"invisible" on/off switch?
Reply
Old 09-06-2008, 01:39 PM
ceecrb1
ceecrb1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default "invisible" on/off switch?
Are there any tried & tested means of hiding the on/off switch for radio on a scale plane?
at the moment the best I can think of is underneath the plane but as it will have a pitts muffler, it will be suseptable to a lot of exaust dirt and oil etc... not a great idea...
suggestions???
ceecrb1 is offline
Old 09-06-2008, 01:53 PM
jtisch
jtisch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: "invisible" on/off switch?
What type of aircraft are you making? Does it have an open cockpit?
jtisch is offline
Old 09-06-2008, 02:07 PM
RGN01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've hidden them in scale exhausts, in open cockpits, inside scale air scoops, under opening covers etc. You can even get some switches that use magnets to switch the model on (magnet attached = power off) so not visible from outside the fuse. There are usually plenty of places to hide a switch but it does depend on the plane you are modelling.
HTH.
Richard
RGN01 is offline
Old 09-06-2008, 02:56 PM
rwright142
rwright142's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: RGN01
...You can even get some switches that use magnets to switch the model on (magnet attached = power off) so not visible from outside the fuse...
Richard
That sounds cool! Do you have any more info/links on this?
rwright142 is offline
Old 09-06-2008, 04:23 PM
Teus
Teus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rwright142
[link=http://www.rc-electronic.com/html/englisch/unten/dpsi/dpsi_micro/dpsi_micro.html]DPSI Micro family from Emcotec[/link]
Teus is offline
Old 09-06-2008, 06:23 PM
CoosBayLumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Had a friend who was into model submarines. As you know they are overly cautious about leak spots. Thus they use magnetic on/off switches placed in the hull at a certain location. He carried a magnetic pocket pen in his shirt pocket to turn it on and off.
Go to wet stuff forums and ask where they get their magnetic switches from.
Wm.
CoosBayLumber is offline
Old 09-06-2008, 07:59 PM
My Feedback: (17)
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The nose gear wheel well works great. I put the switch inside the fuselage with a wire link to the wheel well and also put my retract gear air fill valve in the wheel well too.
8178 is offline
Old 09-07-2008, 03:52 AM
saramos
saramos's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One can use a push-on/push-off style of switch and use th antenna mast to turn it on and off. On my TF Spitfire, I placed the switch, charge jack and air filler under a scale hatch behind the cockpit. The fuel filler was in the scale fuel tank cap location.
Scott
saramos is offline
Old 09-09-2008, 05:50 PM
Dig it
Dig it's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
saramos, where did you get the push on/push off switch?
Dale
Dig it is offline
Old 09-10-2008, 08:58 AM
Deadeye
Deadeye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built a scale luggage compartment on my TF Cessna 182. I will do something similar on my TF Arrow II. I can even refuel it from there!
ID:	1030228   Click image for larger version
Deadeye is offline
Old 09-10-2008, 09:40 AM
saramos
saramos's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wrote my response a bit misleading. I did not use a push-on/push-off switch in my Spitfire. I used a standard switch mounted inside a hatch I made in a scale location. I have seen others use a push-on/push-off switch activated by an antenna mast. I've picked up a couple of these switches at a local electronics supply store (All Electronics), but have not yet used them in a plane.
I also have seen where an antenna mast was used to activate a standard two position switch. Some switches have a small hole drilled into the toggle to accept an extension wire, or one could drill thier own. A length of piano wire with a small 90 degree bend in one end, is imbedded into the antenna and attached to the switch. Push the antenna down for one position, pull it up for the other.
Scott
saramos is offline
