Seidel 7-70 radial: Help me decide!
#651
RE: Seidel 7-70 radial: Help me decide!
OOPS. Deleted my prior post since it's 2am and I wasn't really the scale correctly! See correct weights below.
I just weighed the entire assembly of engine, mount, exhaust ring, and propeller...and came up with about 3.2kg. The engine and mount together weigh 2.7kg, the ring weighs 320g, and the 24x10 propeller weighs 146g.
#652
ORIGINAL: abufletcher
Here's the extremely prompts email reply from Kevin!
Hi Don,
I took a look at the pictures and you are looking great, after the ring is
on the angle will be correct. I would suggest at this point if you could
screw the engine down to a bench or to a board that you can clamp to the
bench you would have both hands to work with.
Once you have done this grab the tailpipe and give study pressure in the
direction that the ring needs to go onto the engine and align one stack into
it exhaust port and with a wooden stick use the other hand to gently pry the
next header over into place and as it goes into place you will notice that
the first header you started now is farther into its hole. Each time you do
this the previous headers go farther and farther in. Keep doing this and on
the about the fourth or fifth one the ring will just fall into place.
They are tricky to get on and it seems that there is no room between the
header pipes and the intake pipes but once it is on everything has clearance
and alignment is correct.
Let me know how it goes for you. I looks like I will need to add this
information to the directions.
Kelvin
Hi Don,
Kelvin
Following Kelvin's advice, I bolted the engine back onto the test stand so that I could use both hands to massage (muscle?) the ring's headers into place. After getting them all roughly aligned, I applied firm counter-clockwise pressure on the tailpipe and could just manage to get the lip of one of the headers into the cylinder. Then with a bit of effort, I got a second one just barely in (and the prior one slipped just a hair further in). I needed to use the piece of wood to leverage some into position...but not too much pressure on the stick. It's sort of like fiddling with one of the metal puzzles where you have to get the two pieces together and it seems impossible, but there is a way...one that doesn't require brute force.
And then they are all in. The next challenge is to get the nuts seated right. I'm still battling with that as it's hard to know how they are supposed to feel. Some seem to thread in easily enough for the first half or whole turn, but then get really hard to turn by hand. I'm hesitant to use a wrench yet.
#654
It took a LOT of patience, but I finally got all the nuts threaded. Part of the problem is that when you do this for the first time (and basically everyone will be doing this for the first time) you don't know how it's supposed to feel. I needed to loosen some of the cylinders a bit more and then it was a matter of wiggling (the cylinders) and trying and trying again. Three nuts went in pretty effortlessly but the other four were difficult to get started. It helped to turn the engine face down (but being careful not to let it rest on any of the push rod tubes).
Anyway, that's done...AND I'M NOT DOING IT AGAIN!
#657
My Feedback: (23)
So whats prop manu, size and rpm is everyone running? Ive been having a heck of a time finding the right prop.
Menz ultra 24-12 = 5200rpm
Above cut to 23" dia= 5300rpm
Cut down to 21" dia = 5700rpm
Cut down to 20" dia = 5900 rpm
JC Super props 20x16 = 5600 rpm
Im About to pull this motor off my fw190 as its life expectancy is only as long as it takes one cylinder to die shortly after takeoff. So bcof that, im going to put it on a 1/4 geebee R2 that will weight around 22lbs.
#658
Sorry to hear that Thomas. Multi cyl glow engines do seem to have thier problems. What I find a real bother is once a cyl drops out even reducing the throttle to where the glow lighter comes on (if you have the altitude and room to do so) they still dont come back to full power.
Doc
Doc
#659
Are you running an on-board glow system? If so, what would make you suspect that you might have a cylinder "die" on take-off? I did have one "cold" cylinder (the bottom one) during some early break-in runs but they all seem to be running now. In the model I'll use the MICROSEN controlled on-board glow, which should keep all cylinders going even at near idle.
The recommended break-in prop for the 770, according to the manual is a 22/10 and that's what I've been using. My engine is still undergoing break-in but I've had it up to 5500. I picked up a 24/10 (XOAR) to see how that works.
#660
Hi Thomas,
Your rpms sound about right. And I have never had a cyl. Die on me. I, too, use the microsens GLOW 7 LP and it is great!
Cheers, Martin
Cheers, Martin
#661
My Feedback: (23)
Im using the mcdaniel onboard glow system. I havent had a cylinder die once they all came on line after warmup and start. The problem, is the airplane is so marginally powered right now, that if anything happens power wise from liftoff until 1 lap into the pattern has been completed, the airplane is going to be a right off. Because of that (and other projects) my 190 is being sold w/o the motor and im planning to put the motor in thd geebee.
I was hoping to get around 6100-6200rpm static so as to get as much performance from the motor as possible. But currently, my home made cut down prop is the only thing i have found that works well with the motor. And since that prop is no longer made, im stuck in a tough spot if it ever breaks
#665
My Feedback: (23)
ORIGINAL: BobH
Thomas, have you ever considered a 3bladed prop for the FW? Just wondering here is all. I have yet to run mine..
#666
HI Thomas,
I remember us talking on this forum before about it. Just seems like a bad fit. Biplanes, slow flying monoplanes that are built in a very light way are about the target group for the Seidel. Their power-weight-ratio is horrible!
If you want to go radial and WWII warbird, MOKI is the way to go! the guys fly Corsairs, FW190s, Grumman -cats, Lavochkins here in Germany with that setup. Absolutely awesome sound and performance. They even fly Sukhoi aerobatics with it and hover them! How about a small MOKI for your FW 190?wouldn't that fit?
Also, I saw that MOKI is making a 7 cylinder radial now.
Cheers, Martin
Cheers, Martin
#667
I've also come to realize that my BIG engine doesn't equate to POWERFUL engine. The Seidel 770 is probably in the 45-50cc class, and weighs close to twice as much as comparable gas engines. But for slow-flying WWI biplanes with relatively short noses, where you can see the engine in that big old round cowl, there's nothing better.
#668
My Feedback: (23)
Martin,
Unfortunately the seidel 70 is the only radial that will fit in my 190. The cowling is only 9.22" in diameter and the seidel is 9.128" at the rockers. Like glyou say, i think the seidel will do better in a lighter plane or a slow biplane. Hence the reason for trying a geebee
#669
Sorry Don... the "best thing" would be an actual Rotary engine in a WWI bird !!! lots of machinists have home built them don't think anybody is mass producing....what a dream that would be... ehh??
Just think of having to muscle with all that torque on take off like the real thing..
#671
ORIGINAL: geezeraviation
I have seen a Clerget a Gnome and a Le Rhone but all in 1/3 scale. Never seen one as small as 1/4.
Doc,
You need to take a look [link=http://www.modelbouwforum.nl/forums/vliegende-schaalmodellen/84686-rotarys-bij-phantasy-blue-9.html]HERE[/link] on a dutch forum [8D]
Two 1/4 scales Gnome's are currently build and almost finished. One intend for a "Brik" (pusher version) and one for training on a Proctor Fokker E.III [8D]
#674
Doc, How about this, a 1/5th scale [X(]
[youtube]http://www.youtube.com/watch?v=oLW_6XCvBWI[/youtube]
#675
Just read all the pages of the thread, phew!
Woz like reading a thriller, enjoyed every bit of it, thanx to the authors
I love 4 stroke, even more so if they're radials. Still have a "50cc" 220cm (86") GW Yak-55M in the box, looking for an adequate, but non DA, DLE, RCGF, etc, engine. It has to be 4 stroke, minimum of 2 cylinders, the more the better.
The Seidel/UMS would provide adequte weight, size and power for limited 3D, mostly scale aeros type of flying.
The big - is glow... decide a few years ago not to go back to them... but who knows...
The big + is the cost. The Seidel also seems reliable, power output is good, and it is pretty easy to set-up and operate.
Also had a look at the RCS/Mokis, problem is that their smallest radial starts at 150cc which would be slightly oversize....
invertmast, loved your 190 with the Seidel. Beautiful video (ok, the pilot is way better than the cameraman).
The 190 looks really scale, also performance wise. The take-off run, the climb angle and the speed look very realistic. Guess I'm a bit fed up with scale looking planes leaping of the ground in a couple of feet and then climbing at unrealistic angles in the blue yonder....
Looking forward how the Seidel performs in the Geebee.
