Metalworking tools and tips
For biplane builders the fact of life is that it's not all balsa and tissue and a competition quality scale model will almost always have a few bits made of metal. Sometimes quite a few pieces. There are assorted fittings and brackets but also entire panels. So I'm hoping that people will post here their favorite tools for cutting, bending, shaping metal and perhaps also some of their techniques.
RE: Metalworking tools and tips
Wouldn't it be great to have a company like this ready to do your every bidding!
http://www.thinmetalparts.com/
Does anyone has a source for odds and ends small metal parts? I did find this one:
http://www.smallparts.com/
I use pretty standard (and a few non standard) tools in the shop. I recently finished making strut ends and center strut brace for 1/4 scale J3 and L4. Some of it was done in brass most in aluminum. The thin stuff was cut with hand cutting shears and in some cases sacraficial sissors depending on how thick. My most used tools are a powered hack saw and verticle 1" belt sander for detail shaping. Gotta use pliers to hold the work and dip in water regularly. I plan on grinding out a tail wheel mount for the J3 and L4 later on. For really fancy stuff I use my lathe and mill. One of my jobs at work is prototyping, I have a small sheet metal shop I run at work. A 24" bending brake, 24" finger shear, corner cutter, power metal band saw, drill press and various hand tools. My most used tool is a dremel.
Edwin
Edwin
A hand seamer works great for precise bends of thin aluminum.
http://www.aircraftspruce.com/catalo...andseamer2.php
I use this to deburr drilled holes.
http://www.aircraftspruce.com/catalo...s/speeddeb.php
ORIGINAL: Edwin
??? Micro rivets? How small are these? Never thought of that before.
Edwin
Edwin
http://www.microfasteners.com/catalo...cts/TNMRVB.cfm
Rivets
http://www.rivetsinstock.com/rivet01.htm
Aircraft rivet identification
http://www.engineersedge.com/hardwar...act_rivets.htm
tools
http://www.averytools.com/c-2-riveti...ing-tools.aspx
Most general aviation planes use 1/8 inch shank rivets for exterior sheet.
Military would use next two sizes up.
Vans RV's use 3/32 rivets.
tools
i thought spikkkkk was really good at showing his craft at this....just one of his examples,
http://www.rcuniverse.com/forum/m_81...tm.htm#8406594
Question #2: Is lithoplate actually and different from the thin (0.1-0.5mm) aluminum sheet that is available in hobby shops?
I tested some K&S 3/16 stainless tubing to possibly build a Cub gear, the silver solder, Ungar 50w iron and Sta-Brite flux worked for me...............Mike
ORIGINAL: abufletcher
Question: Does silver solder work on stainless steel?
ORIGINAL: RcerMike
Here is Japan we have a real MAN'S MAN kind of silver solder. The kind that state that it melts have 650 degrees Celsius. Not that namby-pamby stuff that melts easily with a soldering iron!
Seriously, I couldn't live without my StayBrite type silver solder (3% silver I believe) that flows easily with a 100w iron. No more butane torches for this boy!
The aluminum I used for a full sized plane was usually between 0.020 and 0.032. I once used some 0.016 for skin on the vertical surface of a plane, but that was the thinnest piece I've ever used.
I don't know how thick the sheet aluminum that's available in some hobby shops.
Paul
ORIGINAL: pd1
I dug up a sheet of lithoplate. It's only 0.005 thick.
I think the big thing with lithoplate is it is cheap or free; the hobby stuff is probably the same except for the printing chemicals on it. Annealing makes it much easer to work with if it gets hard again re-anneal.
GA
Yes you can silver solder stainless steel .Dont let the stainless get red hot or it wont stick. you will just have to play with the temps to get it to flow and stick.If you do get it to hot just clean off the black residue and try again at a cooler temp it takes some practice to get it right
Having stamped parts from many different types of aluminum (back in my Tool and Die maker days) to really know what type of aluminum is being used, you need to know it's alloy number: 2024, 5052-H32, 6061-T6-T4, etc... For our purposes if your using it for panels some type opf soft aluminum is preferable (Beer Can stock) for functional fittings a hard aluminum should be used, such as 6061. Many hardware stores carry aluminum strip, and structural shapes such as angles, channels, Hs, Zs boxes etc. Whether the alloy is given, I don't know. Generally, a shaped extrusion would be a harder alloy, as strength is a requirement.
For metal working tools, I have an Aircraft Snips, Machinest Files, a drill motor and drills, various solders, soldering gun, pencil and torch and a vise. I also have a couple Ford Cutters for deburring holes. You can dump far more money into metal working tools, however, the above has done all I've ever needed in this hobby.
