small rc boat build!
so i am making a small rc boat out of plywood it will be approx 10 inches.i will include pics of boat made of cardboard just so i could c what it looked like. so i am trying to figure out what electrical equiptment i should use! this is everything i can think of that i will need! is there anything im forgetting to get this boat rtr? can ye try give me suggestions for the blank spaces? or if ye think something i have listed isnt going to work!!!
Motor: http://www.hobbyking.com/hobbyking/s...er_3000kv.html
esc:
servo: http://www.ebay.ie/itm/250910864791?...84.m1423.l2649
radio gear:
prop:
rudder:
driveshaft:
battery:http://www.ebay.ie/itm/260810367398?...84.m1436.l2649
charger:http://www.hobbyking.com/hobbyking/s...40v_Input.html
http://www.ebay.ie/itm/Axial-AX-3-AR...item35b9c0e409
r is there any cheaper 1 that will work????
esc:
radio gear:
prop:
rudder:
driveshaft:
RE: small rc boat build!
Hi Jack,
If you're not set on going high-tech brushless, then obviously the cheaper route would be using a simple small hobby or surplus motor, servo-controlled micro switch instead of an electronic speed control, and a ni-mh battery pack.
A coupler could be as simple as silicone or rubber tubing. For rudder/prop/driveshaft on a boat this small, you could probably gut an old Radio-Shack rc boat from a garage sale or thrift store.
Now that's cheap!
Now that's cheap!
