"Little toot" Centre of gravity
I recently acquired a "Little toot" biplane. Its 57" span which I believe makes it 1/4 scale.
Naturally I'm keen to get it in the air, but I need to know the centre of gravity location, and also recommended control throws would be nice. If anyone knows this info, or could read it off a plan, I'd be most grateful for their assistance
Regards
Rob
Regards
Rob
Try this link. 22-25% of the MAC (mean airfoil cord) should be a good place to start.
http://www.modelaircraft.org/newsletters/0903_15.asp
Thanks for that.
I know that for a single wing, the C of G is somewhere like 25% to 30% of the MAC. So your figure of 22-25% would suggest that for the biplane the C of G is generally set a bit further forward?
Also I found this http://users.adelphia.net/~pjburke1011/cg.htm , which has a link to a MAC calculation program.
Regards
Rob
Regards
Rob
Rob there is also the amount of stagger of the wings needs to be considered. Some place I have a good explaination of determining how to figure that out and then where to place the CG. If I can find it I'll post it.
Thanks Bob, I'd really appreciate that
regards
Rob
regards
Rob
Rob
I have the plan for the same size Little Toot (from RC Model World).
The CG range is shown at 120-130 mm measured back from the L.E. of the top wing at it's centre.
The control throws are shown to be:
Rudder 1.25" each way
Elevator 1.75" up and down
Ailerons 1.25" up, 0.75" down.
Good luck!
Good luck!
Hi
Thats just the information I needed - many many thanks!
Regards
Rob
Regards
Rob
I fitted a saito 125 4 stroke, and set the C of G to about 125mm, as discussed above. Flew the model over the weekend, and the results were great - it looked and sounded pretty damn good, if I do say it myself!
If anything is still feels a little nose heavy, also the wooden pushrod for the elevator is less than precise, I'll maybe convert to closed loop or more likely fit a couple of direct acting servos at the rear. I might need to move the battery forward a little to compensate for the latter.
So I just wanted to say thanks to both of you for being so helpful.
Regards
Rob
Regards
Rob
Rob glad everything worked out for you..
Previous Thread
Next Thread
