New: Beech Baron and Duchess arf
#1226
CA
RE: New: Beech Baron and Duchess arf
What a beautiful Baron you have too! How did you make your seat belts and nose gear light? On my Baron Doors I used two robart nose gear hinges and the rear doors I used Brass hinges from a doll house store since I was unable to get the rear doors to work with the same range as the real airplane.
#1227
My Feedback: (9)
Great job Alpha! Speaking of the Benedini sound system, I too was thinking the same thing. I actually found a set of sound files for the Baron, while searching the net one time. We could give them to Benedini to make an audio file for the Baron!
James.
James.
#1228
Hey James,
nice to see you again! It' s really not nessesary to ask Thomas Benedini for a Baron-soundfile, because it's done:
http://www.youtube.com/watch?v=m9n5_R7oGUI
The prototype for the Baron...
#1229
ORIGINAL: Kevin Morris
For the seat belts I've choosed some gift tapes (? google-translater...) and the taxi-light is simply glued on the oleo strut for cooling (!) instead of a cooling body, which comes together with the landing light, cause it's going to be very hot !
For lighting please google "emcotec" -> "lighting" -> "landing lights" -> "12 mm Landing light" (direct-link doesn't work) , unbeleavible extreme bright SMD emitters.
Additional landing lights will going into the wings, like older Baron-styles - looks much more interesting on final aproach, I think...
The Brass hinges are the way to go - looks very "aviation-like" !!
#1233
In fact the Baron-sound file is one of the very best on the benedini hp !
Sounds like a beast within a lot of "bass-loading" !
The only thing I miss is the "prop-wash"-sound, as you can hear on the yt-vid below :
http://www.youtube.com/watch?v=w-5ln_m5BVE
#1235
Paul if you still have it ....Email at [email protected]
Regards
Regards
#1236
CA
Late to the party but I finally have this kit, still gathering the necessary pieces. Went through this long thread and collected a lot of valuable information, thanks guys! I plan to build the plane as light as possible, trying to see if Power 32 size motors will be enough. There is a low kv version over at HobbyKing which I'll experiment with 6s lipo. I have some other 40 size planes and several larger planes all running 6s, so it will keep my battery inventory consistent.
I've seen the weird up/down cycle issue of E-Flite retracts in person and on Youtube. Has anybody experienced that with the scale struts?
Ordered some 1 watt LED emitters which I had success with before. These are the only ones that are visible during day light.
#1237
CA
No issues with my eflite retracts and I have posted the retraction test here:
www.youtube.com/watch?v=moVIypEonIY
#1238
Hi folks,
Are those guys still in the business? Nobody answer my emails!
Someone can tell me the box size due to oversees shipment?
thank you!
thank you!
#1239
Hi there,
today I took her to the place for some adjustments,but I think, she is really heavy..
https://www.youtube.com/watch?v=OIc15pCQm2E
#1240
Hey guys,
finally I would like to share some pics from the last flights of this wonderful aircraft .
She is pretty on the heavy side, but landing is a breeze with extended flap range and added Vortex-Generators..!
I'm very happy with the result, tanks to all of you, who helped me to finishing this beauty !
Tank you Cliff for create this wonderful airplane !
cheers
Martin
cheers
Martin
#1243
Thx !
Thank you very much, guys !
Ron, I'm sad to hear of the sale !
It is one of the most impressive trim scheme in this thread !
Some of your Ideas will ride on in my Baron, the front geardoors ,for example , are made exactly in the same manner !
I've tried to make the Cabindoors interieur like yours, but I must admit, that it didn't work as well as yours..!
#1245
Hello, is anyone still building their Baron? I've had mine for two years and just now started building. I'm surprised about how well it's gone together. For those that have built and flown your plane; how did you mount the motors? Did you use set offs, or a mount like the great planes adjustable mount? I have the new electric retracts and boy are they nice. I also picked up the King Air prototype model but wanted to build the Baron first so I can see the similarities on the King Air without a manual.
#1246
jvance,
Although I no longer build the Baron, but I am prepared to the King Air to start to build,..!
My Baron is now in the winter storage, no flying weather here anymore..!
I have used a CNC engeneered Motormount, but the Great Planes adjustable mount also should work pretty well
Pay attention to the downthrust, 1-2° is not to bad !!!
The nacelles will give you an idea, if you look closer !
Sidethrust doesn't seem to be necessary..
The lighter you build, the better to land !!
(Micro Servos HV,f.e.)
Cheers
Martin
Cheers
Martin
#1248
Thank you, mike !
I wonder that it was so heavy ...
When I looked closer, I discovered that the rudder and the dorsalfin completely filled with epoxy in the field of their leading edge.
I removed these lead-heavy parts and replaced them with balsa !
savings: 116 grams !!!
All 6 30 gr. Servos were replaced with 20 gr servos
The torsion bars for the ailerons were removed, instead linkage in the wing panels
cheers
Martin
cheers
Martin
#1250
Hi Baron owners,
I took delivery of one of these beautiful (but challenging) ARF's yesterday. I have all components except the wing tip light housings had both been smashed in transit. I've emailed RC Aerodyne for replacements.
What is the consensus on the CG? The manual says 3.25" back, but others have said 4.5" back is around 4" back the compromise?
Any issues to look out for in the build.
Many thanks in advance,
Phil
Phil
