T-34 3 view
Does anybody know where I can find a really good 3-view of a T-34B? I have the Bob's one and its ok, but I was hoping to find one with full panel lines and rivet details. Thanks!!
RE: T-34 3 view
Have you done a web search using www.dogpile.com ?
You can also go to www.abebooks.com and type in the keyword block of there search engine and it will find books that may help. You may have to type in T-34 Mentor to find specific books. Good luck & have fun!!! [&:] |
RE: T-34 3 view
Well, unfortunatley Doug, those sources came up empty, but thanks for the suggestions. Thje suggested books I already have. I have a bunch of photos of thee plane I am building but I dont want to have to go through and count the rivets adn panel lines. I guess I might have too!!![:'(]
RE: T-34 3 view
Go back to www.dogpile.com and type in T-34 Mentor again. Go through the stuff that pops up. Look for the references to the manufacter BEECH Aircraft. Item 4 or 5 I think. If you can find an address or phone number, contact them. Sometimes the manufacters can be very helpful, but make sure you explain to them what you want and why. And it may cost you a few dollars. Wouldn't hurt. Also Item 36 that popped up on the second page, Trump's Hobbies. There I found a model built buy Mark Frankel. He offers detailed three veiw drawings for about fifty dollars. Check it out !!! [&:]
RE: T-34 3 view
1 Attachment(s)
I have a good set a have a T-34C satio 120
RE: T-34 3 view
One of the best places for 3-views i've found is: www.airpictorial.com .
This outfit is in Britan & has a wide range of different aircraft drawings. I got some nice dornier & Messerschmit 3-views. They are printed on a slightly larger than 11x17 sheet(s) drawn at 1:72 scale. Panal lines & some rivet detail on the Messerschmit, don't recal on the Dornier. Cost was pretty reasonable & shipping moderate. I DID NOTICE that they have a listing for a Beech t-34 Mentor.;) |
RE: T-34 3 view
I ordered the ones from Brittain, thanks for the info omcusnr!!! Hopefully they will be better than the Bobs ones!! Thanks cap21r, but I am making the B model. I might be able to reference the flight surfaces corrugations though.
RE: T-34 3 view
I have several views of all Mentors if you need there are many
RE: T-34 3 view
How big is your plane
