saito or 26cc gasser in my chippy
I just bought a peak 26 and was going to buy a 120 size plane to put it in,but then i looked at my wm 90s chippy[>:]it already has a saito 91 in it but i would like to go gas,so what do u think to big?
My Feedback: (22)
RE: saito or 26cc gasser in my chippy
Most 120 size craft will take a gas eng. 26 size. I don't know what the differances in the Weight of your 90 and the 26 eng . are. If it isn't to heavy, the power doesn't matter. you can always throttle back. Just make sure the fire wall ,and the fuse is strong enough. hope this helps some what.
Jacque......... Waco brotherhood # 27
VA
IMHO the added weight will be the main issue. I would rather go lighter with the Saito 100 or Saito 125 if you have a real need for speed. You might want something that has a short coupled nose and could use the extra weight instead of adding lead. I had a GP Chipmunk that flew great with a Webra 120, no ballast added, until I planted it in a tree.
