Dual batteries
RE: Dual batteries
I would recommend 2 switches and then they can be plugged into any 2 ports in your RX. If you do not have enough ports (channels) you can use a Y harness and share with a servo. This is a very good idea in this day and age with 2.4 and lots of servos.
Hitec is offering the ability to run individual power for your RX now. So at least you will not lose RX power. this will be independant of the servos.
