thanks for the pic-looks like you have a well built Bird dog-the Stafford plans are from the Jack Stafford Scale Kit Company-they make several WB kits. The Bird Dog kit has been "redesigned" so I don't know how it would vary from the RCM plans that are available.
I have some pics of the model that Bob Rich published in RCM if you would like them, along with the article-they were sent to me by another builder. PM me your email and I will forward them to you.
Old 12-12-2006, 09:46 PM
khodges
You might try a hobby shop that caters to model R.R. stuff, they may have thin plastic sheets with corrugations close enough to work. On Vaillancourt's plans, he suggests small plastic "angle iron" from Plastruct, 1/8 inch on a side, pieces come about two feet long. Cut to length and place them one at a time.
Old 01-31-2008, 10:49 AM
MJC0074
Hello. I am building that very same plane. After spending a lot of money to get back into this hobby along with a lot of time. Im having trouble getting the fueslage together. Everything forward of f-3 isn't right. I was wondering if you or someone you know can help. It doesnt seem like there are a lot of people who have built this plane. some things on the plan dont match up or are the wrong size. what I'm looking for are some photos of what this thing is supposed to look like. The landing Gear Block and Doublers. If you can help Please Email me. [email protected]. Thanks
Old 02-03-2008, 03:36 PM
wsmalley
Stand By! I'll try to get you some close up pics in the next few days. Got to be out of town tomorrow-Monday-so probably Tuesday. Bill S.
Old 02-04-2008, 05:38 PM
wsmalley
Don't know if these will help. I'll post these here in case the next guy gets stuck. Don't know where you're at, but recommend you test fit the wing to the fuse, adding some windshield material to the area forward of F3. I have to angle my wing into place-it's a very tight fit!
ID:	869990   Click image for larger version
ID:	869991   Click image for larger version
ID:	869992   Click image for larger version
Old 10-06-2011, 11:12 AM
corsair647
Hello,
I would like to know if you know how much this L-19 weighs completely ready to fly? Thanks for your photos - they are good!
Regards,
Fred
Old 06-22-2017, 11:40 PM
jan brilman
Any news on the Bob Rich Bird Dogs?
I am thinking on starting one soon . . .
jan brilman
