Flight Yoke/Stick articulation???
Guys,
I am trying to get articulated yoke movement and I figured the best way to do this is by "Y" harnessing micro servos with my aileron and elevator channels from the rx back to a helicopter swash plate, but after experimentation I am experiencing "writers block", so to speak. Maybe someone can elaborate on how this is accomplished. I have seen this on model aircraft at large events in the past. Any info on such a setup would be very much appreciated.
On a side note, I thought I would share a discovery I have made today. If you are interested in super scale instrument panels for 1/4 scale aircraft, check out this company. They are in the UK.
[link=http://www.stateofartmodels.co.uk/gallery/mezekdeska/mezekdeska1gallery.html]1/4 scale instrument panels[/link]
RE: Flight Yoke/Stick articulation???
Scalefreak.....are you putting in a Wheel control or duel axis stick?...I have done a stick control and it worked not to bad with two servos and ball joints.Would have to hunt up the mechcanizm I made....Hope I didnt biff out. ..Done many years ago...cheers
HI Scalefreak.....found it..here is the mechanical mock up I made to do my experiments,and it worked,so made it up in smaller size for the aircraft which is now gone.The stick is on the servo which does ailerons,and mounted on a pivot which lets the second servo do the for and aft movements for the elevators. The size of your aircraft you would use micro servos and bingo works fine. cheers
Awesome! Thanks a million Mintie! I will probably use HS-55's for this project! I am getting started on it right now. I will post a pic once I am done.
