RC Scale Boating Enjoy rc scale boating? Talk about it here.
First Time Build - Dumas Trojan F31
Reply
Old 03-16-2012, 05:32 AM
FOB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default First Time Build - Dumas Trojan F31
This is my first build i have every done. lots of fun!
ID:	1739317   Click image for larger version
ID:	1739318   Click image for larger version
ID:	1739319   Click image for larger version
ID:	1739320   Click image for larger version
ID:	1739321   Click image for larger version
ID:	1739322   Click image for larger version
ID:	1739323   Click image for larger version
ID:	1739325   Click image for larger version
ID:	1739326   Click image for larger version
ID:	1739327   Click image for larger version
FOB is offline
Old 03-16-2012, 05:36 AM
FOB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: First Time Build - Dumas Trojan F31
ID:	1739329   Click image for larger version
ID:	1739330   Click image for larger version
ID:	1739331   Click image for larger version
ID:	1739332   Click image for larger version
ID:	1739333   Click image for larger version
ID:	1739334   Click image for larger version
FOB is offline
Old 03-16-2012, 05:40 AM
FOB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[youtube]http://www.youtube.com/watch?v=ZTaXbGALD_I[/youtube]
FOB is offline
Old 03-16-2012, 05:49 AM
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You've done a really nice job, especially on the stem of the boat where a lot of people seem to have a major problem. [X(]  The stem on your model looks to have come together very nicely.
What is your run time on the 3000 mAh battery pack?  What size motors are you using?  Can't really tell from the pictures.
Congratulations on a very nice build.  I'd really like to know more about how you built the stem because of all the problems I've read about in other Trojan builds.  It is probably the one part of the build that has kept me from building my kit.
Bob
rblubaugh is offline
Old 03-16-2012, 05:57 AM
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Video was nice.  Looked like it got up on step but hard to tell since ther were no close shots of her going past wide open.  I'd think it to be unusual for the wires to become that warm so as to smoke but a heaver guage is definitely  needed.
Thanks for making the video.
Bob
Old 03-16-2012, 07:25 AM
FOB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not too sure what area you mean when you refer to the stem.
The engines I went with are 2 Orion SV2 19 turn x2.
I Will be able to answer your question about run time on the 3000 once I run it for longer then a couple min. Got a few things left to do before she ready for long hauls.
FOB is offline
Old 03-16-2012, 01:49 PM
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The definition of "stem" is "The stem is part of the physical structure of a wooden boat or ship that gives it strength at the critical section of the structure, bringing together the port and starboard side planks of the hull." - Wikipedia
The stem is the bow and I was referring to the area where the plywood joined from the keel to the deck.  The joint, as far as I could see, was very tight compared to 3 or 4 other builds I have followed.
Bob
Old 03-16-2012, 03:56 PM
FOB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the clarity! I wish I could tell you that I had some special touch for lining up the stem so wel.... I don't, it just came together pretty good with some clamps and long arm quick grips.
On another note, I was re-wiring today after the little melt down, and I found the connector between the battery and the ESC was melted together.
What could be the cause of this?
Thanks in advanced for any replies!
FOB is offline
Old 03-21-2012, 06:36 AM
FOB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found the issue with the Tyima connections melting... Im told they can only handle about 25- 30 amps before they start to melt. So i changed all my connections to Deans Ultra connectors and every thing is good.
Im waiting for a Larger battery to come in that i ordered, but the 3000 MAH battery that im currently running the boat with only gave me about 4 min of run time.
FOB is offline
Old 03-21-2012, 07:13 PM
rblubaugh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At that rate you were drawing over.55A per minute!  Something just doesn't sound right there?!?
Old 03-22-2012, 04:35 PM
Apismelifera
Apismelifera's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: FOB
Too much current for the connector you were using.
Those that are used for the battery and are repeatedly plugged in and unplugged are more prone to this problem. The constant connect disconnect cycle gradually degrades the connection between the two. The contact resistance goes up and it turns into a little heater.
Replace it with a higher amp rated connector. Not all batteries come with a connector that can handle a continuous maximum discharge condition.
I'm sure that connector is cheap compared to the cost of the boat.
Apismelifera is offline
Old 03-23-2012, 03:34 PM
Drifter1soc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That boat was a gutsy first build. I did that one as my second and haven't completed it yet. You did a nice job on it. the directions for builing the boat were at best vague. Understanding the chine and getting the bow closed were the biggest problems I had. Then like you i just had to go and start alter things. LOL
http://www.youtube.com/watch?v=Dqr9J...uzKMqghOHU3_s=
Drifter1soc is offline
Old 03-26-2012, 01:52 PM
FOB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks. Im pretty happy with the way it turned out. being my first build and all...
The Deans Ultra connectors made all the difference. No more melting!
Drifter1soc, I found your you tube post when starting my build and thats what gave me the idea of making up a fly bridge. I find it give the boat a more modern look. What type of ESC's are you running?
FOB is offline
Old 03-31-2012, 03:18 PM
Drifter1soc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm glad my boat was inspiring to someone.I agree it gives the boat a more modern look without aking away from it. I put a set of 35 amp watercooled brushless motor marine speed controls in it. Running two 1050kv brushless outrunners. The boat it overpowered, but it runs forever on a 2good 3 cell lipos. I own several helos and a plane that runs on the same batteries. That also caused me to use connectors that can handle high amp draws and are polarised to prevent mistakes.
Here are some more pics.http://www.rcgroups.com/forums/showthread.php?t=1578992
Old 05-28-2012, 07:55 PM
87burb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow beautiful boat. I started building mine about a month ago. The instructions are not fun. The front of your boat came out great. Could i ask what epoxy and/or fiberglass you used?
87burb is offline
Contact Us Archive Advertising Cookie Policy
