Go Back  RCU Forums > RC Boats > RC Scale Boating
Reload this Page >
back to boat building after a long absence - scale questions
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Reply
Old 03-18-2013, 04:29 PM
Scratchie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default back to boat building after a long absence - scale questions
I’m back to boat building after a long absence, and want to take what I’ve learned and build a beautiful ship model.
I’ve been building RC airplanes (WWII) for a number of years, and am taking a break and going back to building ships.I’m tired of watching every single once of weight limiting my scale options, fidgeting with flaps and damaged landing gear.I think that for now I enjoy building more than flying.
Anyway, I’ve started a rc 1/55 scale model of the SS Shengking, a 1931 300’ Scottish built small passenger-cargo ship.The hull is roughed-in, beginning to get ready for fiberglassing.Watching YouTube videos of similar ships leads to ideas about scale features, particularly promenade deck planking, state room doors and porthole details.
What features have you found that take a model “to the next level”?
1. Lights within cabin areas
2. Davit details (what to include and where to get decent pics of bolts/pulley placement
3. Life boat details, life boat covers?
4. Exhaust stacks
5. Real-looking deck skylights and cargo hatches
6. Working smoke stack, how is it done so it looks real?
What type of railing construction to use?I think this particular feature needs to be correct for the era.I attached the plans I have, they’re good enough (with some tweaking) to the get the ship built and ready for detailing, but show little details.
What do you think?
Always on a tight budget, thanks
ID:	1863974   Click image for larger version
ID:	1863975   Click image for larger version
ID:	1863976   Click image for larger version
Scratchie is offline
Old 03-19-2013, 02:04 AM
mfr02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: back to boat building after a long absence - scale questions
Yes to all of them.  1:55 is an odd scale, so you will likely be making rather than buying parts.
Smoke units are readily available, you get white "steam" rather than black smoke.  The particles that make smoke black tend to be full of carcinogens, so their use is not generally encouraged.
If cabins are to be lit, make sure that the light doesn't shine through the structure.  Good lighting looks great, bad lighting makes a model boat look like a floating table lamp.
mfr02 is offline
Old 03-19-2013, 06:22 AM
Scratchie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the lighting tip. what about hand rails, what's a good wat to make those?
Old 03-19-2013, 07:07 AM
mfr02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Depends on just how good you want them.  Some folks like shaping split pins, some buy PE brass, some make a jig and lay up tinned copper wire and solder it, some just jig up brass wire and solder it.  There will be a preferred alternative for everybody who answers, but I suspect that, since your chosen scale falls between commonly used ones, there will be nothing commercially available the right size, too tall or too small.
mfr02 is offline
Old 03-20-2013, 07:41 AM
Scratchie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the model is all scratch - no funds for the kits. Ilike the idea of laying our a jig. what is PEbrass - tinning copper wire may lead to lumps. btw, on teh old 1930s ships would the top rail be painted steel or wood? any ideas?
Old 03-20-2013, 01:54 PM
mfr02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PE - photo etched.
If you get lumps tinning, stroke it again with a hot iron - failing all else, most modelers have a file.  The jig is just a means of making sure that the holes line up.  I tend to use panel pins in correctly spaced holes in the wood (liberally coated with something to stop the solder fixing to the pin).  The elephants foot at the deck is just a wrap of wire with the ends poked down the hole.  Fast, easy, cheap and strong, but obviously not as pretty as machined or etched ones when closely inspected.
The top rails on merchant ships were almost certainly wood, or at least, the visible capping would be.
mfr02 is offline
Old 03-20-2013, 06:19 PM
Scratchie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
have any pics?
Old 03-21-2013, 02:54 AM
mfr02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, no pics on this forum since the easy upload option was removed.The wire I used was the tinned stuff as found up the inside of telephone extension cable, with the insulation removed. Easy to shape, easy to solder. My boats are for sailing and looking OK at a safe distance, rather than for close inspection.
mfr02 is offline
Contact Us Archive Advertising Cookie Policy
