Koverall or Stits lite
HI guys
I need an opinon on which covering is better koverall or stits lite. I'm not sure which one I should use. I'm building a D-7 and I will be painting it. I like the stits covering and i have ordered some to test on a wing panel. But Koverall has come to mind as well. Also has anyone used the rib stitching tap from the guy in canada? and how do you like it? any help would be greatly appreciated.
Louie [8D]
Louie [8D]
RE: Koverall or Stits lite
I haven't used stitts covering but I have used Koverall and I liked it. I'd guess that neither one is better than the other.. maybe each is just a little different. If you do a good job of covering and prep both will give you a good finish.
I made my own rib stitching which ends up very much like the product being made by the guy in Canada. Your problem is that I think the Germans used a different stitch pattern. From what I remember their's is in the form of a Z rather than the other method of line with a knot in the middle.
Making the Z pattern isn't too difficult. You might space nails on a board the correct shape and lengh of your wing cord. Wind the thread around the nails to establish the Z pattern until you have a completed Z thats long enough.
I'm thinking hair spray would sufficiently harden the thread so it would hold it's shape. Then give it a lite coat of 3M spray and apply to the rib.
Cover your stitching with colored ribbon from a fabric store or dye your pre cut strips of your own fabric covering with rit dye.
There may be much better methods out there to accomplish the same thing.. this is what I came up off the top of my head.
Bob,
Could you elaborate on the "Z" pattern for the rib stitching? Would this apply to an Eindecker too then?
Cheers,
Cameron
p.s. Louie - I've used Koverall and liked it alot. Suggest use a heat-activated glue (eg Balsarite) to apply with an iron, rather than doping it on though.
Cheers,
Cameron
Cam I'm not a German stitching Master but when doing research into the stitching on an Albatross that's one thing I noticed. Then in a discussion with a friend he said the same stitching was on the Dr1. So Im beginning to think it was kinda standard on German aircraft. Essentially the stitching has a horizontal line across the rib and then a diagonal and another horizontal.. etc all the way from the leading edge to the trailing edge..
The guy I would ask who would know for sure is Glenn Torrence.. He is a German Plane Master!
Cam,
If you will check with one of the larger stores such as Michaels, or see if you can find the website for either Gingher, or Wiss, you will find that they offer a set of pinking shears that has a smaller notch. This notch is only about 1/16" and you can cut the pinking tape from the Koverall. Probably from the Stitts lite as well. I bought a set of them several years ago, and they have served me well. It looks correct at the trailing edges of the wings, and the other lapped seams too.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
Yeah I was thinking of using Sig's stix it for the Koverall or I may try polytac. I haven't used either covering. I have a crashed wing from a friend who was going to trash the wing and I took the wing home cut in half and Im going to cover one with stits lite and the other with koverall. Then I'll see. All you guys gave me some good ideas. About that Z pattern for the rib stitching I'll have to do some research. thats good information, I didn't know about that. so that's a horse of a different color now! I think I should call Glenn torrance and have a chat. I do have a way to go, I only just finished the tail and will probable start the wings this weekend. Next weekend is the Wram show so I wont get anything done that weekend.
Thanks guys
Thanks guys
ORIGINAL: BobH
Bill he isnt asking about the rib tape (at least I dont think he is) he's asking about the rib stitching. The German stitching was different than the Allies.
Bill, AMA 4720
WACO Brotherhood #1
ps ...Are you the same BobH that does the ARF rebops?????
LOL WWI planes didn't use pinked tape!
Although the Albatross Stropp which hangs in the Smithsonain Air and Space does have pinked tape. I have no idea why that is. Perhaps the some of the German MFgs used it? I know the UK Mfgs did not.
No I don't do arf rebops (what are they any way?).
TX
kestrel0222
Could you give any helpful hints on the KOVERALL ???? Hits and Misses. My project is a 1/4 scale Piper Tri-Pacer or PA 22.
I have acces to older fabric covered aircraft so I have a good idea what is involved. Any tricks for stitching ????. I have scratch built
many aircraft but have always used the painted or the plastic materiels.
I'm not Kestrel, but if you will check out the WACO YMF thread in the Vintage and Antique forum, you may find exactly what you want.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
Stitching is pretty easy to simulate. You can buy premade stitching from a guy in Canada. ( http://home.cablerocket.com/~scaleribstitch /) Or.. you can make your own like I did.
I used the technique mentione here ( http://www.glue-it.com/aircraft/gene...stitching.html ) with a small modification. Instead of paper like mentioned in the article I used the same fabric I was covering the plane with. I also stuck down my "stitches" to that fabric with some Spray 77 by 3M with the adhesive side of the fabric facing down. That way I could use a small sealing iron to attach the entire stitch to the wing covering. On top of that I added the "rib tape" and ironed that down.. The entire affair looks pretty good after you're finished.
Hopefully you can see some of the stitching I've included in the two photos.
