TA 152H Meister Scale Project Grun 4
Reply
Old 04-10-2012, 06:37 PM
  #676
David010567
David010567's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: TA 152H Meister Scale Project Grun 4
Made some 1/32" plywood side panels under the windscreen, trimmed the can-o-pee, started the beginnings of the "Flathead Frankenstein" gun hood.
I gotta admit... It's starting to look pretty wicked.
ID:	1749104   Click image for larger version
ID:	1749105   Click image for larger version
ID:	1749106   Click image for larger version
David010567 is offline
Old 04-19-2012, 10:28 AM
  #677
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One Freak'n, Freaky, Frankenstein gun hood finished. Got the right side fuel fill panel box installed as well.
ID:	1752385   Click image for larger version
ID:	1752386   Click image for larger version
ID:	1752387   Click image for larger version
Old 04-19-2012, 10:50 AM
  #678
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow DD.....that turned out very nice. Sweet!!
pandissix is offline
Old 04-19-2012, 10:54 AM
  #679
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanx Bro! Gotta get back on the cockpit, make the sun visor for the instrument panel and finish up a few more fitting details in there.
Old 04-19-2012, 07:22 PM
  #680
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The beginnings of the anti glare screen over the instrument panel. Several tries and now somehow it all fits. Wheew!!
ID:	1752550   Click image for larger version
Old 04-20-2012, 10:57 AM
  #681
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Drilled out the gun sight bracket for a toothpick support. Added ledgers for gluing the upper instrument panel. finished up the anti glare visor with a little extra support.
ID:	1752725   Click image for larger version
ID:	1752726   Click image for larger version
ID:	1752727   Click image for larger version
Old 04-20-2012, 11:01 AM
  #682
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Slit some old phone cord for combing, fitted the Gun sight, hand hold holes, more trimming... Anti glare sun visor finished.
ID:	1752729   Click image for larger version
ID:	1752730   Click image for larger version
ID:	1752731   Click image for larger version
Old 04-20-2012, 11:40 AM
  #683
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Man this thing is turning out so nice. I better cool it with the details or Pandi is going to kill us at the scale meets.
Old 04-20-2012, 12:37 PM
  #684
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's the plan.
Old 04-21-2012, 03:02 PM
  #685
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: David010567
Thankfully there is a BOM rule!
vertical grimmace is offline
Old 04-22-2012, 06:18 AM
  #686
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BUM BUM rule is more my speed
Old 04-30-2012, 06:02 PM
  #687
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So... I got all the gear door parts made now and I'm starting to trim everything up. Pretty happy with how nice and flat they lay down. I'm thinking I should get the gear leg doors mounted before final trimming of the inner belly door.
Man I'm itchy!!!
ID:	1757223   Click image for larger version
ID:	1757224   Click image for larger version
Old 05-01-2012, 10:16 AM
  #688
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the fiddly little bracket I had to make to support the bottom of the lower gear door. Grrrr!
ID:	1757498   Click image for larger version
Old 05-01-2012, 07:29 PM
  #689
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bear with me as I work this all out... I counter-sunk the screws that hold the brass bracket so the doors lay flush. I had to grind off a little of the strut as well.
Old 05-01-2012, 07:33 PM
  #690
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Started locating and drilling the lower gear door mounting holes. I cut a plywood inner liner from the supplied kit doors. I'm thinking I should glass the door liner to seal everything up nice.
This is gonna look great!
ID:	1757694   Click image for larger version
ID:	1757695   Click image for larger version
ID:	1757696   Click image for larger version
Old 05-03-2012, 09:48 AM
  #691
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gear doors are final trimmed, drilled and the inner plywood liner installed using polyurethane glue. It's really amazing how the 1/32" plywood stiffens up the gear doors. I glassed the plywood just to seal the wood for finishing.
ID:	1758202   Click image for larger version
Old 05-03-2012, 11:43 AM
  #692
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Keep the template for these. I've been known to nick a few of these.
Old 05-03-2012, 12:30 PM
  #693
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The lower big door will be functional when I'm finished and slide up when the oleo is compressed. You won't nick these unless you loose a tire or nose over.
Old 05-03-2012, 01:12 PM
  #694
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the design I'm trying to achieve from the David Anderson plans.
Old 05-03-2012, 01:15 PM
  #695
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I still have to machine the slot in the lower door and make some small threaded stand-off's for the strut brackets. More on that later tonight.
Old 05-03-2012, 01:21 PM
  #696
pandissix
pandissix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice touch. Sounds expensive ;-)
Old 05-03-2012, 05:47 PM
  #697
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's my idea to attach the gear doors.... I sheened this little 1/4" diameter coupler and threaded it with a 4-40 tap. I can now use a 4-40 screw to attach the door.
Relax Pandi.... They are not silver hollow points. LOL!!
ID:	1758387   Click image for larger version
Old 05-08-2012, 06:43 PM
  #698
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Update... Here are the gear doors mounted for the first time. I turned all the little stand-offs down to .200 diameter to match the gear door clamps. I also left them all a bit too long for adjustment at final assembly.
You might ask... Why all the trouble, just use a brass tube as a sleeve? Well... With a brass tube over the screws you would have crank down on the screws to tighten the strut door clamps thus crushing the gear doors. Capiche?
Pretty proud of my new sheening efforts.
ID:	1760587   Click image for larger version
ID:	1760588   Click image for larger version
ID:	1760589   Click image for larger version
Old 05-08-2012, 06:46 PM
  #699
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe we can use a piece of fuel tubing between the standoff and the gear door for a shock mount? hmmm?
Old 05-08-2012, 06:59 PM
  #700
David010567
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We should get some 4-40 countersunk screws and counter sink the gear doors so the screws sit flush.
Reply
Display Modes
