CD ScaleDesigns Albatros CI build
#2526
RE: CD ScaleDesigns Albatros CI build
ORIGINAL: gabriel voisin
you're right, the Mizer plan is ok, but the outline,the wings and the tail is not right, also the frames.
If the outline is not right, then you can still do so much, I'm not satisfied with a compromise.
Since I have so many detailed pictures of the restoration, I would go no compromise and would not please me, sorry but that's my personal opinion.
Your question about the outline:
First I will buy the Windsock Datafile, to compare the components with my drawings and my photos.
#2527
Anyway, maybe it's better to turn this back into an Albatros CI build thread which means I need to do some building! (But I'd like to see a LVG/Halberstadt thread). Here are the finished hinges. Well, almost finished. The aileron moves freely, but I'm wondering just how much travel the geometry of this lower wing servo setup is going to allow.
#2528
About the LVG model plan:
I can't understand why was glued another 4 square cuts on the frames , why is that?
I think it's better to do it of the same way as the original.
@GianFrancesco:
Thanks, but I need the Halberstadt CV Datafile with the No.69
Don, I agree with you,....we going back to the Albatros and the LVG / Halberstadt is now ready.
But I don't think, I will write a thread, ....so much work with words and photos,...lol.
You think the hinges hold on the balsa?
Matz
#2529
#2533
ON, CANADA
Don - I managed one further hour of flying therapy on this fine Sunday morning (6 x 10 minute flights during a two hour session at the field). October's a great month for flying here in Japan. I love to build, but flying ties it all together.
Don - I was just suggesting a thread where we could discuss these "planning stage" ideas.
I must admit I’m a little timid/reserved as I’m no where near as experienced a builder as either you or Matz. I will try to prove myself with my Morane Saulnier build. With all the detailed photos available we could certainly work up a beautiful fully scale model of the LVG. I am still infatuated with ‘Elenor’ and would love to create a 1/5 or1/4 scale model. I thought the Mizer plans were fairly accurate scale wise, after all he won the Toledo show back then, but now Matz has proven this wrong so it kind of takes away from scaling up those plans, burst the bubble. I guess we will have to redraft it all rather than mostly scale it up.
Matz, the Halberstadt is another neat two-seater, early on in 1916 isn't it? And a wooden trailing edge - not wire. It too uses the Benz Bz IVu engine, right? Don't the red rings painted on the cylinders indicate high/over (uber) compression or high altitude engine?
Don - the brass tube will be wrapped with the Koverall so there's little chance that the tube could pull loose from the aileron. As for the hardwood blocks in the wing, I think those are as strong as any hinge I've ever used on a 1/6 scale model
Don- It looks like maybe the sides of the model are first made complete frames (with 1/4" longerons and uprights) and then the formers go inside of those to made the fuselage shape
Cheers,
Bri
#2534
@Brian,
yes it's a two seater, the last and only Halberstadtaircraft in original.
Have a look at the photo, that's the wood trailing edge of the Halberstadt C.V
About your Morane,
you doing a good job, all is well.
Yes the red rings show there is a "Ü" engine / cylinder.
The "Ü" stands for "ÜBERKOMPRIMIERT" which means that it's an engine with a highly compressed piston / cylinder. The base of the Benz III or of the Mercedes III engine is ever the same, but the pistons and the cylinder are different.
But there are exceptions, for example, the Mercedes engine DIIIav who again other components.
@Don,
I think you're right, with Koverall it's ok.
I hope I could explain it well.
Matz
#2535
Freds Albatros,....
Freds Albatros,....
#2536
ORIGINAL: Flying Fox
Last October I was up twice a week for the entire month!
#2537
ON, CANADA
Yep - I just checked my flight log and yesteray was the first time up this month - not good at all. No wonder my first fligth in the friendly aerobatic contest was so terrible!
Sorry to hear about the flying on weekends only - that's brutal! Really limits things doesn't it? Any lawyers or insurance guys in the club? What do they say? What's the rationalle for weekends only?
I am very fortunate to belong to a small club and our field is out in the country in a very pastoral setting. We rent from a farmer and the only thing we have to worry about is the river floodoing the field in the early spring after snow melt. This is usually not too bad and in fact really adds nutrients to the field so the grass strip is alwayd lush. Biggest worries are to not hit a big willow tree, plough into a cow, or crash into the river which is immediately beyond the grass landing strip.
The natural landscape of Japan certainly is a distraction from flyiong isn't it? Where is this beautiful 'staircase to the heavens'?
I finished my tachometer tonight and will post in a few minutes.
Cheers,
Bri
Cheers,
Bri
#2538
Abu, slight diversion. I know CD Scale designs is not selling kits/ in business anymore. Did he not have a model of a JU 88? I am interested in this model and wondering if he may be talked out of a set of plans? Any assistance in acquiring contact info would be greatly appreciated.
#2539
#2540
ORIGINAL: vertical grimmace
#2541
You're right Don,
Chris asked me to model the canopies in Solidworks and it really took an incredible amount of time to get al these shapes right,
I think I still have a complete set of plans and samples (first 'draw') of most of the canopy parts, not planning to build one though,
Frank
Frank
#2542
ORIGINAL: Frank Sopwith
#2543
ON, CANADA
bucolic
The biggest dangers are not making back to the "carrier deck" and figuring out how to get models down from the tops of the bamboo.
Here's two photos of our field: the first taken late November from my flight camera looking over the river, the landing strip is lower right, the willow tree top center. Second shows the field in better light.
Cheers,
Bri
#2544
I'd love to fly of such a beautiful grass field. They seem almost unknown in Japan. I guess we all come to love the quirks of our own little fields.
#2545
Just curious, what was the size of this JU 88? I am really more interested in just the plans and not how the structure was engineered to be assembled. If I were to scratch build it, I would not attempt all of the mortise and tenon joinery used in a CNC cut kit. Not practical with a bandsaw. I am more in need of the outline of the aircraft, then I can engineer the internals to suit my building requirements.
So, any help with a set of plans would be awesome. I am really looking for something around 90", but I am sure I can blow them up or down depending on my needs here as well.
#2546
I don't recall at the moment, but it was on the "large" side...certainly over 2 meters and maybe more like 2.5m+ so that's in your 90" range. By the way, I'm shocked, SHOCKED that you have wandered away from the TRUE CALLING of building WWI models. [X(]
#2547
Oh, I have been busy with the heavy metal lately. I do plan to build a 1/3rd scale tripe this winter. Got this cool pic of my DVII the other day. Amazing how many pictures get taken at these warbird events. Nice to get a hold of one once in a while!
I have been honing the airbrush skills lately. I am thinking that is one tool that is imperative to scale modeling.
#2548
#2550
For the most part "weathering" on WWI aircraft seemed to be amount to making them dirty. Stuff like fabric stains and grit from grimy boots and hands. But a little selective rubbing with graphite or a dab of crusty paint can often too the trick for these things. They typically didn't last long enough to get "weather-worn" in the WWII sense. And the markings were often a little irregular looking so with an airbrush (and frisket) there's a danger of having the markings come out too crisp. I really like the look of my hand-painted roundels and don't think I would ever consider spraying them on any future model. But my hand is definitely not up to painting aircraft numbers and the like so there it's either friskets and airbrushing or decals and I think I'd prefer airbrushing.
On the Benz dummy I needed the airbrush to apply the metalizer and Al-clad paints. I also used it to good effect to get a "burnt" look to the top of the exhaust stack. And ultimately, it's silly to using a brush to paint stuff like the guns. So, yes, I know I need to learn to use my airbrush more efficiently...and more frequently. At this point, I'm just using a cheap hobby airbrush with air canisters.
