TA 152H Meister Scale Project Grun 4
Reply
Old 02-28-2012, 08:10 PM
  #651
t_burley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: TA 152H Meister Scale Project Grun 4
use some G10/Fliteskin against the vertical fin
then do your fillet
t_burley is offline
Old 02-28-2012, 08:18 PM
  #652
David010567
David010567's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: t_burley
then do your fillet
Good idea. I was planning on taping it off, then back filling the raised areas with body filler after I sand the first coat of primer. (Like I did Rita)
David010567 is offline
Old 02-28-2012, 08:20 PM
  #653
t_burley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea, use the G10 or light ply, save some time.
you can pay me later
t_burley is offline
Old 03-05-2012, 10:03 AM
  #654
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 4 steps of AGONY....
Step #1 Mark and tape Stab Fillet area.
ID:	1735353   Click image for larger version
Old 03-05-2012, 10:07 AM
  #655
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Step #2 Apply fresh MicroLite to Stab Fillet area with pallet knife.
ID:	1735355   Click image for larger version
Old 03-05-2012, 10:09 AM
  #656
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Step #3 Sand affected area until your finger prints no longer exist.
ID:	1735357   Click image for larger version
Old 03-05-2012, 10:19 AM
  #657
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Step #4 Remove tape and repeat Steps 1-3 for other side.
ID:	1735361   Click image for larger version
ID:	1735362   Click image for larger version
ID:	1735363   Click image for larger version
Old 03-12-2012, 07:01 PM
  #658
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Been trying to finish up the tail...
1. Filled and sanded the fin sheeting to blend into the fuselage in the area behind the stab.
2. Shaped and rounded the Fin.
3. Sanded, beveled and hinged the rudder to match the fin post.
4. I'm getting about 3-1/2" travel in each direction. About 35 degrees.
5. located the exit's in the fin post for routing the pull-pull cables.
6. Started rounding the bottom of the Fuselage.
ID:	1738185   Click image for larger version
ID:	1738186   Click image for larger version
ID:	1738187   Click image for larger version
Old 03-12-2012, 07:21 PM
  #659
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have just the thing to put on that rudder too....
pandissix is offline
Old 03-12-2012, 07:34 PM
  #660
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: pandissix
Tell us more about this gizmo. How does it work? Will it Hover better?
Old 03-12-2012, 08:02 PM
  #661
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hover? LOL...
once you see this gizmo in action....your going to be running to the LHS to put one in Rita....trust me....crosswinds no longer a problem....
Old 03-23-2012, 07:07 AM
  #662
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Update... Switch panel box complete. I decided it wasn't necessary to make the back panel removable because it's easily accessible from inside the fuselage.
Old 03-23-2012, 07:14 AM
  #663
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuse was cut exposing the exhaust stack bay I previously built into the fuselage. I used my 3-views to come up with a 1/32" plywood inlay to simulate the sheet metal around the stacks. I then sanded an angle on each resin stack and drilled them to accept a 1/8" dowel for locating the stacks. The 3-views show the stacks at non equal spacing so I tried to duplicate the best I could. Weird.
A lot of work but I think they look pretty awesome. Should be very convincing once painted.
ID:	1741716   Click image for larger version
ID:	1741717   Click image for larger version
ID:	1741718   Click image for larger version
Old 03-23-2012, 07:21 AM
  #664
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gotta finish the stacks and fuel-up panel on the other side, then on to the gun hood....rrrrr... non-gun hood, what ever you want to call it.
Old 03-29-2012, 06:56 PM
  #665
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More progress on "The Pit"...
I made the floor out of Lite-Ply and built the side panel consoles to fit. I put some lite-ply and a dowel on the back of the hand crank thingy plus some balsa on the right side of the pit for the hand crank to plug into.
ID:	1744425   Click image for larger version
ID:	1744426   Click image for larger version
ID:	1744427   Click image for larger version
Old 03-29-2012, 07:00 PM
  #666
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Basic carpentry is done. Trimmed the seat to fit flush with the canopy deck, ground the bottom of the control stick to lower it down.
It's all gonna fit! Gotta get after the top instrument panel next.
ID:	1744429   Click image for larger version
ID:	1744430   Click image for larger version
ID:	1744431   Click image for larger version
ID:	1744432   Click image for larger version
Old 03-31-2012, 07:14 AM
  #667
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Turned out nice DD. That kit was not PnP for sure...so shoe horning it in turned out well.
Old 03-31-2012, 07:21 AM
  #668
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DD-Now just hear me out now....I have been kicking around the idea to going Electic on this project. No I dont have TBI from AFG...if your concerned.
Kick around some ideas of putting in a Lipo Box with access panel. Maybe the "frankenstein" Gun hood area can be a removable hatch, although may be too far AFT for CG.
Pros:
1. I have the lipos already
2. I have the support equipment already.
3. Clean cowel lines with no cutouts.
4. No fuel mess.
5. Less hassel with fuel lines, tuning engines, clean up.
Questions:
1. Flight times (TBD)
2. Hatch access
3. Making sure the spinner can be used.
Old 04-01-2012, 11:52 AM
  #669
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW! Totally doable.
Find out what those Goodwine boys where using in those electrified 100cc extras they had. The gunhood is way too far back. The only option for the batteries is where the fuel tank goes. Prolly have to pop the wing off to get'm in before flights but there is lots of room in there.
ESC might need a scoop for cooling. Maybe the scale carb intake scoop could be used?
Old 04-01-2012, 11:54 AM
  #670
t_burley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heres what ya need
http://www.aero-model.com/Hacker-Brushless-A200-8.aspx
t_burley is offline
Old 04-02-2012, 04:09 AM
  #671
vik
vik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would love to see it eletric.
From Mick Reeves site on his 1/4 Spit
Pete Ford. 16 1/2 kg turnigy C80100 2x 12s, 5000mah 24x12 6500rpm 6 1/2"
Mick Reeves 15.85kg turnigy C80100 2x 12s, 5000mah 24 x 12 6700. 6 3/4" 17 1/2 kg thrust
vik is offline
Old 04-02-2012, 06:23 AM
  #672
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes I am really considering this option.
David- Lets do some more head scratching on a access for the Lipos. I really dont want to have to take the wing off....its a pain with the 262 and SeaFury when I do this. I wont be going to Top Gun with this one or Scale Masters...just local shows....so to lose some of the scale lines with a hatch is acceptable.
Todd- Anyone converting the retracts I have from SGS over to electric yet? Opinion?
Old 04-02-2012, 06:30 AM
  #673
t_burley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea Rich, down and locked can convert the gear for sure.
the motor info I posted above is what I will be using on 2 upcoming
projects
t_burley is offline
Old 04-02-2012, 04:37 PM
  #674
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuel tank area is ginormous. We can put a hatch just behind the firewall above the fuel tank compartment.
Old 04-03-2012, 12:54 AM
  #675
vik
vik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is the hatch on 1/5 one:
very easy I can fit in 2x6S 8000mAh packs - http://www.hobbyking.com/hobbyking/s...dProduct=19718
vik is offline
Reply
Display Modes
