Dumas 36" Chris-Craft Runabout Build
#51
My Feedback: (427)
RE: Dumas 36
Hi Deathwish and Bob,
I appreciate you following the build and your nice comments. Hopefully this build will help someone else if they are contemplating a similar build.
I just installed the top trim decking that runs the lenght of the boat. Starting to install the fore deck planking. Done the same way as the hatches.
#56
My Feedback: (427)
RE: Dumas 36
OK, I didn't like the way the rear part of the decking on the front deck was meeting the windshield frame. I cut out the rear and inserted a trim piece. This makes a nice smooth neat transition. Instrument panel has been constructed. Next the frames for the seats will be built and fitted to the cockpit.
#57
RE: Dumas 36
After comparing pictures, that does give it a much cleaner look. Is that about a 1/8" piece you've added there? It appears you did a masterful job of shaping the trim piece so it met the decking very smoothly with a very gentle slope toward the windshield. Then again, maybe that's just optical illusion. Any way, it looks nice.
#58
My Feedback: (427)
RE: Dumas 36
Hi Bob,
It's 1/4 in. trim piece of mahogany stock. I tapered the edge that fits against the windshield frame and made the cutout a little tight so it would be a press fit. Made a nice tight joint.
Seat frames have all been constructed and fit into the cockpit area. These will be glued to the floor boards Everything will be removed as one unit for access to radio and engine equipment.
#62
My Feedback: (427)
RE: Dumas 36
Construction is pretty much complete. I'm planning on installing all the hardware and running gear before I finish the boat. I'll drill all mounting holes and trial fit all the hardware. This will make it easier to install everything without damaging the finish on the boat.
I have drilled the holes and mounted the rudder and stuffing tube as well as the motor. More to follow.
#75
RE: Dumas 36
I built This Dumas Runabout about 15 years ago, I went through sever motor setups util I got the one I like. Iadded a6 volt water pump under the front floor that cools the motor and exits out thetwo transom exhaust outlets. Itlooks cool even sitting still and water is pumpingout the exhausts. I also addedtwo3 volt lightsmounted on side of thewindshield.I havehada lot of boats, butthis isstillmy favorite boat to run.
