Seidel 7-70 radial: Help me decide!
RE: Seidel 7-70 radial: Help me decide!
ORIGINAL: Airwarrior
Great looking plane, but Mr. Pilot doesn't look too healthy! Tell that chap to straighten up!
BTW, Teas, do you know if any of the guys using Seidels on their WWI models are using them with "collection rings" ("ringscharrdämpher")?
BTW, compare and contrast: 1) 1/4 scale EIII with $1000+ functional radial engine and 2) my 1/6 scale EIII with $25 dummy covering a $120 Magnum engine!
My Feedback: (9)
TX
Allright Don......will you PLEASE just forget the romance of and dreaming about, using the Seidel.......
Proctor had one in a 1/4 scale Neuport 28 that was successful and flew very well (Dick Hansen flew it & I have a video of it)
Charlie Nelson used that engine successfully in a Waco model that was in a lot of contests including Top Gun. He found the engine very reliable.
I had one of the original ST-770 and it was a beauty. But I, like everyone else, admired the craftsmanship then ran it and marveled at how well it functioned before I put it up to display it.
I had the intentions of putting it in the Proctor N28 because the design of the model was well suited for adapting that motor to it and Proctor had a motor mount available for it.
My 2cents
My 2cents
#31
Don a G 38 is way more than adequate for a pup, The Seidel would be a treat in one built with the nose the correct length though and ballast probably wouldnt be a requirement. It would take throttle management not to fly the wings off it though. The reduction drives you keep mentioning are really for 1/3 scale models where a 30 inch prop is desired. One turning a 24 or 26 inch prop on a 1/4 scale would be perfect as most of the rotarys spun an 8 foot prop.
Doc
Doc
#32
ORIGINAL: Reg Hinnant
In terms of scale appearance, as I illustrated above, a good quality dummy engine will be more scale than the Seidel (but the Seidel definitely looks more scale than any of the other radial engines). But there's a certain scale quality to having a functioning round engine even if it's not quite scale. Curiously, I find the 7-cylinder 770 to look "more scale" than the 9-cylinder Seidel. The 990 just looks "too busy" in a WWI cowl and looks more like a Pratt and Whitney. The space between the cylinders on the 770 gives more of the impression of the space on a 9-cylinder LeRhone or such.
http://www.youtube.com/watch?v=FaOki5eGvy0
#34
ORIGINAL: BobH
Don, I got an email from Hobbyking. They have a Seidel 770 radial in stock for $1199. You can check it out
#35
So here's another way to think about it (i.e. another way to rationalize the purchase). The Seidel might cost me $1000 but if these engines have a pretty good resale value so even if I only got $500 for it down the road, I'll still only have paid $500 for the fun of flying with one. And if I do decided to keep it longterm then $1000 is not such a bad investment for a guy who loves WWI models.
#37
Do I at least get to run the engine? Or do I just have to stare at the box? I'll be selling my Leica (hopefully this summer) and I imagine I'll end up losing perhaps $300 on the deal after a few years. But that's well worth it for a chance to shoot with this legendary camera. I figure the Seidel will be similar. That's assuming, of course, that I don't fly it into the ground, which is always a possibility. Not much chance of that happening with a Leica!
#38
Sometimes you just have to bite the bullet and go for it [sm=thumbs_up.gif]
Just get it and enjoy! Or save it for that special model down the road.
Chances are the more you contemplate it, the harder you might be able to justify the investment.
On the subject of what model to power, the following might be a useful reference:
An article in the may issue of RCM&E mentions a 1/3 scale (153", 50 lb) albatross CIII powered by a ZG 62 fitted with a reduction drive.
The ZG 62cc power output is 4.3 hp (standard silencer) or 6.6 hp (tuned pipe).
On that basis the 4 hp ST 7-70 might be a slight overkill for anything but a very heavy draggy 1/4 scale but then again it doesn't need to be flown full blast, and it would certainly help with the balancing!
#39
ORIGINAL: Trev
Thus: I deserve a Seidel!
#41
I suppose it's only fair that I should also throw out my biggest CON: It makes no sense to buy such an expensive engine with the intent of only using it in ONE model. You'd just HAVE to imagine putting in into several different models over time. But that sort of presupposes that the model isn't going to last very long and then you could just take the engine out and mount it in the "new" model. This is the sort of thinking I had back when I first started the RC hobby and thought I could get away with only one engine and only one flight pack. I never imagined I have more than one RC model...at a time!
And we all know how that works out. I think my current count is 3 x Saito 56, 1 Saito 72, 1 Saito 82, 1 RCV 91cd and a couple of now no longer functioning (I think) Magnum 52s and that original Magnum 2 stroke I used on my trainer, i.e. the "only engine" I thought I'd ever own. Most are currently already in a model.
Strangely "the sound" is not such a big deal for me. Both Gas engines and 4-strokes sound pretty good. And once it's up there in the air on the far side of the flying field you can't hear much anyway, particularly if you're flying the thing a 1/4 throttle. I don't really care much what it sounds like on the ground.
#42
Not that it matters in my case, but I'm curious how scale judges would treat a "authentic looking" radial engine vs. a "scale accurate" dummy. There's no doubt that a well done dummy will look more scale than a Seidel, which to my eye is by FAR the most "scale" looking in terms of WWI of any of the radial engines (except maybe a Saito R3 for something like a Bleriot). The "realism" of the Seidel comes from the fact that it's a real "round" engine.
#43
I have never pondered how a scale judge would treat a real but non scale radial, interesting question.
I had the opportunity in Dec 09 th help hold down the test stand while Robert Cooper ran his 1/3 scale Bently rotary at the Southern Dawn Patrol in Andersonville Ga. A truly awesome display. They're not easy to install and operate in a scale model as a lot of access is required to the rear of the engine for priming and starting, and operation. It is installed and flying now in a giant Antic, a sight and sound to behold. I operate a 5 cyl in an exposed installation on the front of a 1/4 scale Mohawk Pinto, the sound at the far side of the pattern is still that of a radial, it's unmistakable. I've never heard the Seidel run but I can only imagine it makes a wonderful noise.
Doc
Doc
#44
ORIGINAL: geezeraviation
http://www.youtube.com/watch?v=is1Uj3zMato
#46
My Feedback: (9)
TX
OK Don,
You have convinced me. Sell the damn Leica NOW!
Lets get the Seidel ordered!
You don't need no collector ring cause oil should be oozing from all crevices of that round cowl or better yet the exposed engine......
Come on, do it....we are waiting!
#47
#48
My Feedback: (9)
TX
OK Don,
No hesitating now!
The videos are still available from Dick Hansen at http://www.hansenscalevideos.com/list1.shtml
The ones you would be interested in are #16 for Aerodrome 92 (sounds of the "real" ones....full size)
#22 for the "Visit w/Seidel Motornebau" lots of runnung shots with exhaust sounds. Also flying videos of Proctors N-11, N-28, JN4, DVA
#28 Aerodrome 94
#67 Directors cut of Young Indiana Jones filming
We will have to ask which # has the N28 flying with the Seidel. BTW once you see/hear this your mind will be made up FIRMLY. Bye Bye Leica [&:]
No hesitating now!
#28 Aerodrome 94
#50
Maybe not the bomber version but I'd definitely be interested in doing a GIII. And can you imagine what a stunning model it would make with a 9.5" diameter radial engine! On the other hand, figuring out the balance with a 2.6kg engine might be a challenge.
