If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 110 of 115 FirstFirst ... 1060100108109110111112 ... LastLast
Results 2,726 to 2,750 of 2863
  1. #2726
    Join Date
    Aug 2007
    RiminiRN, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: CD ScaleDesigns Albatros CI build
    In my Alb. CIII i have the CG position at 22% of the chord of the upper wing; a bit nose heavy but a lot "safe" in particular in the landing
  2. #2727
    Join Date
    Dec 2003
    new baltimore, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Francesco,Is your Ciii a Darrell Hansen design.If so,what angles did you set the stab and wings?The wings have 2* dihedral and both wings are in line,no staggering-Jeffo
  3. #2728
    Join Date
    Aug 2007
    RiminiRN, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jeffo
    No, my Albatros CIII is from my own plans; 1/6 scale and all the angles , incidence and wash-out are like the original; the airfoil also is from original 1915 drawings.
  4. #2729
    Join Date
    Dec 2003
    new baltimore, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Francesco,What did you set the wing incidence in relationship to the stab.-Jeffo
  5. #2730
    Join Date
    Aug 2007
    RiminiRN, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As from 1915 J. Lagorgette drawings:
    upper wing +6Β°
    lower wing +6Β°
    Stabilizer +2,5 -3Β° (with possibility to adjust this incidence +/- 1,5Β°)
  6. #2731
    Join Date
    Dec 2003
    new baltimore, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Francesco,I measured the plans and came close to the same results.
    Both wings 5.5* pos.
    stab 2* pos.
    I was a little concerned with the wing incidence,but my guess is why they have so much incidence is because the airfoil is so thin.-jeffo
  7. #2732
    Join Date
    Aug 2007
    RiminiRN, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I believe that if my Alb flies so well in 1/6 scale in a bigger scale (1/4) it should fly only better
  8. #2733
    abufletcher's Avatar
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That would be my guess too. On my CI I'm just trusting the incidences that Chris used in his design. I know they are not "scale" but I know that Tom's CI flies well.
  9. #2734
    Join Date
    Aug 2007
    RiminiRN, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    In Italy we say "nessuno ha la veritΓ* in tasca" that sounds like "nobody has the Truth in his pocket"...
  10. #2735
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ain't THAT the truth!
  11. #2736
    US185Damiani's Avatar
    Join Date
    Mar 2002
    Watsontown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just a quick reminder,  The heavily positive incidence was due to the nature of the undercambered airfoils.  The had their own positive incidence built in.
    www.goldenageair.org
    Make sure you visit my good friend Mike O'Neal at
    www.michaelonealaviationart.com
    P-40 Brotherhood #44 TF Gold Edition Kit built in 2001, TF Red Box Kit still waiting on finish
    Sig Brotherhood #63 Sig Kougar, King Kobra, Komander, and 1/4 Scale Clip wing J-3
    P-47 Brotherhood TopFlite Red Box P-47 Spring Air retracts ASP .61
  12. #2737
    Join Date
    May 2008
    Kingston, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Also, at that time, climb rate was very important. It is less so for us as we stay on the ground and so are always adjusting the flight for our fixed vantage point. Most R/C fliers are more comfortable with less difference between the wing and tail incidences. However, the originals are perfectly usable if you don't mind using the throttle more for climb and descent.
    Martin
  13. #2738
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Step by step, experiment by experiment, the quest for the best looking covering goes forward. After multiple tests, problems remained with the silk-applied-with-PolyC approach. For one, the PolyC really doesn't function effectively as an adhesive to stick the edges of the silk to the underlying fabric. Second, no matter what I tried, I was still getting a sandy texture to the silk even after 2-3 coats of PolyC. It was as if the PolyC was somehow "raising the grain" on the silk. Also the PolyC seems to render the fabric+silk combination almost transparent (almost like yellowed plastic). But perhaps worse of all, when I tested the PolyC over the Polyspan I got both sandy grain and wrinkles (maybe caused by differential drying), so that was no good at all.
    So I went back to basics. I covered a test frame with Natural (uncolored) Solartex and then applied a coat of non-tautening Nitrate, then the moistened silk is laid down and smoothed out with a fingertip. And then more non-tautening Nitrate is brushed through the silk. And that seems to do it. Once the second coat of nitrate dope is applied, the rest of the weave can be filled with either PolyC or Butyrate instead of the nitrate (of which I have only a limited supply). This still isn't going to solve the problem of the black CF tubes showing through, but I may just have to accept that. I've done tests where I sprayed the frame with grey primer, but I'm not sure that's really an improvement. Actually the silk is fairly opaque after the first "thin" coat (as seen in the test piece towards the tip) but goes more transparent with further coats. I was hoping I could just add the PolyC after the initial doping to keep this more opaque look, but this creates an uneven look where the PolyC goes where the dope hadn't.
    I've added a couple small swatches of Solartex Linen and Antique for comparison purposes.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  14. #2739
    Join Date
    Aug 2004
    Lake Wales, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Why not spray a coat of wood colored paint over the primed CF rod? Then the see through framework would look quite natural. .......John
    2012 Blue Max contest and Fun Fly 28-29 Jan
    Sanford Aero Modelers Field, Geneva FL
  15. #2740
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Actually, on the original CI the entire stab, elevator, fin, and rudder were made of steel tubing which would have been primed and then the edges wrapped with fabric. And according to Matz, the original linen isn't translucent enough to see the structure anyway. So my covering solution isn't perfect in this regard. One of my test during this week was to add white paint to the PolyC before applying the silk but that resulted in it's own problems.
    This photo shows the test over the primered frame.
  16. #2741
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've also experimented with priming the frame with "rust" primer, white, and silver. The only thing that can be said for pre-painting the structure is that is at least all one uniform color. Also it IS possible to apply Stix-it (and dope) over the primer, through if you apply it heavily it eats into the primer, so thin coats are best.
  17. #2742
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tail feathers primed and ready to cover.
  18. #2743
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  19. #2744
    Teus's Avatar
    Join Date
    Jan 2007
    Friesland, NL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeb,
    Tail parts are looking great Don [8D]
  20. #2745
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The tail feathers are now covered with Solartex Natural. The next step will be to dope on the silk for the color. This shouldn't be as bad as covering everything again. It's more like "painting on the silk."
ID:	1825111   Click image for larger version.
  21. #2746
    Join Date
    Oct 2006
    Memphis, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It is too bad the covering is not just a little off of white. It would look like a plane new out of the factory. Looks good.
  22. #2747
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not really. German CDL wasn't yellowish from weathering. It was yellowish because the raw unbleached linen itself was beige/tan and this color was made even stronger by the varnish used. That is, the varnish gave a warm tone right out of the can. As near as I can tell the color of my test pieces covered with silk is what the aircraft looked like right out of the factory.
  23. #2748
    Join Date
    May 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Still it looks quite nice.. Reminds me of clear doped silkspan.
    Martin
  24. #2749
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The only parts still uncovered are the ailerons. I put off covering those while I looked into what material to use (Solartex) and whether I might consider making the structure more scale (no). Well, maybe no.
    Adding the silk will be a big job...but perhaps no bigger than painting would have been. But before I add the silk I'm going to give some further thought to how I might do rib-stitching with this "no paint" method. I made some interesting attempts earlier they were all a bit too crude looking.
  25. #2750
    Join Date
    Feb 2004
    Zentsuji, JAPAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    After thinking long and hard about methods for doing or simulating rib stitching, I've concluded that none of them are really satisfactory and/or compatible with my silk-CDL approach. I had some initial success reproducing the Z-shaped stitching but the were far too wide to be scale...sort of like having giant rivets on a WWII model. So for this model, I think it's best just to leave them off.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
