1:35 Scale RC LCVP Help!!
Hi there,
I have a RC 1:35 Italeri LCVP. Its been out of commission for about a year as I needed a small enough battery to fit it but, having got one, I can't get it to run now.
The boat is running of a Cirrus 4 channel 40mhz fm receiver with a 300mAh 6v battery powering it. However, after connecting the battery, I get no responce to both the propeller and the rudder. Can anyone help?
Sea Dart!
Sea Dart!
RE: 1:35 Scale RC LCVP Help!!
You charged the boat battery?
The boat battery is new? or you tested it?
Boat battery plugged into the receiver correctly?
Battery in transmitter charged? and or replaced?
Did you check to see if the propeller and rudder turn freely?
Thanks for your help but its all sorted now, just a few loose wires and the bar from the servo to the rudder was slightly too long. All sorted now though so will test her tomorrow and get a few pictures and video's taken
