RC Scale Boating Enjoy rc scale boating? Talk about it here.
Dumas 36" Chris-Craft Runabout Build
Reply
Old 10-14-2011, 05:46 AM
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dumas 36
Ok guys,
I have coated the inside of the hull with a nice coat of epoxy resin before I do any cockpit work. Just makes it easier to waterproof everything before it gets closed up. I use Envirotex Lite epoxy, works great for glass cloth and sealing.
ID:	1674135   Click image for larger version
Check6 is offline
Old 10-14-2011, 06:00 AM
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fred,
Noticed that you have a new follower/admirer over on the Lobster Boat build.
Great work on the runabout. Maybe it is easier than I thought?
Bob
rblubaugh is offline
Old 10-14-2011, 02:18 PM
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Never heard of that epoxy before. But now that I have I am interested in trying it.
http://eti-usa.com/envirotex-lite/
Kmot is offline
Old 10-14-2011, 03:02 PM
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bob,
Glad to see you checked in. I say go for the build.
Tom,
I've been using this for years. Great stuff.
Fred
Check6 is offline
Old 10-17-2011, 10:51 AM
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Framework for the cabin area installed as well as the forward sheeting on the hull.
ID:	1675592   Click image for larger version
ID:	1675593   Click image for larger version
ID:	1675594   Click image for larger version
Check6 is offline
Old 10-17-2011, 01:51 PM
  #31
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cabin sides installed, floor is placed in but not glued. This is removable to access radio gear. Bottom kick panel installed.
ID:	1675660   Click image for larger version
Check6 is offline
Old 10-17-2011, 02:01 PM
  #32
Deathwish
Deathwish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looking good . What are you going to power it with?
Deathwish is offline
Old 10-21-2011, 05:39 AM
  #33
blizard05
blizard05's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fred, a 540 can would be good. I have a Traxxas (stinger) in my sterling century,runs good Larry
blizard05 is offline
Old 10-21-2011, 04:25 PM
  #34
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys,
I have a 550 Goldfire airplane motor. Will this work?
Fred
Check6 is offline
Old 10-21-2011, 06:34 PM
  #35
Deathwish
Deathwish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you know how many turn's it is?
Old 10-21-2011, 06:51 PM
  #36
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, I don't. How do you determine that?
Fred
Check6 is offline
Old 10-21-2011, 09:20 PM
  #37
Deathwish
Deathwish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some motor's tell u on the side. not sure on your's since it's for a plane.
Old 10-22-2011, 03:17 AM
  #38
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found the following information on the "Goldfire 550 Motor":
Great Planes S-600 7.2-8.4 Volt Ferrite Motor
Former Goldfire Motor 05 (550)
Windings: 19 turns of .80mm wire. Timing: + 3 degrees Resistance: .37 ohms
No Load
7.2V - 19,140 RPM
8.4V - 21,960 RPM
Shaft Diameter: 3.17mm (.126") Free Shaft Length: 10.2mm (.408") Case Diameter: 37.0mm (1.48") w/flux ring 35.5mm (1.42") w/o ring Case Length: 56.8mm (2.27") 550 size can Weight: 215g (7.5 oz) Bronze bushings Closed end bell
Epoxied balanced rotor Flux ring for increased power
Boat this motor is in: Kyosho WaveChopper
Information found at this link: http://www.wopba.com/motors.htm
Hope this helps.
Bob
Old 10-22-2011, 08:42 AM
  #39
Kmot
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From the Moto-Calc tables:
Great Planes GoldFire
2441
2.000
0.0940
7.60
This means 2440 RPM per volt, and 2A current per volt. It's a "hot" motor. If you use it, start out with a small prop. And an ESC rated at least 30A continuous.
Kmot is offline
Old 10-22-2011, 10:55 AM
  #40
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All,
Thanks for all the info on motors. I probably will be selling this when I'm finished. If you are interested email or PM me and we can discuss price. I will also install your motor. These frame works are used to form the bend in the hatch tops. I made the bends by wetting the hatch tops and using an old steam iron to heat and bend the hatches. Works great and you can make the bends in 5 mins. instead of waiting overnight to conform to the forming frames. Hatches are rough fitted.
ID:	1677533   Click image for larger version
ID:	1677534   Click image for larger version
ID:	1677535   Click image for larger version
ID:	1677536   Click image for larger version
Check6 is offline
Old 10-23-2011, 03:43 AM
  #41
blizard05
blizard05's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fred, if you don't use that motor,I would be interested in it. I have some more of the smaller motors. Larry
Old 10-25-2011, 06:14 PM
  #42
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK guys,
I have planked the motor hatch with mahogany strips with ABS plastic trim pieces between them.
I had to even out the hatch planking, wasn't happy with the uneven planking at the end.
Looks a lot better now.
ID:	1678777   Click image for larger version
ID:	1678778   Click image for larger version
ID:	1678779   Click image for larger version
ID:	1678780   Click image for larger version
ID:	1678781   Click image for larger version
Check6 is offline
Old 10-26-2011, 07:46 AM
  #43
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oops.
Old 10-26-2011, 07:57 AM
  #44
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fred,
The hatch looks great after you evened it out. Question; what did you do? I compared the before and after photos side by side and other than reshaping the left side to match the right side I didn't see any other planks replaced. I know I usually start in the center and it works out right (pic. Dumas 36" C-C Commander). I'd like to know what to do when it doesn't come out right.
Also, is that .020 thick ABS?
Bob
Old 10-26-2011, 10:10 AM
  #45
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bob,
I trimmed the left plank to match the right one. Had to cut the hatch to match the trimmed plank. I then filled in the space in the hatch area so everything would match. Worked great. Starting the rear hatch, done the same way. Glue in the center piece centered on the hatch, then alternate the planks going out to the edge. I'm using the plastic that was in the kit. Don't know the thickness.
Back hatch is now complete. Will start the planking on the hull next.
Fred
ID:	1678983   Click image for larger version
ID:	1678984   Click image for larger version
ID:	1678985   Click image for larger version
ID:	1678986   Click image for larger version
Check6 is offline
Old 10-27-2011, 11:04 AM
  #46
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got the hull planked with 1/2 in. mahogany strips. Start at the keel bottom and work your way out. When finished start at the chine rail and work up to the top of the deck. Goes pretty quickly with CA and accelarator. When finished needs a good sanding.
ID:	1679391   Click image for larger version
ID:	1679392   Click image for larger version
ID:	1679393   Click image for larger version
ID:	1679394   Click image for larger version
ID:	1679395   Click image for larger version
ID:	1679396   Click image for larger version
Check6 is offline
Old 10-27-2011, 01:45 PM
  #47
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Transom installed. Port side of hull finished planking. Hull needs a good sanding now.
ID:	1679495   Click image for larger version
ID:	1679496   Click image for larger version
Check6 is offline
Old 10-27-2011, 06:02 PM
  #48
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah ha, now I see it.  Wasn't looking outside the box.  Duh.
Old 10-27-2011, 07:38 PM
  #49
Deathwish
Deathwish's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Impressive keep up the good work.
Old 10-28-2011, 06:14 AM
  #50
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I really appreciate your workmanship and especially all the pictures. An exceptional build forum.
Bob
Reply
Display Modes
