TA 152H Meister Scale Project Grun 4
#726
CA
RE: TA 152H Meister Scale Project Grun 4
ORIGINAL: pandissix
Cool. I will take one 12th SS Normandy pocket Panther. Panzer Myer. Make it happen.
#734
CA
ORIGINAL: t_burley
ya freekin hack, this is all you have done since building the ARF?
#737
My Feedback: (59)
CA
since you got Pandis' dash all done, I'm mailing you my 1/5 scale
kit to detail as well.................I mean after all, you have this down now
#738
CA
ORIGINAL: pandissix
Nice DD.
Nice DD.
#739
CA
ORIGINAL: t_burley
#741
My Feedback: (134)
CA
We're going to have to do some spying on the Burley skunk works...I think there some big electrics going in his AOR. Get some ideas on mounting that motor.
#742
My Feedback: (59)
CA
yea, we'll get ya setup.
I got enough electrons up here to start a tig welding business
with all these high energy planes I have under construction.
glad Homeland Security hasnt come by yet after me buying
all this wiring, connectors, LiPo's etc [X(]
#743
CA
Here's a 100cc flip flopper with a big Hacker. Looks like he stacked the standoff's and mounted the batts in the tank area.
I will just machine some custom standoff's.
#745
CA
ORIGINAL: t_burley
#746
My Feedback: (23)
ORIGINAL: David010567
Whatever they charge for the pre-painted panels... Trust me... It ain't enough.
ORIGINAL: t_burley
+1 i bought the "kit" version for my 1/5th 190.. i'll definitely pay the extra $$ for the finished version on my 1/5 TA-152 kit.. 5 days of cockpit assembly is allot of work.
#747
CA
I found some more pictures... Here's a A150-10 mounted in a Hanger9 Pawnee where a DA-85 should be. Looks like standoff's are our only option. Notice that the ESC is mounted inside the cowl.
Where do we want to mount our ESC?
Do we want a special tray to support this thing under the cowl?
Or... Mount the ESC in the fuse and add vent holes? ... bla bla bla
#748
CA
The prop / spinner / back plate mounting is going to be one big headache. The heavy duty back plate + prop + prop washer is so thick that it eats up the grip of the prop bolts and prop shaft. A new prop shaft extension and longer bolts are going to be needed. Grrrr!!
#749
CA
Here's what I'm thinking...
We mount the Pop Tart down low on a plywood tray and put a small rectangular cheater hole under it.
Du verstehst nicht?
Du verstehst nicht?
#750
My Feedback: (134)
CA
DD
I think that's where the Pop Tart should go. That we're I have it in the Sea Fury with no problems.
Send me the link to where you got the photos of the install. I need to see how he wired up his ESC. Hacker has dual positive and negative leads. Which has me confused. I'm use to Castle. Any help here is appreciated. Manual is worthless
